Question about Sharper Image Hybrid GP (SI724) Air Purifier
When clean the filter in one hour the machine stop and i need clean back
    Problem Solver:
  • 6 Answers
Clean the metal filter grid blades with a long strip of scotch brite pad and also clean the corona wires in the back of the unit very gently with light grade sandpaper. i had this problem and tried cleaning my unit so many times that i was ready to toss it into the trash. now it works normally. i did some spray painting in the room where the unit was operating and believe it picked up a coating of paint causing the sparking. good luck!
Posted on Aug 03, 2010
I just bought the purepro 200. I ran it for about 7 hours in a normal house setting and it turned off and the cleaning light came on.I have unplugged it and tried it again. This time it went off in 10...
John, when the clean filter light came on, did you clean the filter? Or just unplugged it and tried again?
In 7 hours, the unit probably picked up a lot of dust, that's why the clean filter light came on. Try cleaning the filter( if you haven't already) and that may solve your problem. When you reinstall the filter, be sure that it is seated properly, so the the safety trigger switch is activated.
Hope this helped you to solve the problem.
Mar 23, 2011 | Montgomery Ward Pure Pro Air Purifier
Help!
Try leaving it unplugged for a while to reset it.
Jul 23, 2008 | Brookstone Pure-Ion (506840) Air Purifier
Tip
Air Purifier Cleaning
You bought that air purifier to help to clean the air in your home. However you have forgotten about it and now you expect it to still clean, when all of the cleaning surfaces and the filter that catches the big chunks are completely used up and covered with dust and dirt.
Here is what you need to do on a regular, like monthly, basis to keep it working well.
  1. If your unit has a filter or pre-filter pull it out and wash it gently in some warm soapy water. If the filter is a throw away one then place it in a plastic bag and dispose of it. Be careful not to throw it away before you make sure you know what to get to replace it. You may need the old one for comparison when purchasing a new one. Also take note of how you removed it and the direction of the air flow. Some of the filters are made to have the air flow in a certain direction. The filter is often located in the back side at the bottom of the unit.
  2. Take apart everything that you can on the air purifier and clean all the pieces with a moist cloth. You may need to take toothpick or something small to clean out the small grooves and crevices in the unit.
  3. Leave everything dry completely before reassembling the unit. This may take quite a while for some of the filter media. A few hours is not uncommon, be patient.
You now will have your air purifier working in top condition again
on Jan 11, 2010 | Air Purifiers
Honeywell Furnace Air Filter clicking noise after cleaning it
I also have this problem as soon as I pt a new filter in - does anyone have a clue what this problem is?
Apr 09, 2010 | Honeywell (F50F1032) Air Purifier
Brookstone Pure-ion Advanced
i am a low voltage tech my wife told me that our 506840 air cleaner stopped working so being a tech geek i had to know why it just stopped working.when plugged in i heard a click telling me that the main board was getting power.opened the back end where power cord goes to put my meter and voltage was going to the main power coil. but the main board was oxidized. when my wife was cleaning the filters and might not have had the filters completely dried the water was dripping down to main board.the unit to main power source is not design very well where water from cleaning the filters can drip down to main power board.solution i am working on is trying to get a new board when we bought this it was $499.00
Oct 15, 2008 | Brookstone Pure-Ion (506840) Air Purifier
Clean Filter Red light
I cleaned the filters as well earlier and the red filter light still blincked to clean the filters. Then I pushed the power button for about 10 seconds continously and then turned it on and the light turned off.
May 22, 2008 | Brookstone Pure-Ion UV Air Purifier
Kaz Honeywell Tower Air filter rest light
When the filter monitor light remains on, it is time to check/clean the IFD™ filters and reset the filter
monitor, if needed. With the unit powered on, insert the tip of a ball-point pen or paperclip next to the LED
filter check light and hold for approximately 5 seconds until the light turns off (Fig. 3). Depending upon
your individual usage (environment and hours used), you may need to check and clean the filters more or
less frequently. If the IFD™ filters are cleaned before the filter monitor light turns on, the filter monitor
should be reset at the same time.
May 18, 2008 | Kaz Honeywell Tower Air Purifier with IFD...
Hunter 730 carbon pre-filter replacement orange light
Filter lights on your Air Purifier http://www.fastbrowser.net/netpicker/Filter-lights-on-your-Airifie.htm One of the best things about your IQAir Air Purifier is that it has warning lights to tell you when to change the prefilter, gas or hepa filters. Of course how long they last depends on your pattern of usage. For the initial 80% of the filter life the control panel will display a green light next to the corresponding filter on the outline of the unit. When the orange light goes on it does not mean that the filter needs to be replaced immediately but that there is 20% of useful life left. IQAir gives you plenty of time and the machine will tell you how many hours you have left. Once the number of hours gets to within a few hours remaining the orange light will then change to red. It is at this time you should change the filter. If you forget to change it and there are no hours left the hours will go into the negative displaying how many hours you have gone over and the red light will change to a flashing red light.
Just in case you have lost the manual like one of our customers, this is how you reset the filter lights:
1. Press the menu button ( 7 times) until you get to where the display says new filter.
2. Press the enter button and hold it down for 3 seconds and a number 1 will be flashing after the words new filter on the display. This flashing number is so you can enter which filter you have changed. Filter number 1 is the pre-filter, filter number 2 is the V-5 gas filter, and filter number 3 is the Hepa filter.
3. You change the number for the filter by pressing the up arrow button.
4. Once you reach the correct filter number you press the enter button and the control panel will display a question mark after the words new filter on the display. Below this it will say, E = Yes M = Cancel. If you wish to cancel the entry so it does not reset a new filter life, simply press the Menu button.
5. If you want it to reset the filter life for the changed filter, simply press the Enter button. Once this is done, the filter light will change back to the green light, which will show the filter has been changed. If you go to the remaining filter life on the control panel for the filter number you just changed, you will now see the remaining life of the filter in hours has been reset.
  • When most people think of Oreck, an air purifier is usually not the first thing
  • IQAir Dental Series Air Purifier
  • UV air purifiers are very effective at neutralizing airborne pathogens
  • HEPA Air Purifiers
  • REPORT ON THE AIR QUALITY CLEAN UP IN OUR OFFICES
  • Ozone Air Purification
  • Ionic air purifiers come in three different forms
  • WHOLE HOUSE HEPA
  • Dehumidifiers - Ebac Orion
  • Furnace Filters, Electronic, Electrostatic Air Filters - Comparisons, Ratings,
  • Nov 26, 2007 | Hunter 30216 3-SPEED FLOOR MODEL Air...
    Cleaning the filter
    Yes to get the clean filter light to go off, you have to clean filter, put back in the machine, and hold down the power button for 3 secs to reset it. the clean filter light will go off!
    Nov 14, 2007 | Brookstone Pure-Ion (506840) Air Purifier
    Sharper Image Hybrid GP  (SI724) Air Purifier Logo
    149 people viewed this question
    Top Sharper Image Air Purifiers Experts
    Daniel Dollive
    Daniel Dollive
    Mike Squire
    Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
