Question about Hitachi 53UDX10B 53" Rear Projection Television
Hitachi 53UDX10B power button flashes, chirping noise, LEDs flash
I have a Hitachi 53UDX10B and when I try to turn on the power button flashes and a chirping noise comes from the back. If I let it continue to cycle like that I cannot make it stop until I unplug the tv. I opened up the back and tried again. I noticed several LEDs lite or flashing. Here is what I found. DP11 and DP35 flash. DP23, DP37, and DP06 (red) stay solid. I've readd several posts about convergance. Please help. I would love to avoid a costly repair.
  • 3 more comments
  • kreed13 Apr 22, 2008
    Where do I get ballast from?
    OK. I downloaded a service manual. Followed a trouble shooting flowchart for Raster and no power. I got to an area and was confused on measuring a pin voltage. I noticed on the power board had no LED lite. So I took it out. Cleaned it up. Made sure fuses not blown. Replaced card and it fired up. Not sure if I let it sit with power off and fixed it or maybe something else. By the way, I'm not a TV repair man, but I am a RF Field Tech for a major wireless company. So I have a little know how.
    Thats what I thought. I was told to check it by another Service rep. But when I researched I found out mine was N/A. I did take out my power board and check fuses. I replaced and it turns on fine. You got any ideas? Or am I just borrowing time before it goes out again.
    OK, so the Ballast / Power unit is a couple hundred bucks. And its recommended I replace. Is this on every lamp? or the main power unit. You suggested earlier to replace lamps and ballast. If its two hundred a pop X 3. Thats alot more than the TV is worth at this time. I do appreciate all the help. Please keep the information flowing. Again thanks.
  • kreed13 Apr 23, 2008
    Well, Now I can turn my TV on. But after a while it turns itself off and does the blinking power light and Chirping noise. Still a ballast / power unit? If so, is their more than one?
  • Hitachi Master
  • 19,396 Answers
You can get the ballast here.
You do not work on the ballast unless you are experienced in servicing TVs, it is quite dangerous.
Posted on Apr 22, 2008
  • 3 more comments
  • Ginko
    Ginko Apr 22, 2008
    Or here from partstore.
    Before replacing the ballast leave tv unplogged for over one hour, the TV can return you a strong electric discharge even when is not connected to power
  • Ginko
    Ginko Apr 22, 2008
    If you want to save some money go to a repairman and say that you already ordered the ballast, and you are waiting for its delivery, you will pay only labour (my collegues will kill me if they read this).
    Have the TV quickly diagnosed before ordering ballast, even if the hissing noise is typical of defective ballast, you never know.
  • Ginko
    Ginko Apr 22, 2008
    Attention Jaime:
    This TV vulgarly called ballast is called power unit, I already posted it here here from partstore.
    It is the same link , It is defective and in need of replacement
    and in my opinion it is something you should not DIY. If you just replace fuses you will keep blowing them. You need to replace the power unit.
  • Ginko
    Ginko Apr 25, 2008
    You should not not have any CRT fungus, as you do not have any symptom for this (blurred pic etc.).
    In your case you have to test boards inside, starting from Power supply PWB.
    There is one main
    power board and 3 PWB boards for the lamps (R, G,B) . You need to test first
    the main Power PWB, then if it is not that the test the 3 PWB on the
    lamps .
    Here is a general troubleshooting diagram for locating the problem with diags etc..
    Here is the diagram for testing the bpoards, start from PSU:
    Here is PSU schematic
    Here are RGBs.
    I noticed you are calling all us on ask me button. In the meanwhile solutions had been accepted or refused on main thread here. You also told me in other post, you voted both us by mistake.
    I will be grateful if you use this same main thread to ask clarification, and eventually correct rating by removing all accepted/refused solutions and voting us only at the end of this.
    Regards
  • Ginko
    Ginko Apr 25, 2008
    To buy parts it is better to use Hitachi telephone number, as suggested by Best darngood
  • 3,037 Answers
The chirping is most likely the ballast trying to fire the lamp. Most likely you should replace the ballast and the three lamps and the problem should be fixed. If you check the lamps and ballast and find that one looks like it is the problem, first try replacing just that one but if you are going to replace one why not all? Replacing them shouldn't be too hard if you are good with simple tools and that should fix the problem. Let me know if you have any questions and I would be glad to help.
Thank you for using Fixya and Good Luck
  • Benjamin Patri
    Benjamin Patri Apr 22, 2008
    1-866-925-PART
    they can send you one
  • 563 Answers
Hi kreed13
My honest opinion would be that if you have never worked on these before , rather have it repaired. If you start fiddling with the IC's and you do not know what you are doing it can cause moer harm than good.
  • Marnus Jacobs
    Marnus Jacobs Apr 22, 2008
    kreed13
    But if you do want to give it a go , search on the board where the chirping is coming from and you will see a small flash on the board where the problem is occuring.
    Unplug the unit and resolder that bit only. Should do the trick.
  • Marnus Jacobs
    kreed13
    Try the above first before investing in new parts.
  • 2,335 Answers
The convergence issue might not affect the TV to the point of not turning ON.
The chirping noise you hear, it means there is a short circuit in the circuitry, possible the HOT or power supply assembly.
  • 3 more comments
  • Jaime Hernandez Apr 22, 2008
    I forgot to mention that this might not be a DIY project as this defect can be a bit hard to find.
    This type of TV does not use the ballast because is a rear projection not a DLP. DLP's use the ballast
    I would suggest to research a bit more before spending on a part you will never use, at least on this TV.
    If you've done this much work, I would say to check the solder joints around high power resistors and touch them up with fresh solder.
    This TV has been around for some time now, so it's hard to say how long it will work.
    If you have the service manual, you will not find anything that looks like a ballast but you will see the CRTs mounted on a big metal bracket.
    The only time when you replace a CRT is when the picture looks like out of focus and even then you can rebuilt it by replacing the liquid coolant that is inside the CRT assembly.
Tv will not turn on
If you hear a clicking noise that sounds like the ballast trying to power on the lamp, but nothing happens, the lamp may be faulty.You can go to http://www.discount-merchant.com/
to purchase a quality lamp.
Mar 26, 2010 | Hitachi 53UDX10B 53" Rear Projection...
53uwx10ba hitachi. just recently changed the stk chips out with what it had in it. stk392-180. but in the service manual i just got it is a different one. i think 110. but the front power light blinks with...
you have a shorted horizontal output. you just wasted your time and money on the convergence ic's that or you have a short from a bad solder job replacing those ic's.!!!
Jan 10, 2010 | Televison & Video
Power light flashes on Hitachi TV model #53UWX10BA
Hi
Can u tell me model no and company name so that i can help u clearly..
If u have warranty then u can claim it..
thank you
Oct 12, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Chirping, flashing power LED
Ok, first let excuse me for the first solution that I make in the 53UDX10B 53 in. I was thinking was a DLP Television but it was a Projection Television.
The Projection Televisions has others problems, so maybe it is that a Technician must has to solder (weld or give weld points) in some boards (PCBs) inside the TV, (the Main PCB and/or the Sound PCB) and/or perhaps has to change a capacitor (C 33uf 16v) that maybe it is exploded. Because that happen with those old Projection TVs.
It is the same with the 53UWX10B.
For all inquiries please call: 1-800-HITACHI and tell then the problem.
They maybe give you a better solution.
Jun 29, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 43FDX10B Power problem
Below is a few possible causes along with verified cures.
Symptom:
Intermittent shut off
Cause: Check auto link and 4 event timer. redress cabling from front control panel away from blue crt-yoke-hv lead
Symptom: NO PIC OR OSD, PWR LITE COMES ON
Cause: CHECK C603 LEAKY
Symptom: shutdown
Cause: T701
Billy
Jan 23, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Flashin power light - wont come on
The "green light flashing to the chirping" circuit may be defective.
Not a basic diagnosis--service literature and/or knowledge of each green light circuit will be needed.Possible shop repair.
Oct 05, 2006 | Hitachi 43UWX10B 43" Rear Projection...
Chirping noise and flashing front power light.
Theres a short somewhere in the set. Most likly the HOT is shorted or the vertical IC has caused this in the past. In one case I had shorted convergence IC cause this symptom.. This set is solid state and there are no user serviceable parts inside so please call a trained tech to assist you with this problem Good Luck
Aug 17, 2006 | Hitachi FDX Series 43FDX10B 43" Rear...
Hitachi 53UDX10B 53" Rear Projection Television Logo
153 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
