Question about Ovens
I need a new door and handle for a Fisher Paykel Double oven model # FP0d302
4 Suggested Answers
  • 412 Answers
SOURCE: Fisher Paykel electric oven doesn't heat in Bake mode
Check the Heating Element of your Oven.......
Posted on Mar 20, 2009
  • 6 Answers
SOURCE: Hi my Fisher & Paykel Paprika stove (Model
Yes the regulators/simmerstats are stuffed but are not hard to replace...but please turn off the power 1st when removeing the backing plate as you will kill yourself....yes you will.
Use a multimeter set on volts ac or a volt detector stick, test tester on a known live sourse 1st like a power point....switched on
Posted on Sep 13, 2009
SOURCE: hello we have a fisher and paykel classic stove
c55aadb.jpg Isolate power from device, remove screws to free back panel.
769e143.jpg Loosen strainer for oven liner on left and right sides and remove clip to allow oven liner to slip forward.
e87a68d.jpg Remove screw on front central upper clip.
42f6dbf.jpg From front, move oven liner forward a few millimetres to release gasket. Here you see the strainer at the rear has moved forwards a few millimeters.
e8ea79b.jpg Remove the old perished seal.
f86ae37.jpg The new seal/gasket part number 573263 is installed. Reverse dismantling procedure to complete reassembly.
Posted on Aug 28, 2010
Fisher and paykel paprika replace door seal
just prise the oven forward a little with a screwdriver too remove old one and to push in new one dishwashing liquid to make new seal slippery helps
Mar 26, 2013 | Fisher and Paykel Ovens
Hi, I have a wo570xd double oven and the controller is playing up, ihave had F& P send me a new controller (572942p), this controller did not work so contacted them again and they have sent out a new...
fisher & paykel oven model WO570XD seems to be no power from source to the wall oven however range top works fine. Power light on switch to oven is illuminated indicating there is power however there is no lighting on digital display unit. Any help appreciated
May 31, 2011 | Fisher and Paykel Ovens
Fisher and paykel oven door wont close, there is a gap at the top of the door. The seal seems to be intact. The door feels loose to the touch.
you need to either replace - or get the door hinges replaced, the spring in the hinges has weakened over time, if it is still in warranty, then they should replace them for free, if not, then take the model number to your local f&P dealer and buy new hinges. Remove the door and dismantle the door to gain access to the hinges, undo the 2 screws holding each hinge in place, clean the inside of the glas while apart, reassemble in reverse order.
May 17, 2011 | Fisher and Paykel OS302SS, Stainless Steel...
I have a Fisher & Paykel double wall oven that I purchased in 2005. The top oven which was used most often stopped heating up to temperature in normal time. What used to take 5 minutes to get up to 250...
Google searches report that after running the self cleaning cycle this can happen. I am experiencing this issue with my Fisher&Paykel AeroTech Double OD302 but with the BOTTOM oven. I'm concerned as Thanksgiving is coming up and I need this baby working!
Nov 08, 2010 | Fisher and Paykel AeroTech Double OD302...
Fisher Paykel oven model OS302M error code F7?
Check your lock on the oven for the door. It may be sticking out a bit:)
Oct 01, 2010 | Fisher and Paykel AeroTech Double OD302...
Our Fisher Paykel OS302 completly overheated during its cleaning cycle. Oven door is locked, nothing comes on and Fisher Paykel will not help, it is only 4 years old, we have made many calls, and certified...
The thermostats have probably blown. There is a rebuild kit for this problem, it is not cheap nor is the labor to do it. Try shutting off the breaker for a few minutes... sometimes it will reset, but not heat. In any event you should have the new thermostat kit installed. F/P should at least be able to give you the tele. of a Tech., keep in mind that depending on where you live there are very few technicians that are certified to fix these.
Jul 08, 2009 | Fisher and Paykel AeroTech Double OD302...
Ovens Logo
35 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
