Question about Jenn-Air JDB6510 Built-in Dishwasher
Cycle times How long does it take to complete the heavy wash cycle?
    Problem Solver:
  • 9 Answers
If you remove the front lower panel with 2 phillps screws (one on each front end) and lift up and forward, you should find a information sheet folded. It is glued at one end so you will have to look at it with the base panel off; but, it shows you by graph how long the cycle is and what is operating at the time. Good info to understand how the electrical runs the mechanical aspects and definitely how your timer switch assy works as it cycles around.
I could tell you the time, but I would have to open one myself and you're the one with the machine.
Posted on Nov 20, 2008
Bosch dishwasher cycle running too long?
Please supply model number and define what is "too long". Long cycle times are usually caused by a water heating issue. Some (heavy wash w/high temp heating) cycles may take 90+ minutes for a complete cycle, this is normal. Does the unit circulate (pump) water or is just the drain pump running?
Aug 28, 2014 | Dishwashers
FOUR HOURS TO WASH TOWELS
That is not normal. Have the control circuit board tested for continuity. Either the cycle or timer section is out of wack and may need replacing.
Feb 27, 2014 | LG WM2487H Front Load Washer
Will not rinse or spin
I have had similar situation with my top load washer over the years. It has been the timer 3 times and the water pump 1 time.
How I came up with it being the timer. The knob which you set it on the type wash you want. Put it on a different cycle and see if it completes the wash cycle. example if my washer is not working when I put it on heavy wash cycle I might put it on the casual wash cycle. If you change the wash cycle and it goes through the complete cycle it is probably the timer which is part of the knob you change for different wash cycles with.
If it stops when it is time to empty the tub on all cycles it may be the water pump which empties the tub. The one time I had a problem with the water pump it was a small piece of coal had the pump locked up. I never figured how it got out of the tub and to the pump but I put it back together and it worked fine.
It should not go into the spin cycle if the tub is full of water.
Two of the timers I bought cost 40 - 60 dollars. One was 140 dollars I bought a new washer that time because the washer only cost 220 dollars.
Dec 03, 2017 | Estate Washing Machines
No spin cycle
Suspect there is heavy load in the spin cycle which makes it trip off. You need to check the free movement of the drum and also the motor.
Nov 20, 2013 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Won't complete normal cycle, but will complete heavy duty normal cycle gives errors codes of "sd", and "f21". have cleaned trap, and it works for next cycle, then errors out again. But Heavy duty works...
GOOD NEWS
actually SD means SUDS, it maens that your using too much soap,
when you clean out the rap your cleaning out the rest of the soap,
anyway, if you cut way back on your soap, i usually sugest 1 tablespoon for these models works just fine
try one empty load and no soap
watxh the suds appear in the wash cycle
remenber you bough this machine for water savingfs
1/6 the water 1/6 the soap
Oct 24, 2009 | Whirlpool WFW8500SR
Runs forever! even on Normal wash...help !!
The most obvious failure would be the mechanical timer that is behind / part of the knob used to select the cycle.
But, you may want to inspect the heating element in the sump area -- some dishwashers will wait (and wait) for the water temp to come up high.
Good Luck!
Feb 25, 2009 | Frigidaire 24 in. FDB510LC Free-standing...
LG front load washer/ clothes still wet after final spin
The heavy jacket prevented the washer from spinning at a rapid pace, so I added a heavy bathrobe to absorb some of the water and to balance the load. The washer then spun very quickly and drained out all the water.
Jan 07, 2009 | LG WM-1832C Front Load Washer
Jenn-Air JDB6510 Built-in Dishwasher Logo
61 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
