It appears both the main & backup batteries on my Dell Axim died. Is there anyway to retrive the data when this happens?
  • 6,993 Answers
there is no way you can retrieve the data on the Dell Axim without it being turned on or without it having a power.
But on the other hand, you can try to connect the Dell Axim to a computer using a USB cable and you might be lucky the computer recognizes it, then you can copy the data into the computer.
If the computer doesn't recognizes it, then it means you will have to revive/recharge the dead battery or look for a friend that will borrow a battery that you can use to power up the Dell Axim.
I wish you good luck.
Posted on Jul 22, 2010
Dell Axim X5 Backup battery
CR2032 battery. Backup your information first.
Jan 03, 2010 | Dell Axim X5 Pocket PC
I have a dell axim x51v I made a password change and entere it into a digital rape recorder the recorder died on me and I do not remember the password as it happened 2 day after de change my cuestion is...
Once you forget the Password, your only option is to perform a Hard Reset on the device and reset back to Factory defaults. You data will be lost, as this is in place to protect you in case the device has been lost or stolen. If you have backups, or sync the device with Outlook, you can run a restore or re-sync the device to populate the data back into your device.
Hard Reset:
NOTICE: When you do a hard reset, you lose all the data stored in your device
Flash memory, and any programs that you installed on your device.
Do a hard reset if:
  • You want to restore the device to factory default settings.
  • You forget your password and need to reset it.
  • Your device is experiencing severe operational problems and you have already attempted a soft reset.
NOTICE: It is strongly recommended that you back up your data before you do a hard reset.
To do a hard reset:
  1. Press the Power button to turn the Axim unit On.
  2. Press and hold the Power button down while using the Axim stylus to press the Reset button at the same time.
  3. Release the Power button and the Reset button. The To clear all data in the memory screen appears.
  4. Press the Contacts button on the Axim to delete all of the data in the memory of the Axim handheld.
  5. Press the Mail button on the Axim to cancel the operation without losing data.
Sep 03, 2009 | Dell Axim X51v Pocket PC
I bought a cheap Axim X5 PDA and I believe it is missing the top "door" but I am not sure, as I bought it from ebay, and don't know anything else about it. Also, it needs a back up battery cover. I am...
Dell Axim5 Top Door is for Compact Flash car. the Battery Backup is the one to maintain the memory alive, but if you still have main battery good is supposed the memory remain until you go out of battery. I have one with some reason the battery backup do not function, so I have to backup all data.
Jul 02, 2009 | Dell Axim X5 Pocket PC
Backup battery discharging
hi thanks for using fixya!
You have to bring your Dell Axim X5 PPC to a service center, to check further the back up battery if needs to change it.
If you need further assistance, let me know.
May 28, 2009 | Dell Axim X5 Pocket PC
Hard reset screen appears whenever i change the main battery
Your pda has a built in battery.The inbuilt one has lost its charge. To keep it from reseting to its original factory settings. You need to keep the main battery(the one you charge up) regularly charged.
Feb 14, 2008 | Dell Axim X50 Pocket PC
Backup battery problem
Try this web site:http://www.pdasmart.com/aximpartscenterx3.htm?tp=CONTINUE+SHOPPING
Sep 04, 2007 | Dell Axim X30 Pocket PC
Axim Data Backup Does Not Work
After doing a soft reset to enable Clear Type, I tried a backup of all data and everything worked! Nor Backup Failure Message and the backup file can be seen on the CF card.
Sep 14, 2005 | Dell Axim X5 Pocket PC
Restoring Backup to New Axim
The backup utility included on your Dell Handheld will backup your data to a storage card. You can restore on your replacement handheld from that storage card. From your Host PC, you can go to Tools | Backup/Restore and do a backup to the Host PC, and you can then restore after syncing the replacement handheld for the first time.
Loss of data when battery goes dead?
-are all pda's this way? All PocketPCs are this way. I don't own a P**m so I can't speak to them. -When the main battery depletes to the point where the unit shuts off how long do you have before data is lost? Until the backup battery dies. -Is the backup battery just used when changing main batteries or does it take over when the main battery goes dead? If so how long do you have before it is dead? I've never had it happen, so I cannot say how long, but if you continue to try to use the PDA on the backup battery it won't be long (minutes) if it even lets you do that. The backup is there to bridge over battery changes and to act as a safety net if you run the main batteries totally flat. -does the backup battery recharge or does it have to be replaced? Replace. -with a fully charged unit how long can it be left off before data is lost? Depends on the machine. Most of us leave the thing in the charger overnight every night, so this issue doesn't come up. You could try an experiment for 1, 2, 3 days, looking each day at the battery remaining and work up an estimate. I would expect maybe a week or more. Remember, even "off" the machine is still drawing power to maintain the RAM memory.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
