Question about Kenmore Washing Machines
Burning rubber smell on Kenmore stackable washer; dryer works fine. Can i fix this myself? How do i get inside the unit? I have 5 year extended warrenty and Sears can't come for a week. I can't wait a week to replace a belt. Smells bad and has light smoking until we turned the unit off.
  • Brad Brown Feb 05, 2018
    Hi garthlocklin, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What is the model number?
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 15 Answers
Wait for Sears. You working on the machine could void tbe warrantu It's not fun but the local coin laundry could save you a fortune in future repair cost.
Posted on Feb 05, 2018
  • Kenmore Master
  • 23,755 Answers
You should be able to see the belt if you pull the machine out and tip it backwards against the wall. You will have to remove the dryer first. The problem will be WHY the belt is slipping?
Google
make model spare parts
and you should see schematics in the images tab of Google.
SOURCE: Fisher and Paykel Smart Drive burning mells
Try: http://usa.fisherpaykel.com/global/customer-care/trouble-shooting/washing-machines.cfm?CFID=5795181&CFTOKEN=46306735
Posted on Jan 15, 2007
  • 1314 Answers
SOURCE: washing machine smells like burning rubber!
sounds like you have a broken motor coupling while your down to the pump check for something jamming the pump here is the procedure First unplug the washer and turn off the water. If you have a shop vac take the drain hose out of the drain,and through the drain hose vacuum the water out of your washer. If you don't have a shop vac go to the auto parts store and buy a pair of radiator hose clamps . Then facing the washer locate the two screws. They will either be in the front or rear of the control panel and back them out far as you can. Once you have done that pull the control panel slightly forward, and tilt it back on the hinges. Now unplug the lid switch wire but don't forget to plug it back when your done. Next locate at the rear of the washer body the two gold clips then push forward, and take careful note of how they fit. Then pop them out with a screw driver tilt the washer body forward at 45 degree angel and walk forward with the body, and set it down. Now you will see the white pump and motor assembly. You should see two clips holding the pump to the motor pop them off, and pull the pump off the motor shaft. Now if you fell the need to remove the pump use the radiator hose clamp. take them and clamp the hose coming from the tub but its not necessary for the repair. Next disconnect the wiring harness from the motor (note the position of the harness for reassembly). Remove the two 5/16 inch screws from the motor clamps and pop the clamps off. Once that is complete, remove the motor put the new coupling on the motor and transmission shaft. I use a socket and a hammer
Posted on Jan 20, 2008
  • 262 Answers
SOURCE: Kenmore Stackable Washer/Dryer
THIS COULD BE THE MOTOR IF IT IS UNDER WARRANTY LET THEM PAY FOR THE REPAIRS
Posted on Feb 01, 2008
SOURCE: washing machine spins slowly and smells of burning rubber
The belt could be worn and will be slipping on the pullys, as it spins up the rubber , rubs against the pullys and that is what creats the burning rubber smell, the belt needs replacing.
regards jonno
Posted on Apr 21, 2009
  • 174 Answers
SOURCE: Our vacuum smells like burning rubber. Does it
Burning rubber smell means the brush belt need attention. Make sure the brush is turning freely and replace the belt
Posted on Jul 05, 2009
Kenmore elite front load dryer squeaking and burning smell
you have a bearing in the drum support that has frozen and now the rubber wheel is burning up. The bearing needs to be replaced ASAP. You could damage the dryer if you continue to use it.
Feb 16, 2014 | Dryers
Dryer has a burning smell
My Kenmore 94702 dryer element overheated and the rubber inside the tub caught fire. Can anyone tell me how to find out if this problem has been reported by other owners of the Kenmore model or owners of the same model sold by the actual manufacturer?
Mar 20, 2012 | Kenmore 94702 Front Load Stacked Washer /...
Wont spin cycle at full speed
Burning smell is a slipping belt. These are tricky to get apart and diagnose but find the reason the belt is slipping and replacing it will solve your problem. Could be clutch, bearing or gearcase related.
Eric
Dec 11, 2009 | Kenmore 98702 Stacked Washer/Dryer
Can you buy a frigidaire stackable washer separately?
Have you had a qualified service man look at your machine? I would think that the burned rubber smell would direct you to examine the belt (found in the very bottom after removal of front cover).
If it is the belt it is a very easy fix on this machine. The not draining part wouldn't be related to the belt the pump that does the draining is driven by its own electric motor and is easily visible when the front cover is off. Its located on the bottom left side. If a sock or other small item manages to get over the side of the basket it always ends up jamming the pump.
You would have to take the pump apart to retrieve the item and restore pump function
Good Luck
Quentin
Aug 18, 2009 | Frigidaire FEX831CS Top Load Stacked...
When drying rubber burning smell from inside Equator EZ 3612 CEE
If you are still wanting to know the reason, it may be that the door gasket has warned off and may need to be replaced.
Apr 04, 2009 | Equator EZ 3600 CEE Front Load Washer /...
Burning smell
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Nov 16, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer drum wont turn- burning rubber smell
could be a stuck gear box. burning rubber smell is coming from the belt sliding .
or the belt is just loose and can not turn the drum to spin it.
tnx 4 using fixya,
drcool
Oct 11, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stackable washer and dryer
check the belt, pulley, & idler pulley assy.
Jul 20, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dec 27, 2007 | Kenmore 98702 Stacked Washer/Dryer
Open Questions:
Washing Machines Logo
74 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
