Question about Whirlpool GEW9250 Electric Dryer
My whirlpool duet gas dryer starts to dry but after a few minutes the E1 turns on and dryer stops. At times the dryer turns on and goes through the whole cycle however clothes are not completely dry. Could this be the sensor or thermostat?
    Guru:
  • 366 Answers
Please check the video in the link below if it helps.
http://www.youtube.com/profile?user=DIYAPPLIANCEREPAIR#p/u/2/e6cMej-C1XQ
Posted on Jul 22, 2010
What causes my gas dryer to heat and the flame goes out
Try using timed dry insted of sensor dry if runs ok you need aew sensor strips. also make sure dryer vent is clean.
Aug 10, 2014 | Whirlpool Dryers
Dryer stops running and displays E1
WHAT IS WRONG WITH YOUR DRYER?
small_8_20.jpg For a detailed Dryer illustration, click below.
redarrow.gif Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Electric dryers aren't very complicated. Here are some common symptoms that you may experience with your dryer:
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
It blows fuses or trips the circuit breaker
My clothes smell bad!
My clothes are marked or torn
Aug 11, 2008 | Whirlpool GEW9200L Electric Dryer
The drying time goes for normal mode start at 34 minutes to 30 minutes left then drops to 20 minutes then goes down to 17 minutes left then suddenly it stops and says complete. so the normal mode doesn't...
Yes, I believe the "normal" setting is part of the sensor dry. So, if the sensors, bars located on the inside of basket, do not detect moisture, the time will decrease and eventually stop. Locate the sensor bars, get some scotchbrite pad, and lightly clean the two metallic "bars" on the inside of drum. I find alot of buildup from dryer sheets inhibiting the conductivity of the sensors. I would start from there. If that doesn't fix it then you may need to call for service. hope this helps.
Sep 29, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
I start the dryier and wokr for a few minutes and stop and turn on again and stop ang mesage in E1
Hi. I can explain why this has occurred and give proper repair details, as well. I have 30+ yrs in the field of large appliance repair.
Sep 01, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Dryer lights works, but when the start button is pushed the drum does not spin. the timer shows the minutes counting off, but no spinning. the dryer worked yesterday, but no today. dryer is a duet...
I am having the same problem. Dried towels last night. This morning, I loaded it, turned it on, it did not lock the door or start drying (spinning) but the timer started counting down. I pressed Cancel twice, unplugged it for a few minutes then tried again. Problem still exists. Any suggestions?
Aug 04, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My whirlpool gas dryer keeps coming up with E1 error code after drying for about 50 min, model ggw9200lwo. Any solutions to what the probelm might be?
The E1 code means there is an open thermistor. This thermistor is located on top of the blower housing. Access it by removing the bottom panel on the front of the dryer. This device is not repairable, so unless it's just a loose connection or the device is not firmly mounted, it will need to be replaced.
Unplug the dryer before you work on it!
Mar 28, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer stops working after 2 minutes into cycle
If it is new, is it not under warranty?
does it run ok on air dry? Is there good air flow?
post your answers in comments
May 14, 2017 | Whirlpool WED9500T Electric Dryer
My dryer starts runs for a few minutes then stops with an E1 on
clear the exhaust tube of lint and make sure you have good air flow out of house and also if you happen to keep anything on top of your dryer please i say this to all NEVER keep anything on top ot it. Clothes or stacked items on top insulates your cabinet and makes dryer run improperly. Nowadays with sensors and all, it fools your machine when you have stuff on top of it. Good Luck
Jan 06, 2009 | Kenmore 73952 Gas Dryer
I HAVE A WHIRLPOOL DUET GAS DRYER MODEL NO. GGW9250PL0 THAT KEEPS BEEPING EVERY FEW SECONDS AND THE DIGITAL MINUTE DISPLAY IS ERRATICALLY CHANGING THE NUMBER OF MINUTES WHEN TRYING TO SELECT DRYER SETTING....
We had the same problem. Sometimes unplugging it for a few days, it would work when plugged back in. We replaced the user interface which is part #19 on the Whirlpool parts list, the front circuit board. The part alone was $160 at the cheapest place we found. http://www.appliancepartspros.com/
Dec 11, 2008 | Whirlpool GEW9250 Electric Dryer
Whirpool Senseon stops mid-cycle
there is a thermostat called a thermister on the blower box that will do that(run for few minutes and shut off) get the model number off dryer door or on inside dryer door wall ,go to sears .com click on parts put in model number and it will show you exactly where everything goes,let me know how you do-mike
Oct 02, 2008 | Whirlpool LER4634J Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
195 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
