Question about Midea Heating & Cooling
I NEED A MANUAL!! Midea MWF10CR 10000 BTU window unit, made by Westpointe. Does ANYONE out there have one??
  • 148 Answers
SOURCE: coils and raidiator freeze up in minutes
chances are you may need a bit of freon might have small leak on the flares
Posted on May 15, 2009
crouchdash
  • 83 Answers
SOURCE: fedders air conditioner 5200 btu manual
As rule of thumb the outside part should be lower than the inside part. You know that the angle is right when the water in the drain pan does not go toward the room but towards the drain itself.
I hope it helps.
Posted on Jun 26, 2009
MsMithra
  • 79 Answers
SOURCE: just bought a kenmore 10000 btu window a/c unit - need to install
You CAN put it on the 3rd floor as long as you make sure it's completely secure. One thing I do recommend is building (or buying) a window unit shelf that sits outside the window and the air conditioner sits on it for extra support. The shelf is secured by the window frame.
There are many "how-to" guides to building a window unit shelf all over the internet.
I hope this helps.
Posted on Aug 17, 2009
autobohm
  • 6 Answers
SOURCE: Dripping air conditoner
The "drip pan" is actually the entire base srround of the unit. There are two critical things you must confirm 1) is the unit angled back to the outside(you need water to flow away from the inside) and 2) there may be a plug/obstruction in the outer casing where the water is intended to drain from. You should check to see if either or both of these conditions exsist.
Posted on Aug 19, 2009
  • 674 Answers
SOURCE: We have a 10000 btu frigidaire window unit and it
Part of the function of an air conditioner is to dehumidify the air in the room being cooled. The water dripping out the back is the water being removed from the air in your house.
Posted on Jun 20, 2010
What is wrong with a Westpointe dehumidifier when it stops removing water and displays P1? It will run this way for hours and kick in and work briefly once in a while on continuous.
Usually the P1 error indicates that dehumidifier needs to be defrosted. The unit has detected ice build-up on the condenser coils.
Unplug the dehumidifier for several hours. Then plug it back in. If the problem recurs, check that the fan that blows air across the coils is working properly. Make sure that the room is not colder than the operating range of the dehumidifier. If the problems continues to occur, you may have a refrigerant leak in the system. That will require a service call to repair the dehumidifier.
If the unit is under warranty, contact Westpointe. The manual I have for a Westpointe 65 PT dehumidifier, https://www.appliancefactoryparts.com/content/pdfs/136333-1.pdf, indicates the unit is covered through year 5 after purchase for a refrigerant system. For Warranty service, the contact point is Midea Consumer Service at 1-866-646-4332. If the unit is not under warranty, consider whether to replace the dehumidifier.
I hope this helps.
(I have seen a dehumidifier develop a refrigerant leak. It constantly froze before the leak was repaired and the refrigerant topped off.)
May 15, 2017 | Dehumidifiers
Recharging with freon
fix the leak first then have it regassed properly
Jun 12, 2016 | Midea Westpointe, 12,000 BTU, Thru The...
I don't understand how to set my humidifier to run economically and still do it's job.
check manufacturer web site for a manual, most have them available for download
Jul 30, 2014 | Midea MDF1-30AEN3-BA4 Westpointe 30-Pint...
Zd30 year old does nothing !
check the fuse on the pcm board. 3 amp fuse. will need to open the unit up to get to it.
Oct 25, 2013 | Midea MDF1-40AEN3-BA5 Westpointe, 40 PT,...
WHy does P2 code come on display for my Westpointe DeHumidifier
I could not find the user manual for your particular model but the manual for the MDF1-30AE model indicates that the P2 code is when the bucket is full or not in the right position.
If you have already emptied the bucket and the error remains I would recommend checking around where the bucket goes as there should be a switch that gets pressed by the bucket when it is in the proper position.
My guess would be that when you are putting the bucket in it is not properly hitting this switch.
Source: User manual for MDF1-30AE
Oct 25, 2012 | Midea MDF1-40AEN3-BA5 Westpointe, 40 PT,...
Just bought a kenmore 10000 btu window a/c unit - need to install
I hope this helps.
Aug 17, 2009 | Kenmore 76100 Wall/Window Air Conditioner
Heating & Cooling Logo
80 people viewed this question
Top Midea Heating & Cooling Experts
Steve F
Mike
pawnpower
Are you a Midea Heating and Cooling Expert? Answer questions, earn points and help others
