Question about Sears Garden
How do i sharpen the blades on my craftsman 18inch model 315 bushwacker. they are moon like blades and a file won't work. Is there a toll for this
5 Suggested Answers
SOURCE: sharpen hedge trimmer blade??
My trick is to make sure that I always lube the blades after each session with a 3/4 engine oil + 1/4 kerosene mix - making sure that every tooth gets a drops or 2, then run it for a seconds to spread the oil & leave the blades overlapping. Doing this allows the blades to self sharpen I've found. 2 stroke oil , unmixed is about the perfect viscosity aswell.
Posted on Feb 18, 2010
wentlanv
  • 710 Answers
SOURCE: I have a craftsman 19''
Hi nod2,
Can you reply back if it's gas, electric, or cordless?
I'll see if I can hunt down anything.
Handie Andie
Posted on Jun 15, 2011
  • 5 Answers
SOURCE: I bought a Craftsman bushwacker,
I have similar one and I used a dremel tool with a 3/16 stone. You have the take it apart to get the tool inside the half moon blade. Not difficult, few screws.
Posted on Sep 05, 2010
  • 30 Answers
SOURCE: Craftsman Bushwacker hedge trimmer year 2007 19"
I have a stihlfs40 "old one" 4130 model that the owner of the broken clutch fs40 could buy for spares.
Posted on Sep 25, 2010
Ihave a craftsman ridding mower model #917.289900 new belt for the deck new blads it still leaves miss cut in the middle anybody know why?
usually if its missing cut it's not rotating fast enough, or the other thing it can be the blades have not been sharpened. some companies that make blades don't sharpen them so they can be handled, it will have a leading edge and you need a sharpening stone to put a cutting edge on the blade. and the blade has to be put in the right way round. flate top cutting edge bottom.
Jun 14, 2017 | Craftsman Garden
How do I take blades off to sharpen them?
raise the mower put a block on the rim of the deck so the blade does not turn remove the bolt on that holds the blade in place sharpen and replace in reverse order
May 27, 2017 | Craftsman Garden
HOW DO YOU SHARPPEN BLADES ON ELECTRIC HEDGE TRIMMER BUSHWACKER?
proper method is to use what is referred to as a "lapping table" professional sharpening shops have these , look in your yellow pages for scissor sharpening , but if your a skilled hand and have some time then a simple fine file will work as well , keep same angles on cutting edges ,approx. 30 degree angle
Jun 17, 2014 | Craftsman Bushwacker Bush/hedge Trimmer...
Blade on a Craftsman 20 in bushwacker electric hedge trimmer stuck on a vine and will not engage
with engine off ! use a pocket knife to whittle wood branch out of bar , do not yank it off the bush the blade will bend then will become stuck
Mar 10, 2013 | Craftsman 20 in. Hedge Trimmer
Its a 21hp 46'' cut craftsman yts 3000 riding mower
Richard:
Check your blades to see if they are balanced. They should sit level when you put them on an arbor, (something pointy that you can put in the hole in the blade that will not go all the way through the hole. If the blade is heavy on one side you can grind or file the heavy end of the blade (I sharpen the blades and the heavy side gets extra sharpening to remove the excess weight on that side). Also check the spindles that you bolt the blades to when you install the blades. make sure that there is no slop in the spindles... they must not wobble. If they wobble, you didn't keep them greased. You'll have to but new spindles... they're not hard to install.
Nov 11, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I bought a Craftsman bushwacker, electric at a garage sale. The blade has half moon shapes. Whats the best way of sharpening this?
Aug 24, 2010 | Garden
I wish to know if I can purchase new blades for my hedge trimmer model number 900.799740 . Can I replace blade with 22 inch or longer size? Can original blade be sharpened? What new model is compatable?
Go to www.partsdirect.com, this is sears website for parts. You should be able to find the part number for a new blade.
If the blade has bolts and nuts holding the blade together it can be sharpened. If it is riveted together, it can be but it is more work than what it is worth.
Sep 25, 2009 | Craftsman Garden
Duel blades on craftsman riding mower cut unevenly
check the front tire air pressures then for a bent blade
Jul 19, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Can i buy a new blade or can it be sharpened? it won't cut very good.
New blades are sold at both Home Depot and Lowes, and probably also at Sears.
To sharpen the blade use a wetsone to buff off any burrs and then a metal file to just touch up the edge. It won't need much work at all.
Jul 07, 2009 | Craftsman Garden
Garden Logo
958 people viewed this question
Top Sears Garden Experts
Tim Whalen
John M Grubb Sr
Matt Olenzek
Matt Olenzek
Are you a Sears Garden Expert? Answer questions, earn points and help others
