Question about Dell A215 Computer Speakers
Speakers/Audio problem My speakers are plugged in, and they did work yesterday. They don't make sound on All Internet Applications, but worked elsewhere. Example: Youtube videos dont make sound at all, but anything off the internet works. I checked all the cables, unplugging and plugging them back, nothing worked. I have a Compaq Presario 8000, and my speakers are a Realtek AC97 Audio type.
    Brigadier General:
  • 4,044 Answers
This isn't going to have anything to do with your speakers. It will be something in your system settings that deals with Internet or Video. Check your Sound card selections and your equalizer settings to make sure you don't have it muted somehow.
Posted on Jul 22, 2010
Speakers not working
Audio driver installed and not corrupt? Double check the memory modules are all the way seated. I've seen improperly seated memory do weird things. Make sure the audio ports are still enabled. Mine can be disabled in the software.
Jan 29, 2013 | Dell XPS 400 PC Desktop
Gateway Internal Speakers Stopped Working
click on Start / Control Panel / Sounds And Audio Devices
look at Speaker Settings / Advanced -- be sure it is set to your internal speakers.
the tabs across the top; go to Audio. -- be sure it is set to your sound card. For example, mine is "SoundMax Digital Audio" ... If there is another device you use that plugs into your USB, it could have stuck on "USB Codex". If it is, just put it on "NameOfSound Card" ...
Good luck, Don't be afraid to look all around inside the Sounds And Audio Devices box. And is this helped, please take a sec to rate me. Thanks!
Don
Mar 18, 2012 | Gateway Computers & Internet
Dear Sir, Speakers are working but headphone is not working please tell me the solution.
Well you can only play sound through one device at the same time. If you wish to change the device to play audio from, using windows 7, go to the bottem corner of your screen, to the system tray. You will there see a speaker icon, rightclick it and click sound devices. Then figure out which device your headphones are (if there's multiple speakers showing up). Click the speaker you want to use and click the set as standard button.
You may have to restart the applications currently playing sound in case they don't play sound anymore or they still play through the wrong device.
Jul 24, 2011 | Computers & Internet
I have a set of logitech X-530 speaker for my computer with windows home 7, i have had the front left and front right speaker working properly, however now i cannot get any sound from any of the...
Try to disconnect the input connector of your speaker and touch the input jack of the unit if you hear a hazing sound it means your speakers are working properly but if you don't hear any sound your speakers are bad. Open the speaker unit and check the amplifier section of your unit. If you don't see any burned electronic component inside. Check the wiring of your unit.
To check if the audio of your computer is working. Plug in the input a headset if you hear a sound while you playing a music in your computer it means the audio of your computer is working good.
Jul 12, 2011 | Logitech X-530 Computer Speakers
I am running vista 32 bit on a dell computer. i have just bought logitech ls21 speakers. i have plugged everything together but the speakers don't work. in control panel/sounds/playback it says i have...
YES YOUR SOUND DRIVER IS NOT ISTALLED .
YOU ALSO USE THE INTERNET YOU DOWNLOAD THE NEW VERSION OF REALTEK SOUND AUDIO DRIVER AND THEN SOUND IS OPEN.
Apr 10, 2011 | Logitech LS-21 2.1 Speakers
My speakers work fine. I don' t know why thay keep turning. i have the internet. How do i keep my speakers on all the the
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Feb 16, 2011 | Audio Players & Recorders
I did a format to my comp and i lost the drivers for my Inspire T 5900 do you know were to download them?
First, speakers don't have drivers (although one of the names used for a speaker is a driver.) Sound cards have drivers.
Inspire T5900 MF4045 Speakers Do Not Require Drivers/Applications to Work (Non-USB Speakers)
Creative speakers do not need to be installed at all as they can be plugged in to a device and ready to be used straight away.
Desktop speakers are designed to function with most sound cards without the use of any drivers. As such, there are no drivers necessary for the speakers to function as they were designed. The sound card or audio device which the speakers are plugged into may require drivers and/or software to work. Ensure that your speaker is connected to your sound card's audio out and that your sound card is configured properly to output sound. Please contact the sound card manufacturer for driver availability.
Jan 18, 2011 | Computers & Internet
I have the Logitech X 540 5.1 speakers. When I used them on my HP Desk Top that had Vista they worked for a long time then all of a sudden stopped. I thought it might be my computer and I needed a new one...
Double check all of your connections and make sure everything is properly connected in the back of the sub woofer. Next, make sure that your audio jacks are plugged into the correct audio ports on *********** board, this is very import to make sure that sound is coming out and going to the proper channels. If the front speakers still do not work, recheck your audio settings on the motherboard. If all is folly and they still don't work, i would still recommend the same speaker set, as for the price they are amazing quality. But I will include a few other options within your price range.
http://www.logitech.com/assets/35723/setup-installation-guide.pdf
http://www.newegg.com/Product/Product.aspx?Item=N82E16836121044
http://www.newegg.com/Product/Product.aspx?Item=N82E16836116049
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6325847&CatId=2894
Jan 14, 2011 | Logitech X-540 Computer Speakers
No sound coming from speakers and drivers not working anymore...
Make sure you use the power adapter with the speakers. Most audio cards today won't drive the speakers on their own. Either
  1. remove the audio from the Device Manager then search for changes, or
  2. Look at the Properties of the audio device and revert to a previous driver.
May 13, 2017 | Logitech Z-5300E (970102-1403) Computer...
No sound from external speakers with toshiba dynadock
if using XP, go to start control panel , sound and audio devices.Under the audio tab make sure the C Media CM106 sound device is selected under sound playback. Then under the volume tab set the volume somewhere in the middle or at the top if you don;t have active speakers . Then Under Speaker settings advanced, make sure the speaker setup is set to Laptop Stereo speakers. Also make sure the speaker volumes are up on the speaker volume button. click ok. If no result check that the cm106 sound decvice was cemented in as I saw it dissaper when I thought i had slected it. I think the key thing here is the device and the laptop speakers setting.
Aug 26, 2009 | Toshiba Dynadock Port Replicator, Docking...
Dell A215 Computer Speakers Logo
330 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Greg Cann
Greg Cann
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
