Question about Microwave Ovens
My krups mixer KB710D41 /861 -4506 R (2 years old) - seems to leak when used the bottom seems no longer well attached. how many "fastners" does it have in the black platic bottom part? mine seems to have two onlly - is that how they are made? and if it is leaking what can be done about it? thanks for any help. adriana
5 Suggested Answers
  • 63 Answers
SOURCE: MY FIGIDAIRE GALLERY SERIES MICROWAVE IS LEAKING BLACK OIL
hi my name is mark, if nothing boiled over in the microwave. the oil could be coming from a capacitor in the microwave oven. i would call for service before it fails.
Posted on Mar 16, 2009
SOURCE: My krups xp7200 is leaking water from the bottom.
You need to unscrew 4 screws in the front, three on the top (underneath the lid where you put the cleaning tablet), one inside the coffe container at the top, and pull gently, but firmly the little black nob inside the coffe container, that you use to adjust the coffee grinding, straight up. Then you can remove the coffee container on the top, and unscrew one screw underneath this container. Also, remove the two screws from the holes beneath the water container. NOW, you should be able to pull the front electronics off, and pull the main cover backwards, away from the front panel. You may have to bend it a little to get it completely off, but it is not a problem. Good luck! :)
Posted on Oct 20, 2010
alicantecoli
  • 22306 Answers
SOURCE: ficher and paykel 10 years
check this out i think it should have a pipe that feeds this water into a container on top of the motor where the heat of the motor evaporates it away ,could be you havent seen it or a mouse has eaten it or the pipe has just perished with age and fallen off ,pull it out and have a good look and i do feel you see what i mean
Posted on Dec 07, 2010
SOURCE: we have an 8 year
I have the same model, same age, same problem. It appears to be the seal between the metal heating coils, and the plastic switch that selects steam or coffee. Possibly caused by no cleaning the injector hole with the tool provided with machine (which causes a lot of back pressure). On mine, the screw that holds the switch to the heater has corroded and can not be unscrewed, so not possible to access rubber seal, and repair. May be tricky since this is plastic sealed to hot metal with a rubber gasket. So fo now, i unscrewed the black base plate on the bootom, and set the Alessi in a tray. THen just wipe up water after use.
Posted on Mar 01, 2011
Attempting to obtain instruction manuals for: Moulinex Masterchef 75(Electronic) Krups Mixer/Blender Set ST 3000
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Mar 22, 2011 | Microwave Ovens
I have a 2 year old LEC T2856w fridge freezer and the fridge keeps freezing everything, it seems to be warmer at the top and makes a wall of ice on the back
That sounds like an a refrigeration engineer is required as if the gas pressure has dropped, it will no longer cool properly.
Mar 07, 2011 | Microwave Ovens
I have a very old mixer, a hamilton beach no.18. I have a basic understanding of how things work, but this has me beat. The cup holder switch is the on/off, and the top switch is to change speed correct?...
The green ground wire attaches directly to the frame of the mixer. If the green iwire is attached directly to the speed "prong" you will have a direct short. There should be a grounding screw just inside the place where the wire enters the frame. If it really old, you may not have a ground screw because in the old days the wires only had two prong plugs. You can operate the machine without a ground wire,but if it fails internally you could get a potentially fatal shock. Any screw that is attached directly to the frame can be used as a ground screw. The green wire is there to take any grounded short circuit back to the breaker box instead of sending the electricity into you.
Sep 21, 2010 | Microwave Ovens
I have a Braun Kitchen Mixer KM32. I have had it for several years and like its capabilities. Now I find that the bakelite backing and speed control to the switch has dried out and has broken-up. Where can...
Braun KM32B Mixer is made in Germany long time ago.
You can buy a switch at:
http://www.californiaelectricservice.com/braun_km32_mixer_series_parts.asp
for $8.99, it does not fit, but still can use it as an external switch, in a small electric box.
Sep 04, 2010 | Microwave Ovens
My krups xp7200 is leaking water from the bottom. How can I open it to check the problem? thanks
Jun 15, 2010 | Microwave Ovens
My 15 year-old RHEEM Warrior Model 71-40S forty gallon electric water heater is leaking, and the element also needs replaced. I am thinking it is likely time to get a new, energy-efficient model versus...
Rheem makes great products. Lowe's sells whirlpool brand and they are not all that bad for the money. I would buy something better than the budget 7 year warranty model though. My preferred choice is AO Smith. I would definitely replace your water heater if it is 15 years old- most don't go much longer than that, although mine is 27 years old and going strong! Please remember to make sure and extend your pressure relief valve down to within 6 inches of the floor when replacing the water heater as Code requires. A water heater blanket will also earn its keep in a short amount of time.
Jan 02, 2010 | Microwave Ovens
Water will not pass through the capsule?
Try running vinegar in stead of water, without the coffee thru it several times.
Dec 27, 2009 | Microwave Ovens
Door handle coming loose, only 2 years old
I recommend that u glue it using some one minute epoxy, available at hardware stores, lowes, home depot
May 21, 2009 | Microwave Ovens
ON CHRISTMAS AS I MIXED A CAKE MY KITCHENAID MIXER SOUNDED LIKE IT WAS STRUGGLING, THEN IT JUST STOPPED RUNNING. MY MIXER IS LESS THAN 5 YEARS OLD AND REALLY HASN'T BEEN USED VERY MUCH. PLEASE TELL ME WHAT...
Is the warranty still valid?
Is there a recall on the model you have?
Typically the problem you describe is a problem with the motor brushes or you were mixing more material than the mixer was designed to mix and the internal thermal link failed.
The mixer is too young to develop this problem without abuse of a material flaw.
If there is no recall on it and the warranty has expired your best bet is to buy a new mixer. Repair cost will typically exceed the cost of a new on if it was a cheap model costing less than $50.00.
Jan 06, 2009 | Microwave Ovens
Microwave Ovens Logo
47 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
