Question about HP Officejet 4110 All-In-One InkJet Printer
Fax problem do not hear my fax dial the number has error 0xf0af8007
    Sergeant:
  • 352 Answers
Hi help, try updating your printer drivers:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done.
anaanymous
Posted on Oct 14, 2008
I place my paper that I want to fax in the fax machine,dial the number that I want to fax, push start, it scans the paper, I hear the fax tone and at the end I get a Beep Beep Beep and the report sending...
1) did you dial correctly?
2) are you in an office or in your own home?
a) if you are in an office, you may have to dial a 9 or someother number to dial out before you can type in your original fax number.
b) if you are in your home, then its a number of things: Fax machine not connected with phone lines properly is one big supect. Check your phone cables to make sure that the fax machine is properly connected.
Mar 05, 2010 | HP 1040 Plain Paper Inkjet Fax
None of our faxes are going out and we receive error number 87
set the fax so you can hear dial tone... if no dial tone then check the fax line.... if fax line plugged in... plug it out of the fax and plug into a phone... if still no dial tone then change fax cable... if dial tone... then call your cell... if static... fax wont work call phone company... if you get a funny signal call phone company...
Dec 10, 2009 | Office Equipment & Supplies
Status 50 on a fax estudio 45
the number is busy. Try pressing the monitor button and listening for a dial tone. No dial tone means your phone line is not working. If you have dial tone, dial the number you wish to fax and listen to see if it picks up. If you get a busy signal, or hear someone answer, that is why it's not working. If you hear the fax tones, press start and send your document. This is a way to fax that allows you to hear the whole process.
Aug 10, 2009 | Toshiba E-STUDIO 450 Copier
Cant send a fax
Confirm dialing the correct fax number?
Any 0s to get an outside line, any special area codes?
What happens when you try to send a fax, can you hear a dial tone? can you hear the fax ringing? can you hear a response from the recipiant?
Jul 17, 2009 | Lexmark F4270 Plain Paper Inkjet Fax
I am unable to send fax, I get a 'phone line error' message. The phone line is fine, I checked it by pluging a seperate phone into it. When I go to 'On Hook Dial' I do not get a dial tone on the fax...
Please check the dial tone by following the instructions given below:
1. Press "Fax Mode."
2. Press "Menu."
3. Press "Up Arrow" or "Down Arrow" repeatedly until On Hook dial is highlighted.
4. Press "Select" twice.
You can now hear the dial tone of the telephone line.
5. Enter the number to which you want to send a fax.
Note: Press the keypad numbers to use an automated answering system.
6. Press "Start Black."
Mar 29, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
Sending a fax
First make sure that the fax button has been pushed and is llit...
The 2820 should have a handset. In order to use manual transmission (when you get to hear all the beeps and whistles) you will need to load the document then pick up the handset. then dial the number, when you hear the recieving fax tone then hit the start button.
The 2820 should also have a hook hold button pressing this will allow you to hear the dial tone and the numbers you dial along with the receiving fax tone. If you dont hear anything when you press this button then you may want to use the volume buttons to increase the volume.
Also remember that if you have not picked up the handset or pressed he hook/hold button the unit will use automatic mode, which is to say that all you will do is load the document, dial the number, and then press the start button.
May 19, 2008 | Brother IntelliFax-2820 Laser Fax
Faxing
you could try pressing the on hook dial button once you have a dial tone dial the fax number you are trying to reach and then you will be able to hear f there is a fax tone form the other machine or a error message from your operator. If there is a series of beeps with the document in the feeder press send.
The most common cause of not sending is ECM (Error Correction Mode) press menu and within TTI settings make sure this is turned off.
Hope this helps you
Thanks J
Jul 26, 2006 | Brother IntelliFAX 560 Plain Paper Fax
HP Officejet 4110 All-In-One InkJet Printer Logo
82 people viewed this question
Seeker5211
Seeker5211
