Question about Ricoh Aficio 1232C Color Copier
Ricoh 1232c What does the Ricoh part number AB040020 SPRING CLUTCH look like ,is it the black cylinder with the raised notches on it whic the white cam locates on.
  • 313 Answers
If you look at the white cam you will see the black cylinder it has a spring inside .. you have the right part everytime you do a copy the clutch actuates the and presses the transfer roller onto the back of the page which then presses against the transfer surface and causes the image to be transfered onto the page .. if faulty the image is week or can be of variable quality..Andy
Posted on Jul 22, 2010
Ricoh 1232c sc 672
The correct way to get into service mode is to first press the Yellow "CLEAR" button then press the numbers 1 >0>7 then press and hold the Red "STOP" button.... Good Luck
Jun 08, 2012 | Ricoh Aficio 1232C Color Copier
What is SC305 Error Message - Ricoh 1232C On
I worked on this same code just the other day for a customer. This SC305 code means the charge corona cleaner is not working properly. The charge corona is located behind the large front door, towards the bottom and just left of center. It has a small thumb screw and a white cord with an end on it like a telephone cord. You can try removing the assembly and blow it out carefully with canned air. Be careful about the very thin hairlike wire in the shell. You can also remove the end of the unit and check that the motor is not gummed up. If it is just put a little light oil on it. Just cycle the power off then on again to reset and try.
Usually once they get repositioned properly they will work fine. Sometimes I have replaced the unit with one from a parts machine.
Good Luck and Thank You for using Fixya.
WheatlandServices
Sep 27, 2010 | Ricoh Aficio 1232C Color Copier
On my 1232c the transfer pressure roller is clicking in and out as printing causing faint lines on print.
the clutch at the transfer roller is faulty if you open the side door and look on the rear frame there is a white cam this actuates the transfer roller at copy stage you need to replace this the ricoh part number is.......AB040020 SPRING CLUTCH..the clutch is attached to a cam actuator at the rear held on by a clip and a spring..you will need to remove the back cover and the side cover at the rear to replace the unit..
Jul 19, 2010 | Ricoh Aficio 1232C Color Copier
Ricoh Aficio 1232C rpcs When I try to print the red light appears on the printer saying 'load by pass tray' even though I have selected Auto tray. Normally the machine prints fine.
when you selected auto tray was that in the driver or microsoft settings ? microsoft settings will overide the copier settings driver. look under file then page setup to see what it is set for.
May 20, 2010 | Ricoh Aficio 1232C Color Copier
Ricoh Aficio 1232c REFILL
You can't use any other brand of color toner to refill the AF1232, you'll have all kinds of issues. They do have compatible toners (generic) for that model but highly recommend OEM.
Mar 31, 2010 | Ricoh Aficio 1232C Color Copier
I am seeking to purchase a Ricoh Aficio 1232c
Are you stuck with just the 1232 or do you have a choice of models? The 1232 is getting pretty dated and is uses a single drum belt/transfer unit that is very expensive to replace. The models that followed use individual drums/dv units for each color so your risk of a very expensive part is less. The biggest factor in used copiers, especially color machines is what maintenance has been done to them and what is the copy count status of the consumable parts. The color speed on the 1232 is also very slow. What is your primary use for the machine? Meaning mostly black and white with a little color usage or is it mostly color you need?
Are you planning on buying from a dealer and getting a maintenance contract?
I'll start with this and see where we go from here.
Mar 01, 2010 | Ricoh Aficio 1232C Color Copier
Ricoh Aficio 1232C prints with red-violet tone
download the RPCS driver from the Ricoh support site and then when you will install the driver go to preference then user settings and adjust the contrast and other options until you get the color of the printed image as you wish to be
Dec 14, 2009 | Ricoh Aficio 1232C Color Copier
Incomplete copying/printing. Full page not copying, just 3/4 of the page, whether b/w or colour. when photocopying or printing only a thrid of the text or image is printed.
Check wether the transfer belt cleaning unit inside the photoconductor unit have wrong cleaning cycle due to the defective cleaning clutch.
Oct 02, 2009 | Ricoh Aficio 1232C Color Copier
Ricoh aficio 1232c. The registration clutch SP 5804-11 is not making clicking sound in output mode. It jams at point B when duplexing. What part do I need and would cleaning this reg clutch out help?
you need a new registration clutch then probably part number is AX20 0240 i believe but if the reg clutch is faulty i would usually replace all feed clutches at the same time other part numbers are AX20 0239 relay clutch x 2 and AX20 0224 feed clutch x 2
Nov 26, 2008 | Ricoh Office Equipment & Supplies
Ricoh Aficio 1232C Color Copier Logo
63 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
