Question about GPS
I bought a used Magellan Roadmate 300 and it had a lot of directions saved in it. I tried to clear them off by going to user settings, then diagnostics, then repair to reformat internal memory. It completed this but would not do the ok at the end and now it comes up blank. It doesn't come up with maps or anything, what can I do to fix this? Thanks
    President:
  • 2,923 Answers
The only option to reset the Magellan Roadmate 300, is by going to Option button, then select User Settings. Since it's no longer loading the map or you cannot do anything, what you can do is to send the device to the manufacturer, and have them reset the hardware.
Thank you and good luck!
Posted on Jul 22, 2010
Can i get a instruction guide for a magellan 300
you can get a copy of your instruction manual HERE for the north american version.
for the Magellan RoadMate 300 Europe version, you can go HERE
bill
Oct 10, 2009 | Magellan RoadMate 300 GPS Receiver
Reseting the Magellan Roadmate 360 to the factory settings
Hello there:
here is a couple of linkds that i was able to retrieve hopefully they will help you ok
best regards michael
  1. [PDF] Magellan User Manual 3519k - Adobe PDF - View as html The Magellan RoadMate 800 is a vehicle ... segments totalling 360 degrees. Starting at the Prime Meridian (which is ... 11.2 Resetting the Magellan RoadMate ...www.magellangps.com/assets/manuals/MRM_800NA_en.pdf
  2. Magellan RoadMate 360 Manuals, Support and Troubleshooting - GPS Free download of Magellan RoadMate 360 User Manual. Troubleshooting ... Resetting the Trip Computer " • Viewing a Saved Trip Report " • Deleting a Trip Report " ...www.retrevo.com/support/Magellan-360-GPS-manual/id/421ag200/t/2 - 109k - Cached
  3. Magellan_RoadMate_360_North_America_Manual Documents_and_Forms ... Magellan RoadMate 360 North America User & Instruction ManualGet access the the ... Resetting the Trip Computer. Viewing a Saved Trip Report. Deleting a Trip ...store.payloadz.com/str-asp-i.388383-n.Magellan_RoadMate_360_North_America_Manual_Othe... - 189k - Cached
Sep 18, 2009 | Magellan RoadMate 360 GPS Receiver
I lost my manual for the magellan roadmate 360.
HI, info here http://www.gpsinformation.org/penrod/rm360/rm360.html
Also user manuals are on the magellen website
Jun 26, 2009 | Magellan RoadMate 300 GPS Receiver
Megellan RoadMate 300
You can find it here: http://magellan.cachefly.net/manuals/MRM_300na_en.pdf
You may also want to know that there is a MAJOR firmware update avaiable for your device.. It looks like it would make your GPS a lot faster and more accurate. You may want to take care of that update too while you're working on your device. The update can be found here: http://www.magellangps.com/support/notes.asp?supportID=288
Let me know if that helps!
Regards,
Steve
Sep 01, 2008 | Magellan RoadMate 300 GPS Receiver
Change the time on the magellan roadmate 1212?
I was in same situation with a magellan roadmate 1212. From what I can tell, the "daylight savings" is not what many of us may be accustomed to... that is, that it means that the location you are at follows daylight savings as happens with Windows or many other devices.
I bet those in Arizona never had a problem becuase they don't follow time zone... let me explain....
The daylight savings seems to state "are we currently under daylight savings time?" if we say yes (as you would normally state in your Windows computer setting (that would determine when daylight starts and stops and adjust pc time accordingly), the magellan 1212 instead will "ADD" one hour to the time stated by the Satellites regardless on whether it is summer ... or not.
So, if you happen to live in a time zone that follows "daylight savings" and you currently are under "daylight savings" time, then set it so in the "time zone".
So, there are two things you have to do:
/menu/user options/system settings/time zone/
1)Set your time zone
2)If currently under Set/unset the daylight savings set button to yes and manually move to no when not on DLS.
The explanation I found in MagellanGPS website is below, but never mentions what is the meaning (I should say effect) of the "daylight savings" button checkmark.
Magellan GPS receivers are not able to set the Time manually. In order to have the correct time set on your Magellan GPS receiver, you must set the proper time zone you are located in (ie Pacific, Central or Eastern). Once the time zone is set the exact hour and minute will display as information is received from the satellites. The following information will assist you on setting the time zone on your Magellan GPS. For Outdoor Triton series 200, 300, 400, 500, 1500 and 2000
  1. From the map screen press Menu and select View
  2. Select profiles and press Enter
  3. Select hiking and press Enter
  4. Press the Page/Go To key once and scroll down to select time zone
  5. Press Enter to select your time zone and Enter again to confirm.
  6. Press ESC repeatedly until you return to the map screen.
Note: Make sure Daylight Savings is adjusted accordingly. For Vehicle Navigation series Maestro and RoadMate 1200-1430
  1. From the map screen select Menu
  2. Select User Options
  3. Select System Settings
  4. Select Time Zone
Aug 29, 2008 | Magellan RoadMate 2200T GPS Receiver
Delete info
You can not erase a destination off the hard drive of your gps. When each one of the users gets full it will auto delite the oldest one.
Jan 08, 2008 | Magellan RoadMate 300 GPS Receiver
Magellan 300
Hi. For some reasons, my magellan 300 does not have any sounds. Anybody know how to solve this problem? Is there a reset button on this gps?
Nov 20, 2007 | Magellan RoadMate 300 GPS Receiver
Change language
You'll have to plug the unit into your computer using the USB cable and use Roadmate Manager :Settings" to change the language.
Sep 15, 2007 | Magellan RoadMate 300 GPS Receiver
Language on Magellan Roadmate 300
You'll have to obtain a copy of the Magellan Roadmate manager disks, load them into your computer, connect the GPS to your computer using the USB cable and the use the "Roadmate Manger settings" to change the language.
GPS Logo
177 people viewed this question
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
