Question about Dryers
70 series kenmore dryer. runs no heat. element seems fine. how exactly do you check thermo fuse. gas dryer obviously
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. You are right when the dryer runs but won't heat then the first thing that should be checked is the Thermal fuse which is mounted to the exhaust duct inside the back cover. If this fuse goes bad the dryer will not heat and you’ll have to replace it as it cannot be repaired. You can test it for continuity between its two pins, no continuity means bad fuse. If this is fine then you’ll need to check the thermostat, igniter and coils. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 22, 2010
  • richb2424 Jul 23, 2010
    got continuity. so how do we test thermostat?
I have a Kenmore 70 series electric dryer that won't heat. I replaced the heating element (replaced it in September with thermal fuse and it fixed the problem then), but it still won't heat. I've tried...
check the wireling harness / clip. also that the two thermo switches are working.
after that it could be the actual main switch on the top of the machine.
Jan 09, 2018 | Kenmore 63942 Dryer
I have a kenmore 70 series dryer that will spin but won't heat! I changed the thermo fuses, but still have the same problem - no heat!
1)Try reseting your circuit breaker - all the way off then back on. 2)Check element for continuity or breaks in it.
Jan 13, 2011 | Kenmore 63942 Dryer
I have a 70 series kenmore dryer bought it from a used appliance guy cant find him now it worked find for a month now it doesnt heat up! been lookin online seems its most likely to be the thermo fuse or...
The thermo fuse will not cause your problem. If the fuse is bad it will cut the dryer off compleatly.
There are two limit switches on the heater can and the heating element. If you have an ohmmeter you can test for continuity across the element and the limit switches. If one of the limits is open replace both limit switches and if the element is oepn replace the element.
This page will help more http://www.appliance-repair-it.com/Whirlpool-dryer.html
If you don't know how to use an ohmmeter this page will help
http://www.appliance-repair-it.com/ohmmeter.html
Sep 24, 2010 | Kenmore 62602 Electric Dryer
My kenmore dryer series 70 is not heating, i replaced igniter, thermo sensor, and still does not heat....there is no glow from inside please help....
Check the fuse Note: Gas dryer thermofuse is linked to the gas assembly and blows whenever the temp exceeds 350f rapidly. Remove all air restrictions15f9d55.jpgbefore replacing that fuse or you will just need to keep buying em.f8e11bb.jpg65c991e.jpg
May 08, 2010 | Kenmore 62602 Electric Dryer
Dyer is not heating up.it turns on and runs but it just does not heat up i took off hose and clean . also looked in back of dyer by taking off clover to look for fuse please help .
Kenmore dryers have what we call a thermo fuse, usually on top on the burner area - I would check continuity on this unit and replace if nesessary.
If the thermo fuse is okay and dryer heats up with gas, check your igniter and/or gas unit coils.
If dryer heats up with electric elements check continuity at both element ends and/or high limit thermostat.
GOOD LUCK!
Sep 01, 2009 | Kenmore Dryers
Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Apr 06, 2009 | Kenmore 64742 Electric Dryer
Dryer timer is not working and won't heat but runs fine
check the ignitor. That's a very common cause for no heat in a gas dryer. other possibilities are the coils, or it could be that you have a bad fuse in the dryer.
Dec 26, 2008 | Kenmore 73952 Gas Dryer
Kenmore 70 Series Dryer Won't Heat
won't heat. fuse good,breaker good,heating element test ok. How do I check the thermostate, and timer.
Apr 29, 2008 | Kenmore 63942 Dryer
Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Mar 18, 2008 | Dryers
Dryers Logo
19 people viewed this question
Top Dryers Experts
