Question about Elna Heirloom Edition 6005
THE SEWING THREAD WILL NOT CATCH THE BOBBIN THREAD
I HAVE RE-WOUND AND RE-THREAD...EVERYTHING SEEMS TO BE WORKING FINE, BUT WHEN NEEDLE GOES DOWN TO CATCH THE BOBBIN THREAD, IT COMES BACK UP WITH NO THREAD
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 183 Answers
The needle is not catching the thread on the down stroke have you got enough thread out on the bobing for the needle to catch
Posted on Jul 28, 2010
Bernette deco 600 I have changed the needle, rethreaded the machine, new bobbin in and it is still not catching the bobbin thread to sew!
Do you have the bobbin in correctly? Clockwise or counterclockwise...
Is the needle in correctly? It could be backwards.
Rethread the bobbin if the thread is not wound on properly...too fast makes the thread too tight, too slow and it can wrap onto the bobbin in a haphazard way.
Check to be sure have the correct needle for your machine...matches stitch etc..
If your machine is electronic...turn it off so it goes back to any default settings.
seems like a lot, but one little thing...
Nov 24, 2016 | Sewing Machines
Won't catch bobbin thread
hi Shauna.
this is all i could find out from the internet.
Make sure the presser foot is up when seating the thread through the upper tension. Now, it's time to draw up your bobbin thread. Turn the hand wheel (TOWARDS YOU ONLY, never turn the hand wheel away from you) and hold the needle thread lightly. Tug on it as the needle goes down and then comes up again.
if this is off no help to you go to this link and see if its any good to you.
Frequently Asked Questions Singer Sewing
or this one.
Sewing Machines Won catch bobbin thread Google Search
Dec 13, 2017 | Sewing Machines
Why does my thread keep bunching up?
That is called "thread nesting," and several things can cause it. The upper thread enters the bobbin area during sewing, catches the bobbin thread, and as the needle goes up, pulls the stitch tight. Something is catching the upper thread as it goes around. The most common reasons are the bobbin or bobbin case (or both) is improperly inserted; the bobbin is warped (roll it down a flat surface--if it wobbles, it's warped), either the case or the bobbin is not seated evenly, there is a rough spot on the bobbin case that is catching the thread, or your bobbin is loosely/badly wound. You need to rule out the possibilities step by step until you find the cause. First, review your threading procedures from start to finish, using your user's manual. Then, without fabric, turn the hand wheel by hand (ALWAYS towards you) to see if you can see it start to catch. The top thread should rotate smoothly in the bobbin area. You should be able to pin-point the cause that way.
Sep 24, 2014 | Singer 2517 Mechanical Sewing Machine
Drawing up bobbin thread
Service Timing is NOT a home fix
Mar 16, 2014 | Elna Sewing Machines
Needle won't catch bottom bobbin thread
hi, you need to alter the timing, mostly related to the upstoke, as the needle returns, sadly i never worked on one of these however it sounds a classic timing issue...
Regards
Rob
www.electronicrepairs.co
Dec 30, 2013 | Michley Lil Sew Mechanical Sewing Machine
Singer sewing machine will not catch bobbin thread to sew
Check the bobbin tension and timing. Please top and bobbin using to new quality threads.
Dec 29, 2013 | Singer Sewing Machines
The top thread continues to break once I begin sewing. I have done all the recommended changes (tension controls, etc.) Everything is threaded correctly. It appears the top thread or the bobbin thread...
I know you've said you have checked the tensions but that usually is the problem. When you pull on the top thread after it goes through the tension but before you thread it through the needle is there some tension but not so much that it breaks when you gently pull on it? It will be a bit harder to pull it at the point after it goes through the needle but it should have a bit of give there too without breaking.
Also check the bobbin again. Take it out of the machine and examine how the thread is wound around the bobbin. Is it all criss crossed or is it fairly evenly wound? Is it in the right direction and through the tension slot? Now dangle it by the thread while in the bobbin case. It should not just reel out to the floor but should slip a bit with some tension and hang there. A slight **** of the wrist should cause it to release a bit more thread and drop a bit more to the floor. It should allow slip but it shouldn't just reel out fast.
When you reinsert the bobbin case into the machine you should feel/hear a slight click as it catches into place.
Also check the needle though that usually isn't what causes this kind of problem.
The thread will break when it has no 'give'. Either the tensions aren't quite right or it is catching somewhere along the way through the various guides where you thread it. Oh and make sure the spool itself is freely turning on the spindle! Sometimes it is because of catching at that point and simply turning the spool upside down so it can't catch will solve the problem ! :)
May 24, 2011 | Simplicity Pioneer II SA200 Mechanical...
Thread jams & wheel axel cannot turn
there are a couple of things that come to mind.
Bobbin:   wound with uneven tension.  Try taking the bobbin, rewind that thread onto another bobbin and wind slowly.  make sure the thread feeds onto the new bobbin evenly.
upper thread:  catching on something or not flowing off the spool easily.
you're doing well, sounds like you consulted the manual and used your noggin, hang in there and let me know if this doesn't help.  we can troubleshoot some more!
Jan 12, 2009 | Sewing Machines
Not picking up the Bobbin thread
Sounds like you have to take off the throat plate and clean out threads under it.  Sometime they ball up and prevent the needle from going down and catching the bobbin thread. You can't see themuntil you take off the plate.  Follow the directions.  It is easy.
Dec 28, 2008 | Baby Lock Ellure
Sewing Machines Logo
612 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
