I have a 2000 hitachi and my picture keeps going in and out. It blinks in and out sometimes if i hit he tv it will come back on for a small period of time. Model #60ex38ba
Slinteriors
  • 8617 Answers
SOURCE: SONY REAR PROJECTOR TV
5 blinks means AKB detected. Try turning down all 3 screen adjustments slightly.
Posted on May 27, 2008
Slinteriors
  • 8617 Answers
SOURCE: Sony KDP-65S550 red light keeps blinking
How many times is the LED blinking in between pauses? that is possibly a error code if you can determine the number of blinks.
Posted on Jun 28, 2008
SOURCE: the light blink 3 times & go off & sometimes it stays on &
I read here from a woman that her husband got a blow dryer and reached inside of his tv and blew off all the dust from the inside of his tv, knowing how much dust can accumulate after 5 years I tryed It and Now my tv works perfectly once again, If you take the panel off in the back that surrounds the wire panel, about 7 screws you can get a small blow dryer inside and get rid of alot of the dust,
Always was affraid to work on the inside of a tv, but that was some easy work,
Thank You to the woman that wrote in with the right fix at the right price.
Posted on Nov 17, 2008
  • 18 Answers
SOURCE: rca d52w14 hit power green light blinks three times wont come on
could be power supply problem or high voltage problem. check caps in main power supply first.look for caps that have tops puffed up ususlly three or four.....
Posted on Feb 25, 2009
  • 157 Answers
SOURCE: My TV keeps shutting off and then the power light
you will find 3 fuses open,replace them also you have to resolder a jumper labeled 010 just in front of L7711
Posted on Sep 29, 2009
Hitachi tv turns on then gets bad picture than turns off blue light blinking
The name of the part is probably "buffer board" and there are two in your TV - upper buffer and lower buffer, also called SDR-U and SDR-L boards.
Those are the two most common sources of problems in P50S601 along with the Y sustain board (SD board in hitachi and Panasonic terminology), which sometimes gets damaged by the failed buffer board.
In the buffer boards market there are all kinds of offerrings. There are old buffers for around $130 for the pair and there are new buffers in the range $160-$200 for the pair.
In my opinion if the difference is barely $30-$40 one is better off going for the brand new ones.
Here's a link to our title for them, you can sure find others if you start from it:
http://www.coppelltvrepair.com/p/182/hitachi-nd60200-0048-and-nd60200-0049-replacement-set-of-buffer-boards
Hope this helps!
Dec 15, 2012 | Hitachi Ultravision P50S601 50 in. Plasma...
Hitachi 53fdx20b Projection Television Had a convergence problem and replaced both ICs. Resistors checked. Turned TV on and worked but still had convegence problem but not as bad. Waited 30 minutes...
If you bought the parts from sites such as www.TvRepairKits.com go back and ask for there help. It can be many things from bad soldering to blown resistors.
Jun 18, 2011 | Hitachi 53FDX20B 53" Rear Projection...
Hitachi projection tv will only turn on periodically. I power the tv up and sometimes it turns right on and other times it seems to power up but then front 3 lights on the front start blinking and the tv...
I don't know what model you have but ... the 50v715 I have did the same thing. Would come up for about 3 to 30 sec's (picture and sound) then shut down and do again. It was the BULB going out. You probably just need to replace your bulb. Check your manual on how to change it out. Make sure you buy an original Hitachi replacement I think there made by phillips. Hope this is helpful.
Oct 26, 2009 | Hitachi Televison & Video
Keeps losing picture,Still have sound
Call him back and tell him that your tv has bad connections. He will check for bad connection on main board in horizontal..........
Sep 13, 2009 | Hitachi 46F500 46" Rear Projection...
May 27, 2008 | Sony KP-53XBR200 53" Rear Projection...
Intermittant white line with subsequent shut down
You have a vert ic problem very common tv problem.
POSSIABLE SOLUTIONS
1 COLD SOLDER JOINTS ON IC REPAIR COST IS 95.00
2 REPLACEMENT IC 120.00
CALL LOCAL TV SHOP AND ASK FOR PRICES ON A VERTICALE IC REPLACEMT. THANKS DOCTOR VIDEO
May 17, 2008 | Hitachi 36UX59B 36" TV
TV Won't Come On...
My Hitachi Model 50V500 led's ligths temperature and lamp blink when power is turn on.Have no picture or sound, followed the reconmended procedure disconnected power
for 30 seconds and reconnected.
Mar 18, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi screen goes snowy and sound is totally distorted
Sounds like bad solder connect in tv tuner....can usually be
repaired or replaced.......................T.
Nov 30, 2007 | Hitachi 43FDX01B TV
Picture blanks out
Check your powercord. Unplug it overnight, then plug the power cord back in the morning. If that doesnt help, it means that something is going on with your set. Sometimes your power cord has shorted out and needs to be replaced. Generally you can find them under $100 depending upon your set...
Aug 21, 2007 | Hitachi 61SDX01B 61" Rear Projection...
Picture flickers when T.V. is tapped on or struck.
sounds very much like a loose connection, i.e. a wire or solder joint, you could have a look around make sure everything is plugged in right, as for the solder joints id advise getting it proffessionally looked at as these rear projection tvs can be a lot of hassle if you slighty knock any of the 3 tubes,
Feb 25, 2007 | Hitachi 53SBX59B 53" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
