Question about Dell (E210882) Motherboard
Intel E210882 Motherboard can't ON
Intel E210882 Motherboard can't start when I press power SW
    President:
  • 739 Answers
> Check the power connection to your computer in good condition.
> Remove the SW on the motherboard connection and switch on the computer by using the SW pin tespen to affect positively and negatively. (To make sure the button on / off function)
If your computer can be turned on this means that the button on / off there is a problem but if the contrary, create a test on your computer power supply box in a manner which was troubleshooting with the power supply box which is still functioning properly or even better one.(Problems on the motherboard can also cause your computer can not be turned on)
If you have to do some tests and the problem is not coming from your motherboard, I believe there is no problem for your computer is switched on and used as usual.
Posted on Jul 23, 2010
  • HTS Sri Aman
    HTS Sri Aman Jul 24, 2010
    Hopefully this can help...
    thanks... please votes
  • Paul Lincoln Mar 01, 2011
    I have a gateway hear that has the power button problem. I found that the button has a polarity that has to be followed. Try turning the button lead 180 degress and see if this helps. Took awhile but it fixed my problem.
I lost my lan driver
The Dell E210882 motherboard has been used in the Dell Dimension 3000. Thus you can try the Dell site for the XP driver. Start here: http://www.dell.com/support/drivers/us/en/04/Product/dimension-3000 and expand the section for network drivers.
If you have a different OS, try the Intel site since the onboard LAN is the Intel Pro/100 VE hardware. The Intel generic drivers are here: http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Network+Connectivity&ProductLine=Intel%C2%AE+Desktop+Adapters&ProductProduct=Intel%C2%AE+PRO%2f100+VE+Desktop+Adapter . Use the drop-down menus to select your OS and drivers if you want to shrink the list below (left-hand side).
If the on-board LAN has failed (it happens), get a PCI ethernet card. Then disable the on-board LAN in the BIOS. Usually that can be accessed by pressing Esc, F1, F2 or F10 on startup. There should be a splash screen telling you which key to press. If you get to the Windows login or Start Screen try again.
I hope this helps.
Jan 10, 2013 | Dell (E210882) Motherboard
I have Intel E210882 motherboard.Which is the chipset?
http://www.amazon.com/Intel-Desktop-Board-D845PEBT2-E210882/dp/B009B5L0OA/ref=sr_1_3?ie=UTF8&qid=1353781789&sr=8-3&keywords=intel+e210882
http://www.intel.com/support/motherboards/desktop/d845pebt2/sb/cs-012740.htm
Click on Product Specification (PDF)
Product Guide (PDF)
http://downloadmirror.intel.com/15337/eng/D845PEBT2_ProductGuide_English01.pdf
The motherboard chipset is an Intel 845PE.
Intel part number - Intel 82845PE - on Northbridge chip;
Intel part number - Intel 82801DB on the Southbridge chip,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Pentium_4_chipsets
The Northbridge chip is under the tall aluminum finned Heatsink, that sits between the processor socket, and the bottom of the motherboard.
The Southbridge chip, Intel 82801DB, sits down towards the bottom of the motherboard.
For additional questions please deposit $30,000 in unmarked bills......................OH, I'M JUST KIDDING!
Post in a Comment.
Regards,
joecoolvette
Nov 24, 2012 | Intel Motherboard
I need to know how much main memory that supports my motherboard.
According to Intel:
(DIMM) sockets
• 800/667 MHz single or dual channel DDR2 SDRAM interface
• Support for up to 8 GB of system memory
Nov 10, 2012 | Intel Gateway E210882 Motherboard With...
I have a t3985 emachine that won't power up. I've opened the case and vacuumed it, took the power supply out vacuumed it. Plug in shows green led on motherboard. i'm wondering if it is the pwr sw. i...
If you carefully take a screw driver and short the two power switch pins together it should start. Did it work before you cleaned it? On the connector itself it should say power sw.
Apr 07, 2010 | Dell (E210882) Motherboard
I need the drivers for the E210882 N232 motherboard please
my board is intel e210882.i'm not get driver cd.how to intall lan,sound&vga
Mar 29, 2010 | Intel Motherboard
I need intel e210882 motherboard drivers
Intel e210882 motherboard drivers can be found at driverupdate us.Take a look, and enjoy
Dec 13, 2009 | Dell (E210882) Motherboard
Dell optiplex gx260 motherboard reset
the front panel header configuration of that particular motherboard.
4e233df.jpg 6-8 (red) is your power sw
2-4 (green) is your power LED
1-3 (yellow) is your HDD LED
5-7 (purple) is your reset sw
black is not connected
The motherboard should go into a custom case no problem.
Oct 21, 2009 | Dell (E210882) Motherboard
Sound driver of intel E210882 motherboard
Hi rukan
intel e210882 motherboard drivers can be found at
driverupdate us .
It will take 2 mins from you to install...
I hope I have helped you...
enjoy
Apr 08, 2009 | Intel Motherboard
Wires connection
the display some time come and some time not come
Jan 30, 2009 | Intel D845GVSR Motherboard
Dell (E210882) Motherboard Logo
1,302 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
