Question about Canon S520 InkJet Printer
Canon S520 Printer won't print black!
My Canon S520 printer won't print black ink!
I've tried the "clean printer heads" option in the printer maintenance menu, and it still will not print black ink.
I have even replaced the ink cartridge, yet it still won't print black!
Any advice or solutions? Thanks in advance!
    Habit-Forming:
  • 159 Answers
This printer model use printhead separately from cartridge. The problem is the printhead cloged. To fix this, you take the printhead off and put it on hot water (just the part with printing on paper) for about 2 hours, or overnight. After this time, clean the printhead very well until is dry, (to avoid damaging the prinhead) and put it again in printer. If doesn't work, leave it for more time. A good tip is to use ultrasonic cleaner.
Best wishes !
Posted on Dec 30, 2017
    Habit-Forming:
    New Friend:
  • 83 Answers
Hi.
Remove Black cartridge,
make sure its not dry, if that's ok make sure that the small air vent is not blocked (hard to find sometimes)
SOURCE: Print Cartridge Problems
I just replaced both the black and color cartridges (empty) with new replacement cartridges - Office Max brand. I couldn't get any e-mails or documents to print, although I could get ink on paper when running the Nozzle Check and Print Head Allignment. That doesn't make sense!
I e-mailed Canon Tech Support and was told to use only Canon cartridges. I bit the bullet, went out and bought another black cartridge - this time Canon brand, installed it ,and my printer now works - including color printing.
The color cartridge is still office Max brand. My printer now says I have black ink, but still says the color ink is low (even though it's full).
Conclusion: The Canon printer only works properly with Canon cartridges!
Posted on Aug 13, 2008
Scott Ellin
  • 558 Answers
SOURCE: Magenta ink will not print
It might be getting problem with the sensor of the Printer which intact to the Cartridge. It need to be diagnose and repair.
Regards
Ellin
Posted on Sep 26, 2008
SOURCE: canon pixma ip500 horizontal bands of non-printing areas
Hi it's Gill again. I've been looking around more on the net and I think the problem is our printers need new printheads which I'm told are spare parts easy to change. Hope this helps. Gill
Posted on Apr 03, 2009
SOURCE: My Canon mp390 printer doesn't print
I had this problem several times, had to buy new print head until I found that to clean it you should use ammonia. It really worked for me. You should really try ammonia it does work.
Posted on Jun 14, 2009
  • 157 Answers
SOURCE: Canon MP950 - strong black line on back side of the paper
The problem is most likely your ink catcher, it is a sponge that catches any ink when it is being cleaned. you need to remove it and clean it then put it back in. there will be instructions in your manual.
Posted on Jun 21, 2009
My printer will no longer print in black s520
if it is a new black ink cartridge and the printer still wont print black start by:
A: Simply making sure the settings are ok. To do this, go to file>print. When the printer box shows up. click properties.
From there, you will be able to see color settings. (ex. black, grayscale, full color.) Try switching to black or "use black cartridge only.
B. If "a" does not work for you, the print head which hold the ink cartridge is clogged or no longer working. Through the cannon window on the printer, try running a print head cleaning or any maintenance program.
If there's still no black, the print head has seen better days and needs replacing. Most of the time it is more effective to get a new printer.
May 22, 2011 | Canon Office Equipment & Supplies
I have replaced the black ink in my canon s520 but printer will not print out black
Please check the seating of black ink cartridge. It may not have been placed correctly. Please replace it and then carry out the print head alignment.
Aug 04, 2010 | Canon S520 InkJet Printer
It doesn't print in black but prints in color
Hi, To ensure this is only an issue with the black, I recommend printing off a nozzle check. This will show you if this problem is effecting any of the other colours.
To print a nozzle please refer to chapter 12 page 115 of the manual,
If colours are missing I recommend cleaning the print head. You have two options for cleaning the print head a normal clean and a deep clean, start by doing a normal clean if required try doing a deep clean.
You can download the manual here:
http://www.fixya.com/support/p360568-canon_multipass_mp390_all_in_one_inkjet/manual-10203#
Dec 01, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
7 orage light blink on my canon s520 printer
Take printer head and cartridges out - remove cartridges - wash printer head in hot /warm water for 30 mins - dry - place 5 drops of alcohol- metho - no drinking - on each noozle and let stand for 5mins. wash printer head in clean hot water for 10 mins - dry - clean outlets of cartridges with 3 drops alcohol - hic - remove scum layer until colour shows ie black,cyan, magenta & yellow - set into printer - set test page - stand back and admire the quality print of your new printer - RC
Aug 28, 2008 | Canon S520 InkJet Photo Printer
Canon s520 printer
Try changing your type of paper setting.
Jul 21, 2008 | Canon S520 InkJet Photo Printer
S520 will not print in any color
If you have tried to print a nozzle check page and no ink has been deposited on the page, then it might be a bad logic board inside the printer or a faulty purge unit. Both parts are relatively expensive to purchase. You might be better off looking for a used Canon s520, i550, i850, pixma 3000, or similar model to use the remaining ink cartridges if you can locate one in good condition and not more than 40 USD. xcd187
Oct 03, 2007 | Canon S520 InkJet Photo Printer
Black jet not printing
re-install the driver and see. bye
Sep 23, 2006 | Canon S520 InkJet Photo Printer
156 people viewed this question
Clive
Clive
old marine
old marine
