Brother HL-4000CN error 003-340 Turn OFF Power
SOURCE: Brother HL 2460 has E- 50 error code
you shold change the logic board to slove this problem
Posted on Apr 01, 2009
  • 1170 Answers
SOURCE: Lost power cord Brother HL 2040
there is no need to buy an exclusive power cord for this Printer. any power code with the same connectors will do.
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
Posted on Apr 02, 2009
komguy
  • 2306 Answers
SOURCE: Hi I have a Brother HL-6050D/N Error E60
E60 says the fan is not working, I would try first to blow it out, and after that look for a replacement fan.
Posted on Nov 27, 2009
  • 21 Answers
SOURCE: Brother hl 2460 showing error E51
mulfunction of laser beam detector,
turn off the printer wait for a few seconds if still remain - replace laser unit.
Posted on Jun 21, 2010
Brother HL-5250 printer toner Light on but Cartridge has Toner it
Try this....
1: Turn off power and remove toner/drum
2: Tape the little spring loaded lever just inside the printer on the upper left hand side in the *DOWN* position! Do not replace drum yet and...
3: Turn power on to printer and let it cycle. Status/Toner lights will come on as usual.
4: Turn off printer, remove tape from lever, replace drum and turn back on.
Mar 08, 2010 | Brother HL 5250DN Laser Printer
Brother hl 2460 showing error E51 please help
Dec 27, 2009 | Brother HL 2460 Laser Printer
Brother HL-2140 Error light is flashing
Try to unplug the power from the print, wait 1 minute then plug back in.
This may remove the error.
Sep 26, 2009 | Brother HL 2140 Laser Printer
Brother hl-5270dn is desplaying the error code S01? What does this mean?
S01 = Fatal error EX
1) turn off the printer
2) wait a few seconds
3) turn it on again
H63 = DRAM access error
3) turn it on again
Sep 11, 2009 | Brother HL 5250DN Laser Printer
Message E52 Service call what does that mean? (Brother HL 7050)
Probably a fatal error. Bad Laser Unit. Try unplugging the power cord for 10 seconds.
Jan 06, 2009 | Brother HL 7050 Laser Printer
Lost Installation CD for my Brother HL-2040 printer
Where Can I download installation software for Brother HL-2040 printer
Sep 13, 2008 | Brother HL-2040 Laser Printer
All error lights blinking and fan running but won't print...
Yes Mr. Guest and Mr SwT,
Replace the fuser assembly unit.
Definitely the fuser got problem. This can be confirm by pressing the Go button and only the Toner LED will light up.
What had happen was right after the power blackout the fuser has fused together both rollers (heating drum and rubber roller) where the paper pass through in between the rollers. Since there was a power blackout, the printer fan has stop functioning and the heat was unable to disperse out from the printer. Suggest to improve on design to disperse heat using aluminium cage in case of power blackout.
Who ever has a Brother HL-2040 should definitely use together with a UPS.
chekamal
Apr 27, 2008 | Brother HL-2040 Laser Printer
Brother Printer HL 1240
OK figured out the sequence to resolve this error:
power off unit
unplug power cable for 1 minute
reset the power cable
open front door
press and hold the reset button under the lights
turn the power on
printer should then be reset
Feb 21, 2008 | Brother HL 1240 Printer
162 people viewed this question
jasbo
jasbo
