Question about Canon PIXMA MP150 All-In-One InkJet Printer
Printer Jam Error
No jam. Same error as others.
  • 3 Answers
Posted on May 02, 2008
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ... Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ... Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ... There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ... > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Card jam please clear printer
Hi Imran,
I realise you probably resolved this issue a long time ago, but this may help others with the same problem (Card Jam on Rio Pro / Enduro / Enduro+).
Immediately after the Card Jam - Please clear printer mechanism, there should be an error number. All card jam errors begin with 06:??. Most common would be Card Jam 06:05.
This error means that the rear card sensor has detected a card.
However, the card has not past through the sensor. This could indicate a failed card sensor (always on). This may sometimes be caused by static on the cards.
To confirm this, switch to 'Hand Feed Mode' (on the front panel: Menu -> Hand Feed Mode -> ON). Cards are then fed (when requested) from the hand-feed slot on the front of the printer. If the error changes from Card Jam 06:05, to General Error 24:08, this would suggest a faulty rear card sensor (very rare).
Try leaving the printer switched off, and with the DC power disconnected for a few hours. If the problem persists, you should contact Magicard Technical Support.
With Best Regards,
Apr 09, 2012 | Magicard Rio Card Printer
How i can clean my printer selphy ES30 also how to solve an error paper jam
For Paper jam:
• Press
(BACK) to eject the paper.
If the paper is not ejected, turn the power off and turn it on again. If the printer fails to eject the paper, contact a Canon Customer Support center for assistance. Other solution here: For cleaning try local canon provider.
Dec 12, 2010 | Canon SELPHY ES30 Thermal Photo Printer
Keep getting an error that says paper jam. can
Dell P703w Printer
May 02, 2010 | Dell P703w Printer
My printer is giving me 2 error messages. One is
For the cartridge jam, that means that either the ink is not properly installed or there is one tiny piece of something blocking the sensors. Same is true with the carriage jam.Please try to look for small bits of paper and remove it.
Is the ink newly installed?
Aug 08, 2009 | HP Photosmart C5180 All-In-One InkJet...
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
Paper jam 11
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Turn off the printer.
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Nov 07, 2008 | Copystar CS-1815 Printer
Error Light does not turn off!
Hi, it sounds like your printer experiencing a hardware failure thats why the error light still on. The sensor that detects paper jam or any obstruction might be defective. Aside from that your printer may also experienced a motion carriage error. You can to power cycle the printer & check ink cartridge. if the error still present your printer might be needed to be send to the nearest Epson Service center.
Mar 31, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Epson Stylus CX8400 Paper Jam Error
I have the same exact problem of paper half torn removed but I can not see the other half anywhere. The printer has hardly worked for at the most six pages and now showing paper jam error. How do I fix it?
Dec 22, 2007 | Epson Stylus Photo R1800 InkJet Printer
Canon PIXMA MP150 All-In-One InkJet Printer Logo
old marine
old marine
