Question about Canon imageCLASS MF6530 Monochrome Laser Copier/Printer
How to get copy count for Canon Imageclass MF6500?
    Brigadier General:
  • 10,406 Answers
Tell it to print a "self-test" page. Some of the printed output will be the copy-count.
Posted on Jul 22, 2010
Tip
Canon Imageclass MF6500 Series Copier with Blank Copies Prints Problem
This tip works on all Canon Imageclass 6500 series machines including the MF6500 MF6530 MF6531 MF6540 MF6550 MF6560 MF6580 MF6590 and MF6595.
First of all if you are experiencing blank copies and or prints the best thing to do is try a different toner cartridge. In rare cases the black copies/prints CAN be caused by a defective cartridge. In MOST cases it is caused by a broken or detatched laser shutter lever or arm. When a toner cartridge is inserted and the door closed, a small plastic arm opens the laser shutter. If this arm is broken or has become disconnected then the shutter is not opened. This blocks the laser from writing the copy or print image onto the drum and this results in no print being applied to the paper. If the arm is broken you CAN open the laser shutter manually and block it open. What you need to do it open the cartridge access door, remove the cartridge and look for a 1/2 inch wide slot running from left to right in the metal frame that is in the back upper section where the cartridge goes. The plastic arm that operates the black plastic shutter is on the right side. If broken you can manually lift up the shutter and "block" it open using something like a folded up scrap of paper. I know it sounds strange but I have used this repair on several of my customers machines and they have all worked fine since. If you can not find or effect the repair yourself at least you will know where to point the service person when they come out to look at it.
Good Luck and Thank You for using Fixya.
on Nov 02, 2010 | Office Equipment & Supplies
I am using the canon image class mf6500 and i can't scan. where do you get the driver for it?
Go to:
Canon MF6500 Series Support
If the Drivers & Downloads tab is not selected, click on it.
Although it shows a MF6550 at the top, the software and manuals are for the 6500 series of printers. There are guides for printing and scanning further down the list you can download too.
You do not say what operating system you have, but there are only drivers for Vista and Mac OS.
Thanks for using Fixya.
Nov 04, 2009 | Canon imageCLASS® MF6550 All-In-One Laser...
CANON COPIER IMAGECLASS MF6500
It needs a new image processor, hope its still under warranty. The part retail is around $400.00 I just ordered one for someone today!
Jun 15, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
Canon ImageClass MF6500 Message on machine ''Download Standby''
My Xerox copy centre C123 shows error code 124-315
and the message says to Switch off the machine and turn it on
Feb 16, 2009 | Canon Office Equipment & Supplies
I have a cannon print mf6500 and i have a littleproblem , i want to reset it to have the defaul setting .
Check the manual:
Or this link:
http://static.compusa.com/pdf/canon-imageCLASS-MF6500-Series-ScannerDriverGuide.pdf
Jan 23, 2009 | Office Equipment & Supplies
Code E808
This problem was solved by turning off the unit and unplugging the power overnight. The next morning it worked fine.
Jan 15, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
Light Copies Canon imageCLASS D320
hi im jules_09,check the developer,if its past over 60,000 copies if its over 60,000 copies you need to change the developer along with the opc drum and cleaning blade or roller,all copiers need to be replaced with new developer,opc drum and cleanign blade or roller when it reach its copy life,that may be the cause of light copy of print
Nov 21, 2007 | Canon imageCLASS D320 Digital Copier
Canon imageCLASS MF6530 Monochrome Laser Copier/Printer Logo
1,176 people viewed this question
old marine
old marine
