Question about Sport & Outdoor - Others
I have a 1992 vespa px200e and it takes at least 6 kicks to start it.do you know why this is and what i can do to repair it? thanks from matty
  • 706 Answers
Did you put back the choke? (under the fuel tap)
and you better change the spark plug (& plug cap too)
- if that doesn't help you need a carburetor service i have a 1992 vespa px200e and it takes at least 6 - a22c08e4-7ccc-4478-8e25-ed8f0cbfaaae.jpg
Posted on Sep 28, 2014
  • 41 Answers
There's a fair chance that on a scooter of that age, depending on usage and mileage, that you need to replace your piston rings. Cost about £10.
Posted on Jun 21, 2011
I just bought a 2009 Vespa and do not know how to start it. No owners manual came with it.
stick the key (brown or blue cover) in the ignition lock and turn right until lights come on on the imstrument panel - if yes you have the right key and the battery is on. then push the starter button at the right handlebar. If the battery is good the engine turns on....
Aug 28, 2016 | 2009 Vespa LX 150
Starting problems
first: buy a brand new battery
- this might solve the problem with starting without disassembly of anything....
Feb 02, 2014 | 2009 Vespa LX 125
How old is matty b
hi matty b rap it shelby Butler
Jan 11, 2014 | IDKJava Android Apps
Remove exhaust from manifold on a px200e vespa
To remove an exhaust manifold: 1. Locate your exhaust manifold, which differs in location depending the year, make and model of your car. It is usually located under the intake manifold. 2. Cool your car down completely. The bolts may break if the
VAG diagnostic tools
Nov 15, 2012 | Cars & Trucks
Removing vespa et4 kick start
in front of the kickstart lever is a nut bolt which you must unscrew.
- but before you do that you need to mark the precise position on the lever axle with a permanent marker - after removing the bolt you can tear off the lever (use WD40 and wobble action)
Jul 07, 2012 | Vespa ET4 125 Motorcycles
My Vespa ET2 will not start when it's off the kickstand. Starts fine when the bike is on the kickstand. Engine cuts out when i push the bike off of the stand.
I'm not familiar with ET2s but I had a similar problem with a Vespa 100 years ago. After hours of messing about i discovered a bolt had fallen and blocked one of the air inlets on the bottom of the frame. Was fine when i kicked it but when my bum was on the saddle it kinda 'sealed' around the tank area and starved the engine of air. As i say, i don't know about new ET2s but sounds kinda similar symptoms.
Apr 13, 2011 | Peg Perego Vespa Scooter
When i kick my scooter(vespa 125cc) off its ok if i stop and it cools down it wont kick off but if i bump it off it fires up ok
I don't know much about Vespa scooters but from what you're describing, your valves need adjusting. If the valve is standing open as little as one thousandth of a inch, you won't have enough compression to start the engine at kick starter cranking speeds. It will start when you push the scooter and bump it off. This is because you get a higher piston speed allowing the engine to start before the compression has time to bleed off. Check the valve adjustment,especially the exhaust valve.
Oct 17, 2009 | Bajaj Chetak Motorcycles
I have a Vespa Won't start.
sound like your starter motor has given up the ghost.
Cheers Dan
Jun 08, 2009 | Peg Perego Vespa Scooter
Vespa cutting out after around 40secs of running
getting to much fuel apparently.But have never seen or heard of one of these.
Dec 22, 2008 | Peg Perego Vespa Scooter
Sport & Outdoor - Others Logo
244 people viewed this question
Top Sport & Outdoor - Others Experts
Marvin
Marvin
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
