Question about Fisher and Paykel DS602 Dishwasher
Hi I have a Nemo Dishwasher and the top spray arm is not turning. The bottom one is going fine and there is certainly plenty of water getting into the washer as I opened the door with the washer going and it flood me. I can see the water getting into both spray arms - the bottom one has a excellent upward spray and turns - the upper spray arm has water getting into it but it will not turn. I have cleaned the dishwasher out and any internal parts that I could find so it is spotless - this is so frustrating as the top spray arm not working means the dishes just do not get cleaned on the top tray. Pump and motor seem to be working as I can hear them. Any suggestions.
SOURCE: Dishwasher not working
Have got the problem sorted. Water got into the control panel which changed the setting for the water pressure. Have now re set the setting and our dish washer is back up and running as normal. If anyone else has the same problem... I will not down the way to amend the setting.
I suggest that when unloading your dish drawer, that you wipe the control panel dry after every use to stop water getting into it.
Hope this helps others.
Fishgirl
Posted on Jan 07, 2008
SOURCE: Fisher and paykel DD605SS
hold all three bottons: power, pause and start and power cycle the unit, it will reset the dish washer.
Posted on Feb 05, 2009
stephanos18
  • 144 Answers
SOURCE: Fisher & Paykel Dishwasher DS603- water not draining out
Does it show a fault code? eg F4?
Posted on Mar 27, 2009
  • 81 Answers
SOURCE: Dishdrawer DD601 v2 Error F1 on the bottom draw.
Below is the link to the service manual
http://www.scribd.com/doc/6462163/DD601V2-Manual
This will be able to explain the problems better that I can in the tiny space I get to write in.
Mat
Please rate me
Posted on Sep 24, 2009
yeaharbrown
  • 18 Answers
SOURCE: Replacing the spring of the door of a F&P dishwasher
How do you repair door springs on F/P DW 820 dish washer. My door seems different from ones on the web.
Melville Brown
Posted on Aug 09, 2010
I have a Frigidaire dishwasher, PLD4460. Only 4 years old. The dishes on the top rack are not coming clean anymore. Something as simple as left small bits of broccoli do not even get rinsed out of the...
Hi
If the top rack of the dishwasher doesn't get clean, check your appliance to see if you can fix the problem.
First check the spray Arms to make sure the holes in the spray arms are free and clear of debris. Your dishwasher should have several spray arms, including one at the bottom of the tub, one under the top rack, and possibly a third spray arm on the top of the tub. Sometimes food and mineral deposits can block holes in the spray arms, preventing water from spraying effectively. If this occurs, warm some white vinegar and pour it into a spray bottle. Spray the holes with the vinegar and dislodge debris with a toothpick or large safety pin.
Then check to see if your dishwasher has clogged filters. Filters generally cover the drain valve area to catch debris as the water drains from the dishwasher. Many dishwashers have maintenance-free filters, but your dishwasher may have filters that need cleaning. Read your owner's manual before you perform any filter maintenance to avoid damaging your dishwasher.
Check your water temperature to make sure it's hot enough. Water that is under 120 degrees Fahrenheit may not be hot enough to clean dishes effectively. Turn your kitchen hot water tap on and wait until the water warms up completely. Fill a cup and measure the water temperature with a kitchen thermometer. If the water is less than 120 degrees Fahrenheit, turn your water heater up to 120 degrees.
Load the top rack properly. Place cups and bowls upside down in the rack and don't nest dishes because this can prevent water from reaching dishes. Don't overload the top rack. Instead, position each item so the dirty areas of the dishes will receive full contact with water spraying up from the main spray arm located beneath the top rack. Prevent items from hanging below the top rack, which could prevent the spray arm from rotating.
Also check this link for more helpful info:-
http://www.ehow.com/info_7977311_top-dishwasher-not-getting-clean.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 15, 2011 | Dishwashers
Whirlpool Gold Dishwasher - GU2700XTSB The top rack of the dishwasher is not cleaning. The bottom rack dishes clean fine. There are no clogs in either the bottom or top spinner arms, the plastic tube...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Jan 20, 2011 | Whirlpool GU2700XTSB / GU2700XTSQ /...
The top two water water arms do not spin
These spray arm will only get water several times in the wash and rinse cycle. They do not turn at the same time the lower (bottom large spray arm under the bottom rack).
There is a chamber that diverts water either to the bottom sprayer or to the top sprayers, not to both at the same time.
If your top spray arms never get water, then there must be an issue with that chamber motor to divert the water. A new sump assembly that has all the new parts.
Good luck.
Jul 19, 2010 | LG LDF6810ST Stainless Steel Built-in...
7-8 year old KitchenAid washes dishes on bottom, but not on top
Position the spray arms in a certain position. Activate the dishwasher for a few seconds and then examine the position of the spray arms. If the upper spray arm has not moved, then either there is no water coming to the spray arm or the spray arm is clogged.
Apr 14, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Top rack not cleaning; now dishwasher does not even turn on.
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
iii
Mar 13, 2010 | KitchenAid 24 in. KUDP02CRBS Stainless...
Bottom spray arm not turning
heatman101
rthd
Jun 09, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Only washing top rack
After observing the water just gushing out when the spray arm was removed, we determined there was still a bunch more calcification/soap in the ends of the spray arm. (We have very hard water in our area). Unfortunately, you cannot open up the spray arms to clean them out, so it took about 30 minutes of pounding and manipulating to get all the gunk out. Now my dishes are clean again. Hallelujeh! And the water cleaning the dishes is cleaner, as well.
Jan 11, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Top arm not spinning
only the top rack isnt getting clean?
there is a little plastic circle in the middle of the bottom of the upper spray arm. turn it counter clock wise to pull the upper spray arm from the upper rack. make sure that isnt clogged and the spray holes are not clogged. otherwise....
the piece that the bottem spray arm plugs into and runs along the back wall of the tank to the top is called a feed tube. pull the bottom spray arm out. now you can see the part of the feed tube that feeds the upper spray arm water. does it pop out freely and easily? if so then you need a new feed tube, if not then its most likely your not achieving the right water level or your impeller connected to your circulation pump(motor) is clogged not supplying enough water pressure to travel up the feed tube to spin the upper spray arm.
Jul 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher
  This dishwasher does not feed water to top and bottom arms at same time.  It starts with bottom and then after awhile it switches to top and then cycles.  If water comes out arms but arms won't turn,  check all holes in arms.  It's the water spraying out these that causes arms to turn.   If arms spin freely by hand,  it's a plugged arm or holes in arm or insufficient water in tank.
  Being that it only sprays 4 inches suggests a water level problem or possible mineral build up restricting flow.
Oct 11, 2007 | Frigidaire 24 in. PLD2850 Built-in...
I replaced the spray arm seal, but the arm still wont spin. I get water but not enough pressure to turn the top arm. The bottom arm works fine. Should the top arm turn easily when pushed by hand. It...
arms should turn freely. spray arms are only rotated by water spraying out from angled jets at end. check for blockage in spray arms - sweet corn and rice are the worst offenders. take spray arms off and run water in centre hole and see it runs out of all the jets freely
Apr 08, 2007 | Whirlpool GU2400XTPS Built-in Dishwasher
Dishwashers Logo
54 people viewed this question
Top Fisher and Paykel Dishwashers Experts
TomDicker
Level 1 Expert
Simon Flummox
Simon Flummox
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
