Question about Splendide 2000S Front Load Washer / Dryer
SPLENDIDE VENTED WASHER-DRYER (LAVANTE SECHANTE COMBINEE WILL NOT START. ADVANCING WASHING CYCLE KNOB (NORMAL WASH MODE) WILL START CYCLE HOWEVER IT WILL NOT COMPLETE CYCLE,
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
WASHER WASHES BUT DON'T DO ANY THING TO DRY
Posted on Jan 31, 2017
2 Suggested Answers
  • 4 Answers
SOURCE: splendide 2100 vented washes clothes just fine but
This means that the washer has found something wrong and it is going to a diagnostic mode. When the knob starts going around, immediately begin counting how many times the red light blinks. Call Splendide and they can diagnose the error from the number of blinks you counted. I would recreate the problem more than once so you know that you counted right.
Posted on Aug 28, 2009
Cycle selector knob clicks forward
PDF]Repair Manual - Splendide
www.splendide.com/service/TRAINMANM_Complete.pdf
WD802M (Splendide 2000). WDC1025M ... 6SOHQGLGH¥. Front Loading AutomaticWasher Dryer ... Description of Preset Wash Cycles / How to Set A Wash Cycle ONL: 21. Description of .... may appear to work well after repair is finished, but failure may occur at a ..... rear of the main top, then slide forward. Removing the ..
Sep 19, 2015 | Splendide 2000S Front Load Washer / Dryer
Wd2000 washer dryer combo timer advances around timer
If the program selector knob keeps turning, the machine needs to be reset.
Wait a few minutes for the drain pump to empty the tub, switch the washer-dryer OFF. Select one
of the Reset positions on the knob, then switch it back ON.
The link below will take you to the manual.
Hopes this helps.
http://www.splendide.com/manual_wd2100_2000s.pdf
Oct 12, 2014 | Splendide 2100 Vented Washer-Dryer
Splendide 2000S Vented Washer/Dryer makes a bad noise once in the rinse cycle and water will not drain
Check the drain pump. There may be a coin, hairclip , button etc stuck in the blades of the pump. If the machine cant pump out, it wont go through the cycle.
Sep 17, 2017 | Splendide 2000S Vented Washer/Dryer
My Splendide 2000 combo stops midway in the wash cycle. What is the cause and how can I fix it please?
If it doesn't go from the wash to the dry, check to make sure that both the washer and the dryer are set before the start of the cycle. It also could be blowing a fuse.
Michael Lee
Thor Appliance Company
www.thorappliances.com
Sep 13, 2010 | Splendide 2100 Vented Washer-Dryer
Unit runs good through wash cycle then while in rinse and spin does not complete cycle. The machine starts doing a short spin, and then dial starts turning around without stopping.
Sounds as if the drain pump is not ejecting the water fast enough. Did you notice of the washer is draining more slowly than usual or at all?
Feb 14, 2010 | Splendide 2100 Vented Washer-Dryer
My timer knob on my Splendide 2100 keeps going round and round
This is a onboard diagnostic system. As soon as the knob starts going in circles start counting the red light blinks. Then call Splendide. Let them know what is happening. When they ask tell them the number of light blinks that occurred and they can tell you what the error code is.
Aug 12, 2009 | Splendide 2100 Vented Washer-Dryer
Splendide 2100 vented washes clothes just fine but now when it goes into the dryer mode just roates the knob around without doing anything. This only happens in the dry mode.
Jul 07, 2009 | Splendide 2100 Vented Washer-Dryer
Splendide 2000 doesnt work at all on wash
I have exactly the same issue. The door normally locks, but doesn't do anything on wash.
Jul 29, 2008 | Splendide 2000S Vented Washer/Dryer
Washer doesn't agitate
sounds like your washer went mellow on you(doesn't get agitated, right)?
ok. enough humor.
sounds like there's a problem with the motor/belt/control board in that order
Mar 13, 2008 | Splendide 2000S Vented Washer/Dryer
2100 Splendide
The cycle knob rotating means the machine is in self diagnostics mode. You need to count the flashes that the led is giving, they are in 1 second intervals then repeats after a 5 second pause. Mine had 13 flashes and after contacting Splendide they say it was either a broken wire or a bad ETC sensor. With the help of a Ohm meter it turned out to be a broken wire. Mine is a 2100 vented by the way.
Jan 13, 2008 | Splendide 2100 Vented Washer-Dryer
Splendide 2000S Front Load Washer / Dryer Logo
154 people viewed this question
Top Splendide Washing Machines Experts
Marvin
Marvin
Philip Diggins
Level 1 Expert
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
