Question about Kenmore Washing Machines
My kenmore 70 washing machine will not rinse.
  • 5,911 Answers
If the washer fills, agitates, then stops at the rinse cycle, the most common cause of the problem is a lid switch malfunction or lid strike (actuator) problem. Symptoms may include, filling and stopping on the intial fill cycle, stopping right after the wash cycle, not advancing to rinse or spin cycles, and a wash tub that will not drain.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike" or "Actuator") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because it does NOT have a lid strike (actuator) and the small hole on the right hand side of the wash tub will not be present. This type of switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator rod by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price of a replacement lid switch for this model washer is about $25 - $35 if you perform the repair yourself. Prices will vary between sites so shop and compare.
If you have questions, or need additional assistance, please post back with your MODEL NUMBER and let me know. This is a very simple repair that you can easily perform without the assistance of a repairman.
If this advice does not help you enough, repairclinic.com has a Repair Manual you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20.
Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful to you.
Posted on Jul 22, 2010
I have a Kenmore 70 series Washing machine top load model 110 serial number 82870120 . where is the lint trap located and how to take out to clean? clothes have a lot of lint after being washed.
It is likely that a tissue or paper product was included with the wash load. The series 70 does not have a lint trap. At the hose connection to the house drain lint has been known to build up restricting the emptying. This buildup would not introduce lint into the washer.
If the water temperature is very very cold and you use powder detergent it will not dissolve completely into the water and will leave a white residue on the fabrics.
Try running a short load in the washer allowing for ample water to rinse out the machine before the next wash load.
Dec 28, 2015 | Kenmore series 70 80 90 Washer timer...
Kenmore 70 series washer model 82871420 only runs on rinse cycle
Is the timer going through the wash time? Is the motor running but nothing happening? If the motor is running, then either it has not shifted into wash or the transmission is broken. An electrical coil shifts the transmission, it could be bad, or the trans it self is shot, time for a new washer.
Nov 04, 2012 | Kenmore Washing Machines
Kenmore series 70 washer leaks during rinse?
the was exhaust hose is either plugged or cracked. also check the drain it is put into as this sometimes will be puleeged with fabric from the clothes you wash
Jul 10, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 series washing machine will wash but won't rinse/drain water...what could this be?
This is likely your lid switch has gone out. If you give model number I can give you part number
May 17, 2009 | Kenmore 22422 Top Load Washer
Kenmore washer not spinning ans washing
Does it sound like the motor is running at all ?( if motor is running u need a coupler) (with machine off turn cycle switch around 3x roughly, then try machine) With the machine off do you hear a clicking noise if you open and close the lid?
Mar 25, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 20722990 series 70 will not drain
I have the same problem right now. I found a dime in the discharge but it still does it. I am going at it from the front side of the pump now. I need disassembly instructions for the upper sections to get to it. It was really nasty dirty and stinks.
Mar 18, 2009 | Kenmore 20722
Kenmore 70 series model #11020712990 won't rinse
The TIMER is what is bad in this case.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 13, 2009 | Kenmore 20172 Top Load Washer
Washing Machines Logo
Sal De
fordexpert
 Brian Main
Brian Main
