Question about Gateway FPD2275W LCD Monitor
My monitor does not turn on and the power button light keeps blinking ...
  • 4 Answers
This is usually a sign that there is no signal going to your monitor, check all your cables and then reboot.
Posted on Aug 08, 2010
Fan noise and blinking blue power light
green=power in motherboard.
blue=stand by.
yellow=memory powerd
Jun 13, 2013 | Gateway GT5622 PC Desktop
My moitor fpd1975w blinks blue power button and a white screen but does not turn on ?
The blinking power light is a good indication of a failed power supply board and the white screen backs that diagnosis up. Here is a link to information show what to look for and replace on the power supply board to get the monitor back up and running again. The repair involves replacing parts called capacitors on the power supply board and can be done in less than 20 minutes once you have the parts needed.
http://www.ccl-la.com/blog/index.php/gateway-fpd1975w-monitor-repair/
I hope this helps,
BuddyMc
Oct 09, 2011 | Gateway FPD1975W 19" LCD Monitor
How do I turn it on
Hello.
To power on the Gateway VX750, press the power button on the front. The power button has 3 sides with a "G" in the middle.
The LED indicates the power status of the monitor.
  • Not lit - The monitor is turned off or does not have power connected.
  • Blinks one time and then goes off - The LED blinks one time when the monitor's power cord is plugged into an AC outlet to indicate that power is detected.
  • Lit solid blue - The monitor is turned on and active.
  • Blinking blue - The monitor is in power saving mode. Before entering power saving mode, a message briefly appears.
Hope this helps.
Aug 12, 2010 | Gateway VX750 (Black, Platinum) 17" CRT...
My Gateway monitor light blinks blue slowly but the screen is blank. I rebooted, and the computer came on, but the screen doesn't. We plugged in an old monitor, and it works. Does the slow-blinking blue...
More likely to be problem in the power supply.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 11, 2010 | Gateway FPD2275W LCD Monitor
VL 1919 power button blue light blinks and screen
Yea I fixed it ..bought a new monitor......I tried the old monitor on two other PC's same problem.....
Nov 23, 2009 | Computers & Internet
No picture - blinking blue light. My daughter was
There are a few things you can check. First, try to see if the monitor cables are firmly connected on both sides (computer and monitor) no need to remove any cable for now just check the monitor cables (ends should be blue or white on both sides) Then check if you got an imput button on your screen (like all TV and some monitors now has) This input gives you the choice between a few possible connections and it may be on the wrong one. Just cycle trough the input modes and I think you will have your image back. If Still, you dont see anything, try a different monitor or try to connect your monitor on a different PC/laptop. In fact blinking blue could be there because the monitor is awaiting a signal on the input it's listening. At worst it could be because your video chip/card dont send a signal to your monitor, could happen, but imo it's probably not the case.
Jun 08, 2009 | Gateway 1532121 Monitor
Blinking power up button
Its a powersupply problem in your LCD screen, i had the same thing happen to me- i found a site where you can fix it yourself- heres the link. http://computerguru365.blogspot.com/2008/01/fix-that-lcd-flat-panel-monitor.html I did it and it works.
Apr 01, 2008 | Gateway FPD1975 19" LCD Monitor
Gateway FPD2275W LCD Monitor Logo
498 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
