Question about Dishwashers
Blanco BFDWC65X dishwasher. Has broken handle. Have been informed that the handle cannot be replaced and that the whole front electronic panel needs to be replaced. Is this correct? Can you recommend a repairman in Brisbane?
  • 10,865 Answers
Hello. Generally the handle can be replaced or repaired with epoxy. Call the local appliance stores as they have lists of local repair persons. Try to get one familiar with your dishwasher. J.
Posted on Jul 22, 2010
How do I replace the cartridge on my 157074R-ST. I'm a little handy, but I have a bad back. Can the repair be completed without going underneath the sink?
This is an easy job.
The only thing to do under the sink is to turn the water off.
The hard part is finding the replacement cartridge (Blanco #2408).
Once you do that, simply remove the handle (undo the set screw in the front, below the temperature indicator,) and remove the lock nut that holds the old cartridge in place.
Lift the old cartridge straight up and out, put the new one in its place, and replace the nut and handle. The whole job will take you ten minutes, from start to finish. (Remember to turn the water back on.)
I've attached a parts breakdown:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0CFUQFjAC&url=http%3A%2F%2Fwww.wdcappliances.com%2Fpdfs%2F440652.pdf&ei=cSCTU8fVLcO-oQSe74CIBQ&usg=AFQjCNHkRKgAx1cbIaGdtfDPk4jSEf7Fuw&sig2=ZORVc7a3zktBNAX9s61QhQ
Apr 18, 2014 | Blanco Plumbing
My Dishwasher won't start unless I push firmly on the door.
Change the handle there is a switch on the handle that activates when the door is closed the switch is broken you have to buy the whole handle not just the switch
Apr 11, 2013 | GE Dishwashers
Blanco Dishwasher
the handle has a switch which also controls distribution of power to the unit this switch makes sure the door is closed in order for the unit to operate a safety feature to prevent flooding. And there are sometimes fuses on control boards. Although i think it is your door safety switch.Remember to rate my solution and leave testimony this is how i earn achievements here on FixYa Thanks in advance
Apr 25, 2012 | Dishwashers
The front panel is broken
http://www.4bosch.co.uk/cgi-bin/product.pl?PID=906106&brand=&model=sgS43E02gb%2f45&part=dishwasher%20panelI have this dishwasher with the same problem and tonight the whole panel broke off.Not sure what I am going to do yet as the dishwasher works perfectly except for this but is 6yrs old.
Jul 25, 2010 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
The handle to open the door broke...can you replace the door?
notify maytag or any appliance parts/repair store or online most online parts stores have exploded views of part replacement u will only need to replace the broken handle not the whole door
Jan 19, 2010 | Maytag 24 in. MDB7650AWS Built-in...
Handle is broken.. how to replace?
This is not a difficult repair. If the model number you have this listed under is correct, all you should have to do is follow these steps:
1. Turn off the power breaker, or unplug the dishwasher.
2. Open the dishwasher door and locate the screws around the perimeter of the inner door panel. These are torx, size T-2, I believe. Remove the screws directly behind the control panel and only loosen the remaining ones. This will enable you to remove only the control panel without having to remove the entire front panel facing.
3. If only the handle is broken, all you have to do is remove the the screws holding the latch assembly in place and lift out of the way. The door handle should lift out from the rear and a new one can easily be inserted.
4. If the latch assembly is broken, I would recommend replacing the small switches that plug into the latch assembly as well. They typically break when attempting to unplug the wires from the terminals, because they are so fragile.
Appliancepartspros.com has all the parts you need, along with some excellent exploded view diagrams you can use for reference. The parts that I am talking about are items 3, 4, and 5 under the "Control Panel" heading.
Item 3 is the Door Handle
Item 4 is the Door Switch
Item 5 is the Latch Assembly
Here are some more sites you may also try for cost comparison:
searspartsdirect.com
pcappliancerepair.com
repairclinic.com
If you have questions about this repair, or if the model number is not correct, please post back with your complete model number so that I may be able to provide you with better assistance. I hope you find this information helpful.
Aug 22, 2009 | Maytag MDB9600A Jetclean II Built-in...
The handle on my Maytag Quiet series 100
I had the same problem with my QS 100. I disconnected power first via the breaker then removed the 11 screws. I couldn't loosen the two electrical connections, but the door pulled far enough away to inspect the handle mechanism. The plastic handle fell out of whole handle assembly rather easily because two molded plastic pins protuding from either side had broken off and were loose inside. There was also a pair of molded plastic v-shaped forks right on the panel to hold the handle assembly and these were damaged but they just to seem to act as guides only (as the handle assembly is held in by two of the screws that were removed). Replacing the v-shaped forks would require a whole new door which I am NOT doing. It looks like I can a replacement handle in the same color with new pins (I am reading they may now be metal) for about ##15. Pretty easy to disassemble and inspect, only about 15 minutes.
May 29, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Door handle will not engage with latch to open door.
yea but the trick is the latch acces is behind console not the front panel, you need to unistall the d/w slightly to remove strike plate holding broken latch closed, door needs to be opened to gain access to console screws
Feb 22, 2008 | Dishwashers
Broken door handle Indesit dishwasher DG 6100
I agree read "broken door catch" solution and be particularly careful in respect of the edges of the stailess steel panels - some of the edges are hidden and they are very sharp.
Jan 29, 2007 | Indesit 24 in. D61 Free-standing...
Dishwashers Logo
356 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
