Question about InFocus X3 Multimedia Projector
Turns on but no light projecting
Green blinking indicator light is on,,swapped out the bulb with a new
one but still no light projecting out the lens? power cord is not the original but cant imagine its the issue if the gren light is blinking?
can the bulb be tested?
    President:
  • 2,923 Answers
Try to reset the lamp timer before replacing it. Turn it on, and hold both volume down and volume up for 10 seconds. Then turn it off, and back on again. - See if it helps, if it doesn't, I think you can send the new bulb to where you bought it, and have them test the bulb.
There's no other way for us to test it, because you're projector is not working correctly, but the green blinking light indicator has something to do with the bulb.
You may need to get a new bulb.
Thank you and good luck!
Posted on Jul 22, 2010
  • chutson1 Jul 22, 2010
    The green blinking light has turned to a red blinking light ..what does that mean?
  • Melvin Ramos
    Melvin Ramos Jul 23, 2010
    A single red blip means there's a problem with the lamp, but I would try to reset the lamp timer before replacing it.
    Thank you!
I have a NEC VT700 projector. I replaced the bulb and housing because it would no longer turn on and the status light would blink every 2.5 seconds indicating the housing on the lamp had an issue. I...
I have solved that problems by replacing the plastic Lamp Cover. NEC says they wear out over the years due to the heat. If you have a spare VT700 about, swap covers and see if that works. or order one from NEC, thay cost 5 dollars.
Jan 12, 2011 | NEC VT700 Projector
Blinking Green Light on Mitsubishi DLP 52525
the circut that detects the bulb has been also failing in these sets
and the conversion chip that controls the picture , and the transformers are not putting out the full power they are supposed to.
this set will need to be tested to determine the exact cause or causes
Oct 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
The screen went black. Last time I changed the bulb and it started working. This time the TV did not come back. The screen is black. The center Green light and the bottom red light blink. Samsung 567W
Make sure properly connected and tightly sure cover put on and screws in,if change projection bulb,still blinking "LAMP" LED indication light.But,if "LAMP"LED indication flashes and making clicking noise.Ur Ballast board also dead.Require replacement,this Ballast board help to ignite the projection bulb.
Jul 30, 2010 | Samsung HLN567W 56" Rear Projection HDTV
Intermittant shut down with blinking green light on Sony TV 55"
Hi,Make sure you get the Original Philips lamps since they last 6000-8000 hrs 2-4 yrs,way better then Osram which last 4000-5000 hrs 1 - 1/2 yrs.
Oct 01, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
I have an LG DLP. that turns off after 15 -30 seconds
If the second light is blinking to orange or red, that is usually the lamp indicator light on an LG DLP tv. That indicates your bulb needs replaced, or something surrounding the bulb has failed (like the cooling fan for the bulb for example) IF you have a spare bulb handy, I'd replace the bulb, keeping in mind if you touch any part of a new bulb with your bare hands, you just cut the life of the bulb by more then half.
Jul 30, 2009 | LG RU-52SZ51D 52" Rear Projection...
New Bulb Doesn't Light
color wheel or light engine,call for service and save your money.
Aug 04, 2008 | Samsung HLN467W 46" Rear Projection HDTV
No Picture - Lamp Indicator Blinking
This may be the main power supply, or the lamp supply. This is providing that the new lamp is okay.
The service tech will swap out the modules to service the set.
Jerry G.
May 15, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Dec 06, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
InFocus X3 Multimedia Projector Logo
61 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
