Question about JVC AM FM CD DET FACE CAR STEREO
JVC KD-R610 is stuck in Protect mode
I have a KD-R610 and the screen keeps flashing protect mode. I am wondering how I an get it off of protect mode because I don't know what the problem is. Have tried checking the cords and reset the system but nothing works.
  • Anonymous Mar 19, 2014
    Protect mode is on. How do I take it off and have my radio work again?
    Protect mode is on. How do I turn off protect mode, so the radio will work?
Try disconnecting your battery, reconnecting it, and resetting your stereo. If that doesn't work, the constant power (yellow wire) or ignition wire (red wire) may have come in contact with ground or isn't properly connected. Make sure everything is connected properly and try resetting your stereo. If it is still flashing "protect", the unit needs servicing Contact JVC Customer Care Center at: 800-252-5722.
Posted on Feb 07, 2011
    New Friend:
I had the same problem... There is a little reset button when the faceplate is off. I pushed it and it started working once I put the faceplate back on
Posted on Jun 12, 2014
  • Grant Armantrout
    Grant Armantrout Jun 12, 2014
Upgrading the R610
It should fit, the R610 is SSI EEB v3.0 footprint (12" x 13"), while the Micro X6DVL-EG2 is 12" length x 10" width, so you should have no problem fitting the motherboard in that case.
Jan 07, 2014 | Fujitsu Siemens Celsius R610 PC Desktop
I can not get my jvc kd-r610 on fm radio. lost the manual. help
You can download the manual from the manufacturer's web site at
http://books.jvc.com/booklist.asp?Model=kd-r610
Aug 20, 2011 | JVC AM FM CD DET FACE CAR STEREO
My jvc kd-r610 car receiver is not playing or anything. I blinks "protect"
JVC head units go into protect mode usually when there is a short circuit on one of the speaker wires. Sometimes this is just caused by moisture in the doors or wherever the speakers are located. The first thing to do would be to reset the unit and see if it fixes the problem. To reset the unit there is a small button behind the faceplate which you will need to push in with a pen or other sharp object. Hold this button in for a few seconds. This will reset the head unit to factory settings which does mean that you will lose all of your saved radio stations, audio settings, color settings etc. If this does not work then one of your speaker wires is probably damaged. To find out which one unplug all of the speakers, reset the unit and plug them back in one at a time. When the unit goes into protect again you have found which speaker is causing the issue. Cheers, Dan
Apr 28, 2011 | JVC AM FM CD DET FACE CAR STEREO
KD-R416 jvc deck. my deck is showing protect on the screen heellllpppp hahaha
protect mode means that you have a short either in the power supply or in the speaker leads themselves somewhere down the line.
Dec 11, 2010 | Car Audio & Video
After instal of JVC KD-R610, the words 'protect' flashes, and I'm not sure what i've done wrong. Wires match, connections are good, i tried the rest...???
this usually happens when there is a short in the speaker wiring (wires crossed) or when you have too many speakers hooked up. rule out these factors.
Aug 05, 2010 | Car Audio & Video
I believe i may have gotten some water in my JVC car stereo KD-R610, and I am wondering if there may be a way to save it? Is there a special or correct way to reset it. The radio comes on but says PROTECT....
If you have not put on the set after the water logging then you could have been saved. Now there is a chance that the processor section have shorted circuit. please open the set, use a hair dryer and warm up to clear up all the moisture. use petrol to clean the main board do not put any petrol on the main panel or plastic.but only the PCB. after cleaning heat again till you have warrmed up and cleared all moisture. reconnect the set and test. I hope this must clear your fault or else you will be having faulty componentts that needs further continuity and voltag checks for finalising. hope my advice helps. good day
Jul 05, 2010 | JVC KD-PDR30 Car CD/ MP3 Player
Wired and Installed a jvc KD-R610 deck in my 95 mustang and deck will not turn on
You should verify your wiring .Also check all fuses. that is on the radio and for the power wire (red) .
May 12, 2010 | Car Audio & Video
New TV 9 mos old, Won't stay on after power up? Remote or manual turn on, set keeps turning off after 1-2 second green on and brief screen flash.
I would try leaving the TV unplugged for 30mins so the TV can reset itself.
If that doesn't work, your TV should still be under warranty. I know 95% of come with a 1 year warranty.
The most common problem with Sylvania TVs made by FUNAI, the Backlight Inverter board fails to early in life. ( That's the part that powers the screen)
The Tv can't power up the screen and it turns off automatically. Basically called "Protection Mode" so it protects the other parts inside the TV.
Jun 01, 2009 | Sylvania LC320SS8 32 in. LCD Television
JVC AM FM CD DET FACE CAR STEREO Logo
6,945 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
