Question about Fisher and Paykel DEGX1 Electric Dryer
Replace bearing in Fisher Paykel DEGX1
I need a diagram (exploded view) of the drum bearing on the above dryer. I have taken it out due to squecking noise and parts feel out every where and I can't get them back in right.
  • 10,865 Answers
Hello. Go to sears parts direct and enter the model number. You should get the diagram u need. J.
Posted on Jul 22, 2010
No matter which cycle I select, why does it go to cool down and continues to beep non-stop?
Clean the vent screen and the vent pipe, apparently the dryer cannot cool down properly because the vent is plugged.
Sep 18, 2015 | Fisher and Paykel DEGX1 Electric Dryer
FPaykel Dryer model # DE05US2 is making a screeching LOUD sound ... still turns and dries just VERY VERY LOUD and high pitched squeeling
It could be bearing or guides in the drum.Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
Sep 27, 2010 | Fisher and Paykel DEGX1 Electric Dryer
My dryer is a top loading Fisher and Paykel and it has started squeaking.
It could be bearing or guide in the drum.Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
Sep 21, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Why is it leaving black dots on my clothes and making a loud noise?
It could be bearings or guide in the drum.Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
Aug 03, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Getting sound when its working. reason for getting sound. Please help me..
Aug 02, 2010 | Fisher and Paykel DEGX1 Electric Dryer
The dryer squeeks when the drying. I have turned the drum manually, and I don't hear the noise, it's only when it is turned on and turning that way.
the belt tensioner pulley has a roller with a bearing in it causing this squeak. greasing the bearing may help or a replacement will work even better
Mar 05, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Wont start. Extra dry light on and cool down light on.
Fault #3 Drum Stalled; unable to move.
  1. Check drum movement mechanisms: belt, motor and motor harness (if motor moves drum slightly, treat as fault #2)
  2. Replace the motor control module.
  3. Replace the motor.
Fault #2 Drum Gap Cannot be Located
  1. Ensure sensor module is correctly located and clipped in.
  2. Replace the lens on the sensor module.
  3. Replace the sensor module.
  4. Remove Top Deck and clean the sensing bumps on the outside of the drum end.
  5. Replace the drum.
May 02, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Fisher and paykel dryer works but very noisy
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Dec 27, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Vibration issue - DEGX1
you need a new bearing. if you lift the lid is going to be on the right side in the middle. and its not fun to replace so i would have a factory authorized company come out and do it. if you try to do it you might damage your drum and have to replace it as well. have fun. call f&p and they might cover the parts cost for you
Aug 03, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Fisher and Paykel DEGX1 Electric Dryer Logo
392 people viewed this question
Top Fisher and Paykel Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
