Question about Dell W3201C 32 in. LCD Television
Having issues with the speakers .. they will just start being inaudible and if you unplug and replug they will sometimes work. Right now only one will work if you switch the wires around the other one will work
  • 11,896 Answers
Either you have a problem with the sound board (possibly bad capacitor or resistor) or there is a short in the wiring itself which you can test with an ohmmeter on the ohm setting placing one probe on each speaker wire.
Posted on Jul 25, 2010
  • papickel Jul 25, 2010
    if it is the capacitor on the sound board what has to be done
  • Nate Stansfield
    Nate Stansfield Jul 25, 2010
    It will have to be soldered off and the new one soldered on. Partstore.com usually carries them
I can only hear phone calls if it is on speaker phone. I have tried blowing into the device and that was no help. This just started happening a couple of days ago out of no where. Apple iphone 3G. Hope...
I had seen this problem, you will have to change the earpiece speaker, and another thing is that you will not get that alone, it is a set that contains the loudspeaker, mike and earpiece speaker
Oct 23, 2013 | Apple iPhone 3G
Alpine Ipod Interface Not Working Correctly
Sometimes those 3.5 mm stereo connectors don't work right. If a little wiggling and unplugging/replugging does not restore the sound there may be a connector that is defective
May 05, 2013 | Alpine Kca-420i Kca-121b Ai-net3.5mm Mp3...
I have an onkyo tx-sr308 and I am receiving only static or very low music on my right speaker channel. Please help
Switch to the other set of speaker outputs (move from A to B). If it continues, you have a repair issue...assuming it happens with all inputs. If it only happens with DVD, or CD, or Tuner, or whatever, but works fine with other components, it's a connection issue - unplugging and replugging, or replacing cables may correct.
If I recall correctly, that unit doesn't have a standard twist knob style balance control. If it does, turn the unit off and rotate it through it's full range several times, then recenter it and try listening to it again.
Jun 25, 2011 | Onkyo TX-SV444 Receiver
Hey, i bought a DLP Toshiba HDTV off a guy on graigslist, when i went to go pick it up he turned it on by remote and everything worked fine as it should. When i got back to my place I tried turning it on...
These DLP tvs sometime u unplug suddenly and replug it back wright away,tv will go into protective mode and will not work wright away.Tries tv unplug,replug it back about an hour later,now the tv will reset itself back to the factory setting.The tv should work now.
Nov 17, 2010 | Toshiba 65H93 65" Rear Projection...
Have only had speakers for about one month now and one speaker is not playing unless I hold the volume control to one side to made good contact. Were great speakers - to start with! Cheers.. Errol H
errol_hedges
In regards to your speakers not working it sounds like the stereo plug may not be plugged in all the way. If it gets unplugged then only one connector is on the stereo plug. So I would unplug and replug the stereo cable on the computer and you sub. Doing will get the connectors lined backup.
Let me know if you still have trouble.
Issken
Jan 08, 2010 | Logitech R-20 Computer Speakers
No sound on my computer. it was working until two days ago.
u don't need to restore it's dound setting problem iu just chek volume control and chek master sound and wave sound is on or mexmimum
Jan 08, 2009 | Bose MediaMate Computer Speakers
Almost inaudible handset because its so quiet.
A speaker is the first suspect, the second is the speaker connection, the audio amp final ckt. Check for a lose wire, dirty connection, flux, a bad solder connection, ect on the main ckt Bd.
Nov 28, 2008 | Motorola Walkie Talkie 2-Way Radio
One speaker not working.
Suggest you swap the right speaker into the left output if it works the the amplifer in the control unit is faulty. IF still on sound then the rigth speaker is faulty.
Oct 03, 2006 | Harman Kardon SoundSticks II Computer...
Dell W3201C 32 in. LCD Television Logo
59 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
