Question about GE 46GW947 46" Rear Projection Television
GE 46GW947 BOWED PIC
I have a bowed pixs and the colors are not lineing up my qusteion is where is the convergance chip located is it the board on the top of thr chassis up by the the crts i see it has a large red blue greeen wire assembly and a large heat sink with a stk chip on it also does any one have a repair manual some where for down loading thanks
  • 1 more comment
  • lucked Apr 22, 2008
    hi it looks like pn 151-2810a its hard to see thanks
    how about PN 1512810A THEN BELOW THAT D1 15127410 THANKS
    here it is the corerect number had to take the board out stk 730-130 i hope this is the convergance chip if not where is it in this tv thanks
  • GE Master
  • 8,617 Answers
The manual is almost impossible to find. But that chassis usually only has 1 IC that powers the convergence. Usually a STK730-020 or simallar. post the number off the IC you see up front and I will cross reference it for you and post a link where you can get a replacement
Posted on Apr 22, 2008
  • Sonny Berry
    Sonny Berry Apr 22, 2008
    I am not getting anything off that number. can you use a strong flashlight and repost all letters and numbers on that IC? thanks
I have Rca 52 inch that when I turned it on it was bowed at the top and the bottom, the images are double and the color is off.
sems like to me you have a convergences problem chedk conveg board and convergence chips and risistor or try replacing it. or try auto convergence. useally when when they are bowed at the top and bottom its the conver board..i hope this will help
May 28, 2012 | RCA Televison & Video
Convergences not linning up and bowed after replacing a blown fuse
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some images of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Or goto the site www.TvRepairKits.com for the parts and instructions on how to fix it yourself.
Apr 15, 2011 | GE 46GW947 46" Rear Projection Television
There are 3 distinct color lines and the picture looks 3d. The lines are bowed and trying to adjust using the convergence grid doesn't work- the grid is bowed
Mitsubishis are notorious for bad solder connections on the convergence IC's. These are located on the big heat sinks on the main board. It's an easy fix if you know how to solder. Check for any play on the IC's when "wiggled".
Feb 06, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Toshiba 50hdx82 tv touch focus error blue is bowed.
Convergence is dead.Know how to solders.Must replaced the 2 Convergence ICS,and all it resitors.To do it ur self repair buy a convergence kit at Tv repair World.com,Repeairkits.com.The shop will cost u $300 for parts and labors.
Feb 04, 2010 | Toshiba 50HDX82 50" Rear Projection...
I had to replace a fuse for the power supply and know the picture is blurry and bowed
Your convergence power supply is propably not working. The convergence supply board is mounted above the mainboard and has AC 110V supplied to it from the main PCB. That's probably why the fuse blew.Rca Has abulletin regarding replacing two diodes CR19710 and CR19713 on convergence power board.
Oct 02, 2009 | GE 46GW947 46" Rear Projection Television
Picture doubles and looks like 3d
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 21, 2009 | JVC AV-56WP74 56" Rear Projection...
Distorted picture
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
Using your original remote go-to the settings menu then goto the convergence section.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Mar 26, 2009 | RCA D52W23 52" HDTV CRT TV
Convergance
the regulator will sometimes blow the fuse when it shorts. Hopefully the regulator will solve the problem if not you will need to trouble shoot the convergence board itself
May 08, 2008 | GE 46GW947 46" Rear Projection Television
Conv problems with no pic has sound
  • Screen looks 3D
Apr 30, 2008 | Mitsubishi WS-55809 55" Rear Projection...
GE 46GW947 46" Rear Projection Television Logo
102 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
