Question about Vacuums
Where can I buy Vacum powerhead motor by Wertheim other then Godfrey, Thanks
I have bought it From Godfrey and solve the problem.
Posted on Apr 24, 2008
Wertheim 6035, lost manual, where is button to restart carpet head?
There is a hole at the back of the powerhead near the height adjustment lever. Just put something slender in the hole like a screw driver to reset.
Jul 08, 2012 | Vacuums
Hi I have an electrolux vacumm cleaner, super J model. My problem is that the powerhead only works if the switch is in the off position. vacumm motor works in the on position, opposite of each other. Can...
Looks like there's an interchanged wires in your vacuum. Both the motor and the powerhead must go together. Check it up. Leave the
motor wiring connection intact. Just tinker and check the powerhead
wiring connection .
Sep 25, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Need new powerhead for Fantom Lightning Style PH1A - Where can I buy it and how much?
I have the power head, wand & hose, exrra belt, 4 heps filters ans a spare main vacuum motor for Fantom Lightning. My main motor burned out. Found a used motor on Ebay. Went to change it and part of wiring was burned, so I decided not to rosk reairs with bad wiring. Power head was not attached at the time, so it is fine. I'll sell all together for a decent price, it you're interested.
Jul 15, 2009 | Fantom Vacums Lighting Canister Vacuum
Royal 3050 power head does not run
The sounds like powerhead motor either burned up, or the belt broke and got tangled in the turning motor shaft. Pull the bottom off the power head and look for a curled up rubber band. If you find one, it's the belt.
If it's the motor, you won't hear it running when you turn the powerhead on.
Jan 23, 2009 | Royal Procision 3050 Bagged Canister...
Replacing the powerhead motor
depending on which powerhead you have the screw may be under the decal on top of the powerhead. you should be able to feel an indent above the motor. most of the other heads do not have a "hidden screw".
Jun 12, 2008 | Filter Queen Majestic Canister Vacuum
Electrolux Epic 6500 Powerhead Motor
Call an Aerus Electrolux dealer in your area.
Jan 29, 2008 | Electrolux Epic 6500 Vacuum
My vacum power head wont work
fan belt might have snapped.  take off top by snapping out plastic over light.  good luck!
Apr 18, 2007 | Kenmore 23313 Whispertone Bagged Canister...
Vacums
check belt not broken - could have happened when you caught tassle in head
Vacuums Logo
236 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
