Question about kawasaki Full Suspension Mountain Bike Men
Hello, i have a kawasaki jet ski 1996 engine is a jh1100 how do you bleed the oil line the cover plate has a looks like ten millimeter screw on it i think thats the bleeder if so what is the proses on bleeding it out thank you,kevin
  • 427 Answers
Just loosen the oil cap and then loosen the bleeder untill steady stream comes out the bleeder. Top off with oil replace cap and thats it . Good luck
Posted on Jul 22, 2010
What is the gas-oil ratio mixture for a 1995 kawasaki jh750-a4 jet ski
50 to 1 that is 2.5 ounces to the gallon for pleasure riding
40 to 1 that is 3.2 ounces to the gallon for racing
May 09, 2015 | kawasaki 2010 Jet Ski Ultra 260X
How do I adjust seadoo RFI mixture?
There should be an adjustment screw that looks like a "t" on the side of each carb. Screw it in 1/8th turn at a time to lean it out. Too much and engine detonation. I would recommend getting the retrofit kit to block off the oil tank and run mix fuel. Then there are no issues with too lean/rich, oil pump failure, plugged oil filter, broken or collapsed oil lines etc.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/matthew_d24b835e574ef6ca
Sep 03, 2014 | WSM 1999-2003 Sea Doo Gtx 951 Cc Jet Ski...
What oil and how to you check it in a 93 kawsaki 750 jet ski, not engine oil the transmission oil
Your 750 jet ski does not have a gear box. If you are referring to what looks like a filler cap on the front of the motor, that is the generator/flywheel cover and it is a dry compartment and should remain that way.
Jun 11, 2011 | Encore Software Kawasaki Jet Ski...
I have an kawaski 440 jet ski and how much oil does it take in the gear box and what kind
Your 440 jet ski does not have a gear box. If you are referring to what looks like a filler cap on the front of the motor, that is the generator/flywheel cover and it is a dry compartment and should remain that way.
Apr 16, 2011 | kawasaki Full Suspension Mountain Bike Men
How to replace seal on a jet ski
The seals in the drive pump can be replaced by taking off the ride plate and pump housing. To replace any other seals (engine or hull) you will have to remove the motor from the hull.
May 15, 2010 | kawasaki Full Suspension Mountain Bike Men
Jet Ski Won't Start when Engine is cold
You must take out completely the carbs and clean them especially their canisters with the flowters.They may have jelled gas inside or closed air pipes.Use a carb cleaner spray and compressed air.
May 25, 2009 | 1990 kawasaki ZXR 750
Jet Ski Will not start when cold
If the teeter/totter needles are gummy or covered with moisture corrosion it could be the reason the machine is so hard to start. When storing the jet ski's syphon all the gas out and burn it in your car or truck. Even if you stabilize it it wont be good fuel in the spring. Your plastic tank will not rust so remove the fuel. You may be able to clean them up by running a tank of Chevron Techron through them. Before riding we charge are batteries and start are jet ski's on the trailer/lift before dropping in the lake. This saves the battery. It takes more juice to start the boat in the water.
May 25, 2009 | Encore Software Kawasaki Jet Ski...
kawasaki Full Suspension Mountain Bike Men Logo
5,125 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
michael
michael
Marvin
Marvin
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
