My washer stoped aggitating everything else does what its supposed to do ? what can my prob be ?
my hotpoint vbsr2060 top load washer doesn't agitate but a very little. I can assist it with my hand to turn its full range of motion. I've checked everything above the trans. shaft bolt, bell gears etc above are fine.
    Genius:
  • 1,073 Answers
Replace the transmission
Posted on Apr 23, 2008
Won't aggitate but will spin
the lid switch could cause this problem as well as the timer.i do not think you need to replaced the agitater at this time
Sep 16, 2009 | GE WDSR2080D Top Load Washer
My kenmore clothes washer won't empty water
some models reverse the moter to activate the pump .. some have a solonoid to engage the pump .. depends on what model you have ... if the motor runs but still it doesnt pump then look for a broken belt that drives the pump .. on some there is a little universal joint that sometimes breaks .. often the pump becomes clogged with coins and other debree .. you didnt say if the spin cycle started or not .. if it doesnt then you could have a bad door switch .. if that doesnt operate then the spin cycle wont start and it wont drain as well .. you can test for clogs by taking the drain hose out and placing it on the floor .. if a lot of water comes out then its not clogged .. if no water comes out then you have a clog .. (be prepaired for lots of water) .. even if water comes out there still could be a coin stoping rotation of the pump .. there is no reset on the pump, it is almost always run by the main motor ..
Sep 12, 2009 | Kenmore Washing Machines
Will not agitate 110 92587210 Kenmore Washer
I have 2 words for you: "dog ears".
the dog aggitation ears are what cause the aggitator to aggitate. Those things wear down and not grab after time.
Pretty easy to change out. You just need to pull the aggitator out and change the 4 little plastic ears. Good luck :)
Jul 13, 2009 | Kenmore 24032\24036 Top Load Washer
Washer will not spin. Does everything else.
If it aggitates, then the tranny and motor coupling is ok. the drive assembly is bad. nintey perent of the no spin problems is motor coupling problem. But since yours will aggitate, then the coupling is fine.
Jul 12, 2009 | Whirlpool Inglis IP4400 Washer
Washer will not aggitate all other functions work fine
Sounds like you need a set of dogs...(dog agits)...
Pop the top off the agitator and remove the bolt. Pull the agitator top off and inspect the dogs...(small tear drop shaped pieces of nylon)...
Sounds like the dogs lost their bite aka teeth.
Apr 11, 2009 | Washing Machines
Fisher & Paykel WA37T26G Washer
I have one and they are right. Both the drum and the agitator turn so that the clothes are not beaten up.
Also the electronic motor control is fully variable speed. It will go as slow as! Dial up for wollens and it almost massages them. The cycle time is 1/3rd of a front loader.
Jul 20, 2008 | Fisher and Paykel IWL12 Top Load Washer
Agitator stopped moving back and forth
dismantle the agitator and see if the shaft of the gearbox is moving.its either the gearbox or the agitator
Feb 23, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Loud screaming sound during spin cycle
The screaming noise is probably from a dry bearing in the motor, it will probably come and go and shouldnt cause to much problem, they are supposed to be self lubricating but sometime they run dry.
Oct 18, 2007 | GE Spacemaker WSLP1100D Top Load Washer
Washing Machines Logo
176 people viewed this question
Top Washing Machines Experts
