Question about Poulan WeedEater Hedge Trimmer 25cc Engine
Featherlite SST 25 Gas Trimmer
This trimmer is in bad shape the gas tank was all gummed up and the primer was so bad it crack. so I replace the primer bulb and a new gas tank on it. now this runs but only in the choke mode, as soon as I put it on run it dies? I have no servis manual for it so I dont know what to do next?
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 10 Answers
Clean the carburetor and replace the spark plug and air filter. Also make sure the oil/ fuel ratio is correct.
Posted on Feb 10, 2018
evwood
  • 50 Answers
SOURCE: poulan 32 cc string trimmer mod.# ppb100
After you have done all the suggestions #1 gave you, make sure the tubings are good. They deteriorate over time. Also be sure to check the spark arrestor. This is part of the muffler. Good luck
Posted on Nov 16, 2008
  • 246 Answers
SOURCE: Poulan 17'' Gas Weedeater keeps dying!
Hello su2yak2:
From your Description it Sounds like the Exhaust Port or Muffler is Restricted with Carbon Deposits, the Carburetor Metering Pump Actuator Gap is Incorrect.
>>The Following is a Basic Instruction File for Doing a Diagnostic on the Engine for this Problem. Any Input is Appreciated.
>>**Remove the Muffler and Make Sure the Exhaust Port is Clear.
>>If it is, then Try to Start the engine with the Muffler Off.
>>If it Starts and Runs Properly, then Clean the Spark Arrestor Screen in the Muffler or Replace the Muffler if Required.
Is the Fuel Line from the Fuel Filter Staying Full of Fuel?
The Carburetor Metering Jet Actuator is Set so the Pump Diaphram Dowl is Just Touching the Actuator Arm. These Components are Located Under the Cover with 4 Small Screws Holdong it to the Carburetor Body.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
#1 Taper
  • 1041 Answers
SOURCE: poulan trimmer , will not stay running ?
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.) Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Posted on Jun 21, 2009
  • 41 Answers
SOURCE: gas won't pump through the hedge trimmer
carb may need to be rebult. sounds like a bad diafram hope this helps
Posted on Jul 11, 2009
  • 3 Answers
SOURCE: trimmer starts but the spool wont turn anymore
you're trimmer could have one of two problems, One, if it has a clutch on the engine,( the way you would tell is if it doesn't spin when it idles. it has a clutch) Two, your trimmer would spin all the time, they use round flexable cables stamped square on both ends, which fit into square sockets one at the engine one at the trimmer head, so you're problem is either a worn out clutch, or, the cable is broken, or, one maybe both sockets have become rounded out. I hope this helps you out. Bob
Posted on Aug 01, 2010
I have a craftsman quantum. Weed trimmer and won't prime gas to the carb, what do I look for?
fuel in the tank, cracked hoses to the primer , primer bulb cracked, primer valves affected by rubbish, grass or failed
May 22, 2016 | Craftsman Garden
Trimmer dies
If the bulb is cracked or gummed up inside it maybe starving the trimmer for gas. You stated you rebuilt the carb I was just wondering did you adjust it after the rebuild also did you put the same size needle jet back into it. In addition, did you change the screen for the jet they get gummed up and the screen will fill with residue most times.
May 11, 2017 | Poulan Garden
Troybilt trimmer primer bulb collapses. it will start occasionally but will only run a few minutes.i have replaced the primer bulb and gas lines and still have the same problems.
it should have a small vent in the fule tank cap if its blocked the primer bulb will be sucked in as the fule pump can **** any fule from the tank
check the tank cap first,,,,,
Aug 08, 2010 | Troy Bilt Tb70ss Gas Trimmer
I have a ryobi lawn and garden trimmer. SS26 (i t...
The fuel filter in the tank could be plugged, a fuel line gone bad, or the primer bulb has cracked, gotten hard, or otherwise rendered useless. It's possible that the lower chamber diaphragm in the carburetor is bad--hardened or cracked. The primer is supposed to pull fuel from the filter in the tank, into and through the carburetor, then out to the primer bulb, then back into the tank through another line. Go to: http://www.drystacked.com for a 12 page article on Walbro brand carburetors--very helpful. Hope this helps!
May 20, 2010 | Garden
Featherlite FL 20 fuel line assembly
1 from filter in tank to carby 2 out of carby to primer 3 from primer back to tank
Jul 06, 2009 | Garden
Primer bulb doesn't pump gas
Does the primer bulb pop back out or does it come out slowly? Is the inline hose in good shape or has a crack where it can **** air in? Did you check to see if the diaphgram in the carb is pliable or is it paper-like and needs replaced. Or your carb could be stopped up.
Only one problem..I can't think of any weedtrimmer that has an inline fuel filter. They are usually located in the gas tank.
Jun 24, 2009 | Troy Bilt Tb70ss Gas Trimmer
Primer bulb does not fill with gas
Check the primer bulb for cracks,it will not pump gas if it is torn or cracked. Then check line from bulb to gas tank to see if there connected or are broken.
Jun 17, 2009 | Homelite Mighty Lite Lawn Trimmer
Craftsman trimmer won't prime
A new carburetor would be simplest solution. You could try disassembling the carb, cleaning and replacing diaphrams, but just replacing the carb would be my choice. What is the model # on the trimmer and I can tell you the part # of the carb you need.
May 24, 2009 | Craftsman 25cc Gas Line Trimmer
Mightylite 26cs Gas Trimmer
sounds to me like dirt in gas tank dirty or plugged filter screen on fuel line inside gas tank or plugged pinched or obstucted fuel line . also check for the following pin hole in primer bulb bad spark plug dirty or rusty coil or flywheel magnet.or simply dirty or missadjusted carb if i can be of further assistance let me know i would start with the fuel hoses and make sure they are in good shape first ...do the easiest and cheapest things first good luck hope this gets you up and running good mrdmburns@cableone,net
May 01, 2009 | Homelite Mighty Lite Lawn Trimmer
Featherlite trimmer primer bulb
Hi
Check the hoses from primer bulb to the carb.
best regards savumihai71
Dec 09, 2008 | Poulan Featherlite Gas Blower, with Low...
Poulan WeedEater Hedge Trimmer 25cc Engine Logo
238 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
roeb
Jay Finke
Jay Finke
Are you a Poulan Garden Expert? Answer questions, earn points and help others
