Question about GE Profile JTP18 Electric Single Oven
F3 Error Code - GE Electric Oven JTP18
GE Profile JTP18 Electric Single Oven shows F3 after heating for 15 mins. Sounds like it has to do with the oven/temp sensor, but someone said they replaced and still had problem. Is replacing this part the first thing to try? Do you have suggestion on finding the part #?
  • Anonymous Mar 15, 2009
    Our oven is 13 years old......when I turn it on after 15 mins it beeps with the F3 showing. This has happened a few times when cooking or preheating the oven.
    President:
  • GE Master
  • 2,651 Answers
All ge codes f3 are saying ot replace thermal sensor, you can check the harness connecting them for a pinched or burnt wire i guess, as far as getting a part number , you can enter complete modle number her e and look for the sensor, i checked just the partial number you gave and a few different ones showed up
http://www.searspartsdirect.com/partsdirect/index.action
Posted on Apr 23, 2008
Ge oven jtp18 elements won't heat
The limit switch in a Ge oven usually works or is blown. I would look at the oven sensor located at the back of the oven. It should read approximately 1k ohm at room temperature.
http://www.on-timeappliance.com/ovenrepair.html
Mar 26, 2012 | GE Profile JTP18 Electric Single Oven
GE profile oven 326B1230P001 error code F7 will not go off. what does it indicate?
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Sep 05, 2011 | GE Profile JTP18 Electric Single Oven
My GE Profile electric oven keeps shutting off on me, it shows a "F3" code on the screen. What does this mean?
Sorry to read about your problem, I hope this helps you out.
your F3 means: Oven temperature sensor open you cannot reset this type of problem.
Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Jan 02, 2011 | GE Profile JTP18 Electric Single Oven
GE Wall Oven JTP 10GP F3 code when I turn it on it goes straigt to F3
on our maytag a f3 code means shorted or open temperature sensor. do not know if that code is the same as a ge, but you can google your oven model codes and find out what the problem is.
Jun 21, 2010 | GE Profile JTP18 Electric Single Oven
F3 Code on microwave
You have a shorted touch pad.. here is a link for a replacement.. http://www.pcappliancerepair.com/newfindform.phpIf you open up everything and examine the touch pad, you may see something that is causing the short and fix it, oherwise, you'll have to remove and replace it.. Hope this helps..
Jun 12, 2009 | GE Profile JTP18 Electric Single Oven
F3 code flashing
Replace your oven temperature sensor.
F-3 bad sensor.
Feb 02, 2009 | GE Profile JTP18 Electric Single Oven
GE oven only heats up to 300 then shuts off
just a thought but maby the
tempature sensure has gone bad
Jan 21, 2009 | GE Profile JTP18 Electric Single Oven
GE Profile Oven Model JKP13G0V1BB
f3 is a bad oven sensor, two screws will remove it in the upper left or right hand side of inner cavity.thin metal shaft protuding maybe 3inches or so.
Mar 23, 2008 | GE Profile JTP18 Electric Single Oven
GE Model JTP15 oven shows F3 error code
I have the same problem. I noticed that the oven gets to the selected temp ok. Then when the pilot attempts to RELIGHT, it gets the error F3. Did you get a solution? After other posts, I will see if the temp sensor is around 1100 ohm as suggested by others. Ken
Jun 14, 2007 | GE JTP15 Electric Single Oven
GE Profile-electric oven
Copper, F3 means oven temp sensor is open. You need to replace the probe. Easy job. Part number I have for this is WB23X5340, but double check your model number. Look it up on the net to see what you are going after...Catriver..post back
Sep 19, 2006 | GE Profile JTP18 Electric Single Oven
GE Profile JTP18 Electric Single Oven Logo
1,076 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
