Question about Traulsen G30010 Commercial Refrigerator
What is a normal temperature i should set?
SPH--?
SPL--?
SCL--?
CL--24?
dA4--TODAY DATE
d5-?
sd-?
dL1--?
dL2-?
dL3--?
dL4--?
ro--?
what number should i entry on the above symbol to function the frezzer?
  • Traulsen Master
  • 1,262 Answers
I have a 2000 crown vic and my coolant fan wont come on unless i cut the a/c on or unplugged the cylinder head sensor i changed thermostat and temp sensor it still same thing what could be the problem
You have a wiring problem from sensor to the PCM - engine computer .
DL22 CHECK CHT SIGNAL CIRCUIT FOR SHORT TO GROUND
    Note: Refer to the PCM connector pin numbers in the beginning of this pinpoint test.
  • Disconnect PCM.
  • Measure resistance between CHT signal and SIG RTN circuits and then between CHT signal and PWR GND circuits at the PCM harness connector.
  • the PCM is what controls the cooling fan !
  • This Pinpoint Test is intended to diagnose the following:
    • Cylinder head temperature (CHT) sensor (6G004)
    • Harness circuits: CHT, VREF, and SIG RTN
    • Powertrain control module (PCM) (12A650)
    Tables and Graphs
    On applications that do not use a ECT sensor, the CHT sensor is used to determine the engine coolant temperature in place of the ECT sensor. In this case the PCM may store both CHT and ECT Diagnostic Trouble Codes (DTCs). To cover the entire temperature range of both the CHT and ECT sensors, the PCM has a dual switching resistor circuit on the CHT input. A graph showing the temperature switching from the COLD END line to the HOT END line with increasing temperature and back with decreasing temperature is included. Note the temperature to voltage overlap zone. Within this zone it is possible to have either a COLD END or HOT END voltage at the same temperature. For example, at 90°C (194 °F) the voltage could read either 0.60 volt or 3.71 volts. Refer to the table for the temperature to voltage expected values.
    Voltage values were calculated for VREF = 5.0 volts. These values can vary 15 percent due to sensor and VREF variations.
  • DL1 DTC P1288 OR P1116: CHECK OPERATION OF CYLINDER HEAD TEMPERATURE SENSOR
    • Run engine at 2000 rpm until engine temperature becomes stabilized.
    • No Starts or Vehicle that Stalls:
      • GO to DL3 .
    • Check that upper radiator hose is hot and pressurized.
    • Rerun Key On Engine Running (KOER) Self-Test.
    Is DTC P1288 or P1116 present? Yes No GO to DL2 . Engine temperature was not stabilized. REPAIR any other DTCs as necessary. DL2 CHECK VREF CIRCUIT VOLTAGE AT TP SENSOR
    • Refer to schematic at the beginning of this pinpoint test.
    • Disconnect throttle position (TP) sensor.
    • Key on, engine off.
    • Measure the voltage between VREF and SIG RTN circuits at the TP sensor harness connector.
    Is voltage between 4.0 volts and 6.0 volts? Yes No There is sufficient VREF voltage. RECONNECT TP sensor. GO to DL3 . GO to C1 . DL3 CHECK RESISTANCE OF CYLINDER HEAD TEMPERATURE SENSOR WITH ENGINE OFF
    • Disconnect CHT sensor.
    • Measure resistance between CHT signal and SIG RTN pins at the CHT sensor. Refer to the table at the beginning of this pinpoint test for resistance specifications.
    Is resistance within specification? Yes No For No Starts or Stalls, RETURN to Section 3 , Symptom Charts.
    All others, GO to DL4 . REPLACE CHT sensor. You need a scan tool to do some of these tests
  • DL4 CHECK RESISTANCE OF CHT SENSOR WITH ENGINE RUNNING
      Note: Verify that engine is at operating temperature before taking CHT readings.
    • Run engine for two minutes at 2000 rpm.
    • Measure resistance between CHT signal and SIG RTN pins at the CHT sensor. Refer to the table at the beginning of this Pinpoint Test for resistance specifications.
    • Key off.
    Is resistance within specification? Yes No REPLACE PCM (refer to Section 2, Flash Electrically Erasable Programmable Read Only Memory (EEPROM) ). REPLACE CHT sensor. DL5 DTC P1289 OR P1290: ACCESS CHT PID AND CHECK VOLTAGE
    • Connect scan tool.
    • Access CHT V PID.
    Is the CHT V PID less than 0.2 volt? Yes No GO to DL6 . GO to DL7 . DL11 CHECK CHT SENSOR SIGNAL AND SIG RTN CIRCUITS FOR OPEN IN HARNESS
    • Disconnect PCM.
    • Measure resistance of CHT circuit between PCM harness connector pin and CHT sensor harness connector.
    • Measure resistance of SIG RTN circuit between PCM harness connector pin and CHT sensor harness connector.
    Is each resistance less than 5.0 ohms? Yes No REPLACE PCM (refer to Section 2, Flash Electrically Erasable Programmable Read Only Memory (EEPROM) ). REPAIR open circuits. free wiring diagrams at www.bbbind.com
Jul 13, 2015 | Cars & Trucks
We have the above model refreigerator. How many times a day it defrost? Let me know how to set dL1 to dL4.
It should normally go into a defrost cycle every 8 --10 hours and last up to 30 minutes then come back on. the optimum setting is medium in a 1-7 dial use about number 4 sorry not sure about ur dl1 to dl4
Jun 21, 2015 | Refrigerators
Voltas Vertis AC not cooling
my voltas split a/c is showing CL on closing please help me out
Jul 04, 2012 | Heating & Cooling
Pulsar watch, how do you set the day of the week and month?
mcdevito75 here, The stem has 2 positions, first adjust the day or month by going thru the 24 hour cycle with the stem. once set, slip a finger nail just ubder the stem and lift carefully this should allow you to change the DATE adjust to 1 date before the date you need, now pull the stem out to adjust date and time of day turn sten the complete 24 hour cycle to achieve the correct date and time of day. Now your watches day and date are set and will change to the next day date on time, around Mid nite 1 --2 AM.
Jul 08, 2010 | Seiko Watches
Who to manuplate the date in java
Date arithmetic is relatively easy if you remember that time in JavaScript is measured in milliseconds. Use the date method getTime() to determine the number of milliseconds that have elapsed since the magic date of January 1, 1970. Use the setTime() method to establish a date you have calculated in term of milliseconds.
Danny Goodman, author of the JavaScript bible recommends that you set up some variables that build on each other to make it easier to do Date Arithmetic. Here is the variable setup that he recommends:
var oneMinute = 60 * 1000 // milliseconds in a minute
var oneHour = oneMinute * 60
var oneDay = oneHour * 24
var oneWeek = oneDay * 7
So for your case (date for 10 days after today), we can declare like this:
<SCRIPT language="JavaScript">
var today = new Date();
var mm= today.getMonth();
var dd = today.getDate();
var yyyy = today.getFullYear();
var oneMinute = 60 * 1000; // milliseconds in a minute
var oneHour = oneMinute * 60;
var oneDay = oneHour * 24;
var dateInMS = today.getTime() + oneDay * 10;
var TargetDate = new Date (dateInMS)
document.write("Today is: " + mm + "/" + dd + "/" + yyyy);
document.write("<br />");
document.write("10 days after today is: " + TargetDate);
</SCRIPT>
P.S.: If this information was helpful, please rate this solution.
Mar 12, 2009 | Microsoft Computers & Internet
Acqua Indiglo water resistant watch with alarm 30m
Press and hold the MODE button (bottom left) for approximately 3 seconds.
When the Alarm set time starts flashing, press the MODE button once more. Now the seconds for the watch time should be flashing.
Use the START/STOP button (top right) to move bewteen items and the SPL/RESET button (bottom right) to change the item.
Moving between all items, it will take you through: seconds, minutes, hours, month, date, day of the week. Simply press MODE when your settings are complete.
Jul 25, 2008 | Watches
Traulsen G30010 Commercial Refrigerator Logo
95 people viewed this question
Top Traulsen Refrigerators Experts
Dennis Boxerman
Andrew Taylor
Andrew Taylor
John Tripp
John Tripp
Are you a Traulsen Refrigerator Expert? Answer questions, earn points and help others
