SOURCE: Rainbow aqua mate II instructions
You have the vacuum and the basin, you put them together just like when you vacuum but don't put water in the basin. There is a large white container that comes with the shampooer. you fill that up with water and then you place the vacuum cleaner and the basin on top of that. Now you will need the water hose (not the one that has the gas pump hadle). Hook that in the same spot that you do for vacuuming. Then you take the shampooing handle( it will have a trigger and a little white bottle and some tubes hooked to it) the one end of it hooks to the water hose and the other end hooks to the wands. There are 2 wands that come with your shampooer. At the end of those the shampooer head will be attached. There are two separate tubes there is a thick tube ( there two tubes fused together) and a thin tube, they hook to the large white container that you fill with water. Just look and you will see where they go. Then there is a tube that hooks to the shampooer head at the bottom. The you take the little bottle and fill it with your shampoo. You should have gotten some clips to hool onto your hose so that you can keep the tubes attached to it so they aren't in the way. You should be set. I hope I helped.
SOURCE: Tefal Pro Express iron.
Put
50/50 mix of water and vinegar in your iron, let it run, after a while
start pressing the steam button, you may have to do this a few times,
but it will eventually stop the light flashing, then the steam function
will return to normal. You'll need to clean the iron out a few times afterward
Green light means steam ready.Still problem persist then the control unit has to be repaired.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
SOURCE: POWERFULL TEFAL PRO EXPRESS 2911
strait vinager fill it to full let sit over night then empty
SOURCE: often when ironing, the iron{tefal
Try using CLR cleaner, if not just buy a new one, and keep the receipt for a return down the road, these iron's are reasonable nowadays.
