Question about Whirlpool ED2FHEXN Side by Side Refrigerator
WPL 4389102, came with the LED transmitter (3193683) and the LED receiver (3193662). The receiver module is the one that deceased. Kenmore Icebox. The original receiver board for the icemaker (Optics) was noticebly fried. I replaced both the transmitter and receiver boards and it immediately started in the harvest mode. It almost completely dumped one load of ice and the receiverboard fried again. according to the troubleshooting guide it said if no optics replace both boards. The icemaker is made by whirlpool.
3 Suggested Answers
  • 1218 Answers
SOURCE: I have a kitchen aide side by side. Icemaker not
Good day,
Well your savvy, so, let's do it backwards.
Pull the power plug off of the water valve, and insert both prongs from a vom meter set at 150 Ac or higher.
Cycle the ice maker. You have time, fill is at the end of the cycle.
Just before the end of the cycle you should see 120 volts for approx. 7 seconds. Don't blink.
If you do get power, replace the valve. Jumping them will not always do the trick.
If no luck, then it has to be an ice maker issue. I've installed more than one that never worked from the time of installation.
P.S. You said the water line was not frozen. It's the fill tube that runs from the back of the machine into the ice maker that freezes and is a common problem.
If you can, remove the plastic tube from the bottom of the ice maker (it's the 1/4" inch smaller of the two if you have water in the door). You should be able to blow thru it freely. If not it's iced, problem with a filter ect.
This should be done first.
Thanks for using FixYa.
Posted on Dec 19, 2009
Macmarkus
  • 2605 Answers
SOURCE: whirlpool ice maker ,no harvest?
Hi, The optics almost never go in those unit's, the problem is in the icemaker module itself. If you can jump it thru a fill and then no advancing thru to harvest afterward ( provided your freezer is below freezing ) it's the module. You can either replace just the head/module or the entire icemaker. For the difference of only about $50 I always replace the complete assembly. The most common one being about $150 complete, # 2198597 and this should be the one for your fridge since you mentioned the optic component's. Hope that help's. Thanks for choosing "fixya" for your fridge inquiry. Please take a moment and rate this solution if indeed it solves your problem. Thanks again and good luck. Macmarkus :)
Posted on Mar 23, 2010
Tip
Do it Yourself: Reprogramming the Remote Keyless Entry (RKE)
Normal 0 21 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tabla normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Jeep Grand Cherokee Alarm System (1993-1998)
I would try reprogramming the Remote Keyless Entry (RKE) transmitters before looking for anything else. Make sure the batteries in the RKE transmitters are good and replace them if in doubt. Here's the procedure for programming the RKE transmitters.
Up to 4 Transmitter Identification Codes (TIC's) can be programmed into the receiver at any given time.
1. Open the driver's door of the vehicle. Leave it open through the programming procedure.
2. Move the mechanical door lock lever to the LOCK position.
3. Insert the ignition key and turn it to the RUN position.
4. Turn the ignition to the RUN position. Within 20 seconds, aim a transmitter at the receiver dome and press the lock button, for at least 5 seconds. Once the receiver accepts the programming code the driver's door will unlock.
5. Once the first transmitter has been programmed, additional transmitters (up to 4) may be programmed into the receiver. Within 20 seconds of the previous transmitter programming, move the mechanical door lock lever to the Lock position. Aim another transmitter at the receiver dome and press the LOCK button for at least 5 seconds. The door lock will cycle again.
6. To lock the programmed codes into the receiver, the ignition must be turned off and back on within 20 seconds after programming the last transmitter's code. At that time, all previous codes are erased from the module.
If the alarm still doesn't work correctly, you probably have a bad Alarm Module. If you wanna download this procedure, clic the image.
Enjoy Jeep.
on Sep 23, 2009 | 1993 Jeep Grand Cherokee
Red light inside the freezer part stay on for my side by side Kenmore refrigerator
Hello William;
My name is Peter. I am a retired field service refrigeration technician.
The, 'Red' light is a infra red light. This light assembly on the right hand side of your freezer is the transmitter.
Directly across is the receiver. On the receiver is a spring loaded plastic flapper.
This is a safety device for your ice maker. When the freezer door is closed, the flapper is closed, allowing the infra red transmitter to complete the signal to the receiver. This allows the ice maker to discharge ice cubes. When the door is open the signal is broken, the flapper springs out blocking the circuit signal, and the ice maker will not discharge ice cubes.
There is a On/Off switch on the red transmitter. I do not know why you would want to turn it off. If you turn it off and the transmitter stays on then you have to replace both the transmitter and receiver.
Nov 11, 2014 | Kenmore Refrigerators
Can a the transmitter and receiver be replaced by wall control for a Hunter fan model 28425?
The part # you need is 85662-01-000. Maybe you can find it somewhere in cyberspace.
Aug 01, 2014 | Hunter 52" Ceiling Fan With Light And...
1997 jeep will not start thinking its the anti theft lock but dont not how to reset the code ... does anyone know how
Click here also; http://www.scribd.com/doc/20110658/Keyless-Entry-System-Jeep-Grand-Cherokee
Oct 05, 2010 | 1997 Jeep Cherokee
Ice maker stop making ice red light flashing inside freezer water dispenser still works kitchenaid kscs25
the emitter/receiver has gone bad and will need to be changed out. the part number is 4389102 at about 130.00
Feb 28, 2010 | KitchenAid Superba Architect KSCS25INSS...
Kenmore refrig/freezer. freezer side is cold,
Check your condenser coil (should be below the refrig.). If dirty, you can clean it with a condenser brush from Home Depot or Lowe's. Turn the appliance off while cleaning. Be careful not to damage the refrigerant tubing (copper). If this doesn't solve the problem, then there may be an issue with the defrost thermostat, defrost heater(s) or the main temperature control assembly.
Contact an appliance service company.
Feb 17, 2010 | Kenmore Refrigerators
I dont know if it is the receiver or may be the transmitter, but i can see modulation on the transmitter but the receiver keep saying "NOTONE" can you help with this
H,
You can check on your receiver if there's a RF signal.
If so, check the gain setting on the transmitter.
And check also the gain setting on your receiver.
Thats all I can advise on this distance.
Regards,
Gerard
Feb 01, 2010 | Sony (UWP-S1) Professional Microphone
SL2 Receiver does not light up/rear speakers do not work
reveres the poleley
if it uses led s and wires are backwords no go
Nov 24, 2008 | Bose SL2 (17817393904) Wireless Adapter
No sound transmitting from Soundstation EX wireless mic # 2201-00699-002
confirm that you select aux input in your soundstation2.-if your problem excit change audio cord between receiver output and the aux.
Oct 17, 2007 | Polycom SoundStation EX (expandable)...
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
821 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
