Question about Fisher and Paykel GWL11 Top Load Washer
Drain hose has a constant drip with the washer empty.
Machine runs through its cycle normally but the drain hose drips forever.
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Now does the drain hose drip water when it is washing or when it is filling or all the time?Problem could be a stuck diverter.This component recirculates the wash water .Please look under the machine to the front right.You should see a red or black fan, this is your pump.On the black pipe which is the drain hose you should see a small component with 2 wires to it,this is the diverter.Please reply to confirm the style of pump and diverter and I can guide you throe the next stage of testing for this fault.Looking forward to your reply.
Posted on Jul 22, 2010
Kenmore series 80 washer do not drain enough
It's normal to hear some water in tub, it isn't normal for the rubber wheel to be hard to turn, you need to replace the pump, they are much cheaper on ebay
If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_2094e122cc46f24c
Sep 27, 2017 | Kenmore Washing Machines
This unit flows continuously thru the drain line that returns to the waste drain is this normal
What's causing this refrigerator problem? [Archive] - Straight ...
boards.straightdope.com > ... > Main > General Questions
Mar 16, 2012 - 32 posts - ‎16 authors
The drain line should come out of the unit some where and empty into a .... water generally goes down the back wall of the fridge and through a ...
How To Repair A Freezer Dripping Water Into Refrigerator ...
removeandreplace.com/.../freezer-drain-frozen-water-dripping-into-refri...
May 27, 2015 - The freezer drain hole and drain line in the bottom of my freezer keeps icing up. ... is to simply run hot water through the drain line to allow water to flow. ..... Divert Water Dripping Outside From Air Conditioner Window Unit June 30, 2015 ..... How To Fix A Toilet That Is Constantly Running - DIY Toilet Repair ...
Refrigerator Troubleshooting & Repairs ' HomeTips
www.hometips.com/repair-fix/refrigerator.html
May 22, 2015 - Refrigerator Runs Too Much ... If your refrigerator runs without stopping, it may be too low on refrigerant to ... 4Make sure the drain line isn't plugged. ... Instead, the unit may have dirty condenser coils, a door that doesn't seal tightly .... on the tubing and, eventually, restricts airflow through the refrigerator.
Dec 29, 2015 | Refrigerators
True back bar freezing up
Most models have a metal drip collector below the evaporator that has a drain hole in it where the defrosted water goes into before it goes down to the drip trap and then out the drain hose. If the area around the drain hole has cracks, or was punctured during servicing, the drain water can get underneath the tray and run out beside and around the drip tray and never gets into the drain tube and freeze in that location. A careful inspection of this area will reveal any issues.
Aug 15, 2014 | Refrigerators
My whirlpool duet is leaking from underneath between the washer and the pedestal. It appears to be during the drain cycle.
1. Find out where the leak is coming from. Does it leak constantly or during one part of the cycle?
A constant leak means the leak is in the valve where the hoses hook to the washer, the supply valves, or the lines to the washer from the water supply.
The other two options are when the washer is agitating or pumping the water out between cycles.
2. See if it leaks during both cycles and the test there would be to lift the lid just as it starts to drain and wait to see if the water stops leaking.
If it doesn't, then run the drain cycle to see if it gets worse or better.
Results may not be immediate as it would take a few minutes for whatever water there to finish dripping.
3. Wait until the water has been pumped out, lift the lid and check the drip again.
When the location of the leak has been determined, unless the washer has been frozen, most leaks can be fixed without parts and just using hand tools.
If you have an older, top load washer, the back or front will come off so you can observe where the leak is coming from.
WARNING. You are working with a moving, electrically hot machine that could flood.
You must take your time and not put your hand or hair in somewhere that can catch you.
You should not have to get into the upper control center, thus reducing the shock hazard.
4. Before turning the machine on, remove a cover. On some washers, there are two screws on the bottom L & R front corners that take the front panel loose.
Once the screws are removed, the front cover is hinged at the top and you simply pull the bottom away from the machine until it comes un-hooked, and set the cover aside.
There shouldn't be many exposed wires or ends, but a few. Don't touch the terminals or lay something metal in the machine that could fall on the terminals.
5. Take a flashlight, look for obvious leaks or better, water stains around nuts, hose clamps, etc.
Most likely you'll see some water residue here and there and that would be normal as a washer is wet. Look for puddles, long white streaks, calcium deposits.
Most likely, you won't find standing water, but some clues of where you should look when the machine is running.
Unless this leak is so obivous you can see what's wrong, you don't need to start it and you should repair the problem.
Once possible areas have been identified, you should start the machine as if you had a load in it and start to watch for the leak.
WARNING- Make sure you have no tools laying in the machine and you are out of the way. There are spinning parts and live wires once you turn the machine on.
Stay clear, and watch your hair and hands.
Once the machine is full and starts its cycle, look for leaks.
Let the machine do its cycle and as it goes into each part of the cycle, look for the leak.
Once you find a drip, stop the machine by lifting the lid or pulling out on the control knob, and now observe more closely.
Remember, water runs down; where it drips is not necessarily the place of origin.
6 Find the leak and make the needed adjustment (which will be all that is necessary most of the time).
If it is a part you need, get the make, model number and serial number of the washer and call an appliance parts dealer or repair service if you don't think you can repair the problem.
If the washing machine leaks water while it is filling, pull it away from the wall and see if the water drips from the inlet hoses or valves as the unit fills.
If it does, tighten the faucet packing nuts. Then, inspect the hoses and replace them if they have become cracked.
Also look for cracks in the casing of the inlet valves. Unplug the unit and lift the top to better inspect the valves.
Replace any valves that are cracked.
Valves usually crack when the hot water in the house water supply is heated to greater than 170 degrees.
They also crack if the house is left cold during the water and water is not drained from the unit. A cracked inlet nozzle can leak during fill.
The leaking water will drip down the outside of the tub and collect under the unit. Be sure that the hose connected to the inlet nozzle is tightly clamped.
Replace the nozzle if you find cracks in it.
If the leaking occurs at some time during the wash sequence other than when the machine is filling with water, unplug the unit, remove the back panel and examine the parts under the machine.
You can make a closer inspection by tipping the unit over onto it's front or side.
Tighten hose clamps that have become loose. If water is leaking from the pump, replace the pump.
The gasket between the tub and the splash guard may wear out and leak. To check the gasket, lift the top and remove the snubber and splash guard.
Replace a worn gasket. A hole in the bottom of the tub can develop.
If the hole is less than 1/4 inch in diameter, remove the agitator and basket and seal the hole.
If the hole is larger, replace the washing machine or tub.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet leaking water from bottom of washer-after I noticed the water on the floor from the washer leaking from underneath, I took the clothes out and tried to run the machine without clothes in it....
Aug 01, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Kenmore 417.99980120 stack washer/dryer won't drain.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@#$
May 12, 2010 | Kenmore 98702 Stacked Washer/Dryer
Kenmore elite he3 leaks in drain cycle
May 10, 2010 | Kenmore Elite 45986 Front Load Washer
Leaky drain pipe
Apr 12, 2009 | Washing Machines
Machine stops in Rinse & Spin Cycle & leaks water
Mar 09, 2009 | Kenmore Washing Machines
Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Sep 07, 2007 | Maytag MAT13MN Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
69 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
