Question about Gateway T-1620 Motherboard - 40GAB1800-F220
My Gateway T 1620 laptop has an issue with the power supply connection. The laptop does not always "sense" that the plug is inserted and operates as if it is unplugged. We tried to plug it in the same orientation but that does not always work. Sometimes we can plug it in and it works and sometimes we can move the plug around and it will work and sometimes it just does not work and we leave it alone and it starts working (most curious). What do you think?
  • 734 Answers
Hi There,
Gateway Laptops are widely known for this issue. It means your DC Power Jack is coming loose on the motherboard. This is a problem which will only increase in dimension. I used to replace them myself, but there are now many choices on eBay that make my replacement efforts unmarketably priced. These companies use advanced equipment to do the replacement.
If you go on eBay and enter "DC Power Jack Repair" in the search box, you can shop for deals between the different companies. Turn around time is usually about a week total and the price averages out around $100 or a little more including shipping. I have used several different companies and the result was the same; perfect repair, courteous treatment and quick service.
The sooner you deal with it, the better off you'll be. Defective DC Jacks can cause widelty different problems as they worsen which will confuse the issue and expose you to other diagnoses which can be way wide of the mark and much more expensive.
Be well.
Posted on Jul 22, 2010
So the gateway laptop i have e475m it won't turn on or no lights when plugged in. The battery will charge when the laptop is plugged in.what the issue and how to fix it
Try removing power supply and main battery. Remove HDD and RAM. Plug in power supply and press ON. It should complain that there is no hardware. If it does, replace one RAM stick at a time and repeat powering up. If now OK replace the HDD. If nothing, the motherboard has issues, possibly GPU.
May 27, 2016 | Gateway Computers & Internet
Not charging
Sounds like the ID chip in the battery pack has gone bad. This is a common issue with dells.. Otherwise your looking at the sensing circuit of the motherboard. If you know someone else with the same power supply as you try there power supply and see if it works.. If you continue with the same issue then contact the reseller and look into warranty repairs.
Oct 27, 2013 | Computers & Internet
How to connect to a laptop
Lexmark is one of the most popular printer manufacturers, and the installation process is fairly straightforward no matter what computer brand you have. Lexmark, however, doesn't always include all of the equipment required to hook up the printer. If you want to hook up your Lexmark printer to your Gateway laptop, you will probably need to purchase a printer USB cable.
1.Plug your Lexmark printer into the power outlet.
2.Turn on your laptop, or make sure all software programs are closed if your computer is already on.
3.Insert your installation disk into your Gateway laptop's CD or DVD drive. Wait for the "Welcome" screen to appear. If it doesn't appear after a minute, launch the installation CD manually by going to your start menu and clicking on "Run." In the "Run" field, type: D:\setup.exe
4.Press the "Install" button on your "Welcome" screen to go on to the "Introduction" screen.
5.Press "Continue" on the "Introduction screen" and press "Continue" again on the "Read Me" screen. Agree to the license agreement and follow any additional installation prompts.
6.Connect the Lexmark printer to your Gateway laptop when prompted. Plug the USB cable to the back of the Lexmark printer in the "Quick Connect Laptop Port." Then plug the other end of the USB to your Gateway laptop.
I hope you find it very helpful. Thank you for using fixya.
Aug 19, 2011 | Lexmark X4650 InkJet Printer
Gateway Laptop it not powering with or battery or plugged in
Try to connect AC/DC power supply to your PC. If it works there is something wrong with your DC Battery. If you have done this, try to use tester to test if the power battery can still transmit power from source. If power is down, may be another kind of battery that is compatible to your PC. Insert only battery required for your laptop that would destroy your PC totally.
Jun 19, 2009 | Gateway Computers & Internet
I'm trying to fix a gateway MFATXNIN NMZ 500SE
Check the adapter with a multi-meter to see if there is voltage at the plug that connects into the laptop. The oltage reading should be slightly higher than the voltage that is printed on the label on the adapter.
Try to borrow an adapter (same as yours) and connect it to your laptop. Also try removing the battery and power up the laptop without the battery but with the adapter connected (could be a battery problem).
Mar 29, 2009 | Gateway NMZ-500SE Notebook
Plug in power cord and push power button, nothing comes on
Yup Yup I had the 28, same problem, the issue is within the adapter plug itself, I ended up taking my laptop apart and hard wiring the the connections directly into the wires that came off the plug, it was the only way to solve the issue without ordering the part from gateway,,,this is a image of the device that is causing you this misery.
t
http://cgi.ebay.com/DC-Power-Jack-For-Gateway-MX3212-MX3215-MX3225-MX3228_W0QQitemZ330288544158QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item330288544158&_trksid=p3286.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
Nov 21, 2008 | Gateway MX3215 Notebook
Gateway M460E Wont power up
not good..sounds like either the power supply has not enough juice, or the mother board is unhappy..check the power supply for proper voltage as indicated on bottom of the power supply..
Oct 16, 2008 | Gateway 400E (400EB) PC Notebook
Hi, My Gateway MX3215 notebook computer no longer powers up with the AC plug. The battery was 5% and the AC plug was connected when the computer died, and it has not come back since. I have plugged in the...
Make sure you have power at the wall outlet (Dumb question, but I have to ask). If your AC power cable is detachable from the laptop transformer, make sure it is plugged in tightly. If there is a LED on the transformer, make sure it is on. If you have a voltmeter, check for DC voltage at the power supply plug where it plugs into the laptop. You should have between about 10 - 14 volts there. If you don't have a voltmeter (or multi-meter), see if you can borrow one.
If your battery was not seated properly or was worn out, then obviously it would not charge, but the laptop should still function off the power supply, so it is probably not a battery issue. If the voltage input and cable condition checks out okay, then it is probably a bad power supply.
Sep 11, 2008 | Computers & Internet
Gateway T-1620 Motherboard - 40GAB1800-F220 Logo
141 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
