Question about Poulan 14" Chainsaw
How to connect the fuel lines for Poulan Model # 1950 Chain Saw
How to connect the fuel lines for a Model 1950 Chain Saw. Mine has a Carb
with 2 brass connections. One at the top and one at the bottom. Which is
for the line from the filter in the tank, and which goes to the short line that
just goes in the tank a little over an inch. The larger line goes into the tank
with the filter attached?
    President:
  • 2,220 Answers
The following link should be very helpful:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
A link to a Poulan model 1950 Type 7 follows (may not be your saw, there are 7 different Types and 2 Woodsharks (LE))
http://www.ordertree.com/modelinfo/PWE/1950-Gas-Saw-Type-7/75.1950-Gas-Saw-Type-7.1.59.1.html
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Jul 22, 2010
  • dontbother10
    dontbother10 Jul 22, 2010
    The print is deceptive The filter goes on a small hose and connects directly to the carburetor. A short section of small hose fits between the output side of the carburetor and the suction side of the primer. The larger hose connects between the bleeder (pressure) and a fitting (return) on the tank.
  • dontbother10
    Poulan.com
    http://www.ordertree.com/modelinfo/POULA...
    The dash number of your serial number is the type.
How do I get inside the fuel tank of my poulan 1950 to replace the line in it?
To replace line you use tag wire or similar item to pull the fuel line through the tank fittings.
First you install tag wire through the tank fuel line open and out the fill hole. Then attach this tag wire to the fuel line and pull the line back through the fuel line opening. You do this for both the pickup and the return lines. Mark your return line about an inch from the end so you can install it at the proper placement. As pull this return line through the fuel line opening stop when you reach the mark. Now with both lines installed cut them to desired lengths to connect to the carburetor and the primer.
Here is a picture of how connect the tag wire to the fuel line.
Dec 22, 2014 | Poulan Chain Saw. 14 in. 33 cc Gas Chain...
How to tune the carb on 1950le poulan chain saw
H I ONE quarter turn L one turn then adjust the idle.
Oct 10, 2014 | Oregon Poulan/Poulan Pro 12" Chain Saw...
Poulan chain saw model #2025 - fuel lines dry rotted and disintegrated. There are 3 fuel lines: l from gas tank and 2 from primer button but only 2 fuel ports on the carb. What goes where and how?
You should have 2 to the tank, the one with filter coming from tank goes to nipple on right side of carb, the nipple on left side by primer bulb goes to primer bulb and other from primer bulb back to tank as return line, how it should work is when you push primer bulb it pulls fuel from tank through carb and back to tank on return line so watch in tank orleave one line out that you think is return line and see if gas comes out when you prime, but remember it goes through the carb first before it goes back to tank, had a pic but too big to put on site sorry, 2StrokeJim
Oct 11, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Hi Sirs, I have a Poulan Woodshark model 1950. The gas lines deteriorated and I bought new ones, together with the primer bulb and the chain. Now I can't remember how to connect the lines. I need help....
The fuel line from the tank with the filter on the end goes to the carb inlet, closest to the metering cover usually a chrome cover held with four screws, the other conection on the carb goes to the suction side of the primer bulb, normally the shorter of the two conections, the pressure side of the primer goes back to the tank, this pipe just sits in the tank to act as a return, just remember the primer pulls fuel from the carb, into the bulb, and back to the tank.
Jul 23, 2011 | Poulan Pro 14" Gas Chainsaw 33CC P3314
Need diagram of fuel lines from tank to primer bulb and carburator on a Poland chainsaw model 1950 wood shark
There are 7 different types of the 1950 model (types 1 - 7) and it came with one of these 2 carbs Walbro or Zama. The carbs are different as are the fuel line connections for each one.
Although this video is for the promer bulb you can see the routing of the fuel lines.
http://www.ereplacementparts.com/article/4262/How_to_Replace_a_Primer_Bulb.html
You will have one line from the fuel tank connecting to primer bulb the 2nd line going to the carb. If you connect it backward it does not pump fuel into the carb.
Kelly
(FYI Types 1 - 5 all have the same fuel line routing.)
Apr 12, 2011 | Poulan Pro 14" Gas Chainsaw 33CC P3314
42cc 2cycle poulan chain saw does not start spark plug fires has fuel, fuel in fuel lines seems there is some blow-back in the carb when I turn the engine over don't know much about chain saw motors, if...
Here is a Link to a couple of my Tips. They should solve your problems:
www.fixya.com/support/r6081405-cleaning_small_engie_carburetor
I don't know anything about outboard motors, so I can't answer the reed valve question. There is a needle valve on the diaphragm side of the carburetor though. Maybe these two parts perform that operation.
Good Luck!
Jim
Oct 11, 2010 | Poulan PP4218AV 18" Chain Saw
Need to know how to connect the gas lines from the primer bulb to the carburetor on a poulan woodshark model 1950 chainsaw
The lines should be connected to push fuel into the carburetor. The output (overflow) of the carb is routed back into the tank. So, two lines in the tank, one is an overflow (return) and the other is the suction. On the primer one line from the tank and the other to the carb. Connect so as to "push" fuel into the carb when the primer bulb is pushed.
Jun 16, 2010 | Poulan 14 in. 2.0 Peak Horsepower Electric...
Carb. connector hose to air filter keeps melting.
There should be only two small diameter hoses (lines) that connect to the carburetor--one comes from the fuel filter in the tank and the other connects to the primer bulb. If either of these is melting/breaking from heat, someone has replaced them with inferior rubber/plastic tubing or you have some serious engine heat problems! Buy the correct lines from a Poulan saw dealer and replace the junk. If you had that much heat, it would have seized the piston in the engine. After the lines have been replaced, check the fuel filter, air filter, and muffler for plugging. Start the engine and after warm up, open the throttle fully. It should 4-stroke but immediately 2-stroke when cutting. If it 2-strokes at all times, then the 'H' jet needle may need to be adjusted. Don't ignore this as it causes overheating, low power, and possible engine damage. Hope this helps!
Jun 05, 2010 | Poulan Pro Chain Saw 46cc 20"
Fuel line routing
A typical fuel system and a couple of suggestions follow:
An example of an IPL for a "2055 Gas Chain Saw Type 7" follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/2055-Gas-Chain-Saw-Type-7/75.2055-Gas-Chain-Saw-Type-7.1.59.1.html
If not your saw, yours can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
I am reasonably sure the upper most carburetor connection (it bleeds any air in the carburetor, air rises) goes to the primer. Leave the hoses long enough to swap them and try it. They can be shortened once you verify the correct routing. Good Luck. HTH
Lou
Feb 24, 2010 | Poulan Pro Chain Saw 46cc 20"
How do I install fuel lines on a poulan chain saw model 1950?From carburator to primer,from primer to fuel tank,two connections on each.
The smaller line comes from the fuel filter in the tank to the nipple on the side of the carb with the cover w/ 1large screw in the center, the other small line goes from the other nipple on the carb to the primer bulb, the larger line goes from the other nipple on the primer bulb back to the tank, and only gets pushed in about 1/2-3/4" into the tank. Hope this helps.
Feb 26, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Poulan 14" Chainsaw Logo
4,768 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
roeb
Jay Finke
Jay Finke
Are you a Poulan Garden Expert? Answer questions, earn points and help others
