Question about Microsoft Windows Vista Ultimate Edition
Screen goes black all at once, alot of letters appear, screen talks about a DATA ...., says insert boot disc and push any key. If I shut down and wait a bit, I can turn the computer back on and it works for awhile. Gateway One, ZX190, Vista operating system.
  • 808 Answers
Will be better for u if u repair ur window again
Posted on Jul 26, 2010
  • 75 Answers
If that problem started happening recently,we can try system restore
Click on Start->programs->accessories->system tools and then click on system restore
and choose a date when it was working fine
Keep me informed
Posted on Jul 22, 2010
How do i shut mac off then put start up disk in ?
Simple. Load the Apple System start-up disc first while the computer is running. You should see its icon on on the screen. Then select restart from the Apple Menu on the top left of the screen. Hold down the C key as it reboots. You will now boot into the start-up disc. This method also applies to Disc Warrior and other tools. Alternately, with the computer already running, insert the Apple System start-up disc then go to System Preferences also under the Apple menu, Under the start-up disc icon, select your apple system icon and restart.
Third alternative. With the computer running insert Apple System start-up disc. Restart the computer. Before the chime, press and hold the option key, left-hand bottom side of the keyboard to the left of the Apple (Command) key. You will see your system HD icon and the screen as well as your Apple System disc. Click on the System Disc and that will boot the machine.
Jul 09, 2014 | Apple iMac G4 Desktop
Acer aspire one flash BSOD then loops booting up
You can repeatedly hit the F8 key when you turn it on to get to the Safe Mode and other options. Select the option to Disable Automatic Restart so that you can see what the error is on the blue screen.
Try running the check disk utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
Jun 06, 2012 | Computers & Internet
Cannot load Windows 7 from hard drive. Possible with recovery discs.
Run the Check Disk Utility.
May 31, 2012 | Computers & Internet
Windows boot manager
So What about the boot manager?
Will your system not boot because it's missing or corrupt?
You will need a operating system disk or a repair disk to fix it. Insert it in the drive then boot from it. You want to get to a dos command prompt (black screen with white lettering) and type the following commands. Press ENTER after each command.
bootrec.exe /fixmbr
bootrec.exe /fixboot
bootrec.exe /rebuildbcd
Reboot and see if the problem is solved. If not get back to the dos command prompt and run the check disk utility.
May 20, 2012 | Computers & Internet
When the computer boots, it display bluescreen
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.If after running the Check Disk Utility you still have problems you will probably need to reinstall windows. Look into doing a Repair Install so that you don't lose your data.
Apr 24, 2012 | HEWLETT-PACKARD 630 Notebook
How do you go about to format a toshiba l650 and reinstall windows 7
Hi! If you have the Windows 7 disc just insert it restart the computer. It will boot directly from the disc. Then follow the step by step instructions here.
If you don't have the Windows 7 disc, you have two ways to reformat your Toshiba computer.
Using Toshiba HDD Recovery Utility from the recovery partition
In case of a hard disk drive failure, you may be able to restore the drive to the factory default state using the on-disk Toshiba HDD Recovery Utility (in a special partition on the hard disk drive).
You can select restoring the entire hard disk drive to the factory default state, or restoring only the C: drive -- without affecting other partitions (for example, a D: drive) -- or changing the size allocated to your C: drive, and then restore it.
To recover your hard disk drive from a system failure using the utilities stored on your computers HDD, follow these steps:
  1. If the computer is running, shut it down -- by clicking Start, Shut Down, and again Shut Down.
  2. Press and hold the 0 (zero) key on your keyboard and then press the computers power switch. When the computer turns on, the Toshiba HDD Recovery Utility screen will appear, presenting three options:
Sample TOSHIBA HDD Recovery Utility screen
Restore Original Factory Image (Recommended)
CAUTION:
Restoring a hard disk drive to its factory default state deletes all partitions on the hard disk drive and all data stored on those partitions. All of your files and information will be lost! Be sure to back up all important files first.
  1. Press 1 to restore your hard disk drive to its original factory default state. A confirmation message will appear, indicating that all data will be overwritten and lost during the restore process. Be sure to back up all important files before proceeding.
  2. Click Yes to begin the recovery. A message will appear once the operation is finished, indicating the HDD has been restored.
  3. Press any key to restart the computer.
* The options 2 & 3 are for advanced users.
Hard Disk Drive Recovery using Recovery CDs or DVDs
You may also wish to to run the Toshiba HDD Recovery Utility from Recovery CDs or DVDs that you have created.
Insert the first Recovery CD or DVD into your CD/DVD drive, and turn on the computer. Once the computer is running, the TOSHIBA HDD Recovery Utility screen will appear, presenting the same three options above. Again Press 1 to
restore your hard disk drive to its original factory default state. Click Yes to begin the recovery. Press any key to restart the computer.
Installing Drivers and Applications
The TOSHIBA Application Installer allows you to reinstall the drivers and applications that were originally bundled with your computer.
To reinstall drivers and applications:
  1. Double-click the "Toshiba Application Installer" icon on the Windows desktop. This utility may also be launched by clicking Start -->All Programs --> Hard Disk Recovery Utilities.
  2. Click "Next".
  3. Click the item(s) you wish to install. To select multiple items, hold down the Ctrl key as you click your selections.
  4. Click "Install".
  5. Follow the on-screen prompts to complete the installation process.
Hope this helps.
Jun 19, 2011 | Toshiba Computers & Internet
My screen is black or blank. when I reboot the computer the word "DELL" shows on the screen but then it goes black again. I shut down and rebooted several times with no luck.
boot files missing run a OS repair with OS disc recover and backup your data then do a proper clean OS installation to replace all kernel32 and boot sectors on boot drive
Nov 23, 2010 | Dell Vostro 1500 Notebook
My mac air stays on grey screen how do i get it to boot !
Insert your Mac OS disc and start your laptop with the c key held down. It will launch the system on the disc instead of your computer. Once it reaches the desktop, you can choose "Disk Utiltiies" from the menu bar and run a disc repair on your hard drive to fix any damaged OS file... then restart without the OS disc.
Nov 19, 2009 | Apple iBook G4 Mac Notebook
Compaq Presario CQ60 recovery disc how to use
insert the disc into the drive, restart the computer.If it doesn't boot from disc, restart again.
As it restarts, press and hold F8(may be F2 or F12 depending on the settings)until the boot options screen appears. Using the arrow up/down keys select drive "d" or what ever drive letter represents the drive you put the disc into.
It will now(or should) continue to boot from the disc, follow the onscreen instructions to restore.
Aug 27, 2009 | HP Compaq Presario CQ60-249US Notebook
Computer not booting up
hiiiiiiii ther
how r u ??
the boot disk is any OS bootble CD or disk start up
plz tell me more so i can hellp u
what is ur machine ?
what is teh problem ? is it running slow or u need to boot ?
and if u need any further assistance email me
u take care and have fun
salammmmmm {bye in arabic }
p.s rate me thanks
Nov 25, 2008 | HP Compaq Evo n610c Notebook
Microsoft Windows Vista Ultimate Edition Logo
137 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
