Question about Casio FX-300MS Calculator
2 problems My calculator seems to appear with exponential , i really dont know why, I tried changing the mode but is not helping, i.e. 10 + 20 = anw shows as 3.0 E01, I really dont know how to get this straight & simple. Second problem is, how to recall the memory, for instance, if 29902 is selected to be memorized then I cant recall this back? Pls. help The manual for this calc is in Spanish & I am a Malaysian.
  • 27 Answers
Check if it has a mode button, press mode then deg.
Posted on Jun 01, 2008
  • Mikey1963
    Mikey1963 Jun 01, 2008
    press the mode button twice then number 1 I think for Deg
  • Mikey1963
    to recall mem press alfa(inred) then M+ (which if you notice has a red M above it)
    similarily shift & M= to minus from memory.
    press mode button twice to display deg which is key 1 I think.
I accidentally entered a function on a calculatot
No you do not have an exponential p. The p at the bottom right of the screen says that the numeration mode is the one in base 5 (pental mode). Change it to decimal (Dec). Find the key that has the marking (->Dec) above in on the faceplate of the calculator. It s probably the + key. Press [2nd F][+] (>Dec). The letter p will disappear.
Mar 04, 2014 | Sharp el-531x scientific calculator
I have DEG on the calculator screen and get figure out how to turn it off??
Press the DRG key to cycle through the three angle modes. Be aware that whatever mode you select, the corresponding indicator will appear on the screen.
The angle mode should not affect the exponential and logarithmic functions. If you still get errors, please post an example or two, including the exact keystroke sequences.
Dec 11, 2013 | Texas Instruments TI 30XIIS Scientific...
E^ won't work
You are not using it correctly. To calculate the exponential of a number you use the key sequence [SHIFT][LN] to access the exponential function. Then type it the exponent (positive or negative) and close the parenthesis.
You do not use the power key (^)
The exponential function is not affected by the angle unit when you are using real values.
Jul 03, 2012 | Texas Instruments TI-84 Plus Calculator
How to remove the grad mode from my canon f-710?
Grad is a unit of angle. The angle unit affects only the results that involve trigonometric functions and their inverses. It cannot affect the display of results in exponential format (scientific).
Change the angle unit to degree or radian if you want.Disable the scientific or engineering displays by using FIX or Normal (floating).
May 06, 2012 | Canon F-710 Calculator
I am using my Casio fx-300MS and have somehow gotten into the display where it puts my answers in exponential form; 5+5 = 1.0 exp10 to the 1. How do I return to getting my answers in standard form?
Display Format
To change the exponential display format, press the [MODE] key 3 times.
Fixed number of decimal places:
Press 1: Scientific Notation: 0
Press 2: SCI: 0
Press 3: NORM
You will then be prompted for NORM 1 or NORM 2. CHOOSE NORM 1
To return the calculation mode and setup to the initial defaults, press [SHIFT] [CLR] [2]
[=]. This will return the calculator to the following settings:
Calculation mode COMP
Angle unit Deg
Exponential display format Norm 1
Fraction display format a b/c
Decimal point character Dot
Percentage Calculations
Apr 13, 2011 | Casio FX-300MS Calculator
I do not know how to change the mode on the calculator. i want it scientific but i am unable too.
Press MODE to bring up the mode editor. Use down-arrow to get to Exponential Format. Press right-arrow to bring up the choices, then press 2 to select Scientific notation. Press ENTER to save the settings and exit.
Sep 27, 2010 | Texas Instruments TI-89 Calculator
I can't get the calculator out of the exponent mode. ex. It gives me 7 -03 rather than .007.
You must change the number display to FIX. Press [MODE][7:] followed by a number betwee 0 and 7. This will set the number of decimal digits. Be warned that the Indicator FIX will be displayed on the screen.
This information is for the FX250D, but I trust it is also valid for the FX-250HC. If it is not, just look in your manual. If you cannot find yours, do not blame me, I cannot get hold of a manual for this calculator.
You can always take the time to play with the [MODE] key followed by [.] or a number. When you press the mode + number, look on the screen to see what indicator appears (deg, Fix, Rad) The one that makes FIX appaear is the one that gets you out of the exponential scientific mode.
Good luck
Nov 13, 2009 | Casio FX-250HC Calculator
Does the fx-260 SOLAR do exponential calculations?
Yes it does. All scientific calculators do logs, power, roots, exponential, trigonometric functions. Most do also hyperbolic and inverse hyperbolic functions.
Hope it helps.
Aug 16, 2009 | Casio FX-260 Calculator
Need Help Solving Exponential Functions ASAP!!!!
You can calculate =4^1.2 in Excel and get 5.278031643
And also in Excel you can determine what the square root of 2 is (2.506628274631) and then in Excel = 5 ^ 2.506628274631 = 56.5012395907155.
I know this is late but maybe it will help later. Assuming I am doing it right. Thanks!
Mar 29, 2009 | Texas Instruments TI-30XA Calculator
Inputing numbers to solve exponential functions
there is a nice tutorial on
this works for ti 83, 83+, 84, 84+ and 84+ silver
Nov 11, 2007 | Texas Instruments TI-84 Plus Calculator
Casio FX-300MS Calculator Logo
150 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
