Question about ASUS P5GD1-VM Motherboard
Cd problem i have a cd rom and a dvd rom on my computer. they have both stopped working. in the bios there is primary, third and fourth, but no second. can any help please?
  • arnaldodiaz2 Jul 18, 2008
    well, i have three dvd rom, two serial IDE, and one serial ATA, but the ATA is not appear in the pc.
Cine are cd pentru placa de baza p5gd1-vm pls
Posted on May 12, 2008
I needed to change the hard disk of my computer. I installed the hard disk and tried to install the operating system which I have been using viz. windows XP pro. I inserted the operating system cd in the...
Hi
first go to the BIOS and check your Hard Disk is detected or not if it is detected then go to the boot section on your BIOS and set CD Room as a first boot device and HDD as a second...
or if your hard disk is not shown in the bios then check your hard disk reconnect power on you hard
disk.. and most important thing don't forget to check jumper setting of you hard disk...
ifyou find this is helpful for you so please rate me this will encourage me to domore free work..
regards
sandy
Sep 06, 2011 | Computers & Internet
How to reboot a XP4 computer
1 first insert the windows cd in cd/dvd rom 2 chek in the bios if the first boot device is the cd/dvd rom 3 vhen it boots it will say press any key to boot from cd 4 after loading all the data you must format drive C 5 after formating it will restart instaling windows you must insert the windows cd key thats all
May 16, 2011 | Microsoft Windows XP Professional
I have sata dvd writer.when i connect it my computer does not boot.does intel D102ggc2 supports sata dvd writer?
You're Intel motherboard does support up to 4 SATA hard disk drives including SATA CD-ROM / DVD-ROM drive, reader/writers. This MB also includes two serial ATA IDE ports.
The most likely reason you're system is not booting is because all SATA ports are all seen as Master drives. By connecting the SATA DVD-ROM drive the bios auto configured the SATA ports.
You'll need to enter the bios when you're system boots-up. Press the F2 key on you're keyboard right after hearing a single beep. You will than enter the bios main menu. Listed at the main menu are devices connect to the motherboard. (Instruction on how to move around in the bios is listed at the bottom of the screen). Mainly, the hard disk drive or (drives) and the SATA DVD writer. You'll need to open the Boot tab. Look for boot order. You want the boot order set like so;
First boot device: [Floppy disk] drive; if one is connected.
Second Boot device: [Primary Hard Disk] drive.
(The drive with windows installed on it). (This drive may be ATA IDE or SATA; you did not provide that information).
Third Boot device: [DVD-Rom] drive. Save and exit the bios. The system will auto restart.
You're windows operating system should load correctly after the auto re-start.
The SATA data cable and the SATA power cable should be checked for good connection. It only takes a little bump to make either loose.
Here is the link to Intel for you're motherboard;
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22+D102GGC2+%22
Mike
May 12, 2010 | Intel D102GGC2 Motherboard
When i choose somewhere:
Hi there, This issue may occur if you accidentaly replaced the Msvcrt.dll file with a third-party version that does not contain the _resetstkoflw (recovery from stack overflow) function. inorder to resolved this issue please follow step by step procedure below.
  1. Insert your Windows XP CD-ROM into the computer's CD-ROM drive or DVD-ROM drive, and then restart your computer from the CD-ROM.
    NOTE: Some computers may require that you modify the basic input/output system (BIOS) settings before you can start the computer from a CD-ROM. For information about how to modify BIOS, see your computer documentation.
  2. At the Welcome to Setup screen, press R to start the Recovery Console.
  3. Press the number key that corresponds to the installation that you want to repair, and then press ENTER.
  4. Type the Administrator password, and then press ENTER.
  5. With the Windows XP CD-ROM still in the CD-ROM drive or DVD-ROM drive, type the following commands, pressing ENTER after each command:
    • cd system32
    • ren msvcrt.dll msvcrt.old
    • CD-ROM_or_DVD-ROM_Drive_Letter:
    • cd \i386
    • expand msvcrt.dl_ BootDriveLetter:\windows\system32
    • exit
    NOTE: BootDriveLetter refers to the drive letter of the boot drive. In other words, it refers to the drive where the Windows folder is located, which is probably drive C. CD-ROM_or_DVD-ROM_Drive_Letter refers to the drive letter of the CD-ROM or the drive letter of the DVD-ROM drive. The CD-ROM drive or the DVD-ROM drive are frequently located in drive D.
Hope this resolved the issue. Thanks!
Apr 06, 2010 | Microsoft Windows XP Professional
Dell Dimension 8300 - Can't Boot from XP Disk
When in doubt do without, that is remove the new hard drive cable and power, remove the DVD drive and try loading booting the XP from just this CD device. Enter the BIOS and check if the system sees the device. If it's not found in the BIOS then you'll never boot anything. Address it as the Primary device on the cable (I don't use CS) and see if the BIOS sees it.
If you get CD device seen in the BIOS then try to boot the CD in it. If it boots then power off and connect up your 40gb drive (optioned as Primary) on the other cable. Now power on as check the BIOS for the drive and the DVD device. If both are seen then boot the cd and try to load XP. After it's up and running install the other CD device as a Slave on one of the cables.
May 28, 2009 | Dell Dimension 8300 PC Desktop
Cannot boot windows xp
Test the CMOS BATTERY..TO MAKE SURE ITS GOOD IF NOT REPLACE.If it test good leave out for 5-10 minutes replace.motherboard bios should now beat default settings.reenter the bios.move cd to first boot.save changes.if you do not save changes it will not work.place.computer should now boot from disk.
Was this solution helpful? Show your Appreciation by rating it..RICHARDM69
Dec 14, 2008 | EliteGroup P4M800-M7 Motherboard
Problem in reinstallins operating system
This can be started by changing the boot order of your system.
To do so, start up the laptop from a shutdown stance.
This part requires some speed, it will either require the "F2", or "F10" in most cases. IIts not 100% guarantee that this will be the two buttons required for activation of your bios.
WARNING: BE VERY CAREFUL IN THE BIOS. YOU CAN FOUL YOUR COMPUTER VERY EASILY BY CHANGING THE WRONG SETTINGS IN THE BIOS.
When you enter the bios, try to find the boot settings. And make sure your cd-rom is selected as the primary boot device.
After you change the cd-rom as the primary device, Save and Exit from the bios and your computer will automatically restart.
Make sure the O.S. (Operating System) CD is in the CD-ROM and it should automatically boot from the cd-rom, it may come up with options, your options should await you when or if the auto boot from cd works.
Hope this helps.
Oct 22, 2008 | Computers & Internet
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
ASUS P5GD1-VM Motherboard Logo
76 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
