Question about Dell Dimension 4700 PC Desktop
I get a pop up with a RED CONTRAST screen every few minutes It sometimes goes away if I push the contrast button on my Dell monitor. but it will usually come right back. I have tried everything to stop this problem I can think of. Sometimes I also shut off just thie monitor, but it will still come back.
You can try the monitor on another computer to verify it is the monitor and not the display card at fault.
I'm assuming this is an LCD monitor. If you are sure the monitor is the problem, then your monitor's display driver circuit is probably getting close to failing. When one of the three colors (red, green, blue) becomes intermittent, the screen takes on the hue of the working colors. In your case it sounds like the blue is starting to fail.
A repair technician may be able to replace the circuit.
Posted on Jul 22, 2010
I have a dell crt monitor. Luminance Temperatura pop up on the screen and it go on and off. Sometimes contrast or bright appear on bottom of the luminance temperature. How do I fix?
Sep 01, 2010 | Dell E773C 17" CRT Monitor
Contrast/Brightness Menu repeatedly pops on screen/won't go away
What kind of system do you have there? Regular PC + monitor or All-in-one/Laptop?
Dec 30, 2017 | Dell E172FP 17" LCD Flat Panel Monitor
Black screen on computer monitor
Here is the link for the E151FPb monitor manual.
Since you email your question you have access to get this manual and print it. The manual shows the Auto set button, the contrast control button and a monitor reset feature.
Unfortunately you have to do each of these blind. Follow the instruction given, push buttons smartly, wait a few seconds for any action to take place, then follow the next instruction.
Good luck.
Feb 01, 2010 | Computers & Internet
Contrast window pops up and dims the screen.
You are not alone. I have a Viewsonic monitor that does exactly the same thing. Wasn't sure if it was the monitor or a "bug".
Dec 10, 2009 | ViewSonic VX910 19" LCD Monitor
Contrast button stuck? driver issue? etc?
It is a hardware problem and needs a replacement. Also try to unpress/release it by tapping lightly on the monitor. If you feel it is a driver problem then go to Start->Control Panel->System->Hardware->Device Manager->Monitor. Remove this monitor and from Action in the Menu select San for New HW. the monitor drivers will be loaded and you can then reboot.
Nov 08, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
A few moments after I start my computer, I get a blue box in the center of my monitor that displays contrast. It keeps popping up every few minutes, what do I do? I keep pressing the exit button of the...
The contract button seems to be stuck. Try pressing the button hard a few times and see if it helps. If the contract button still keeps poping up and it may be a physical problem with the button there.
Aug 16, 2009 | Dell Computers & Internet
Brightness/contrast window pops up and scrolls through fast
The up/down button on your flat panel is stuck. Please contact Dell Technical Support to have the monitor replaced if its still within warranty.
May 28, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
The Contrast screen pops on all the time
It looks like your UP button contact is demaged.
SOLUTION is to insert a piece from your business card mostly above the button to adjust it down or up. It works fine.
Dec 09, 2007 | ViewSonic VX910 19" LCD Monitor
Menu keeps popping up
Never a good idea to clean with any spray cleaner. The cleaner does get down in the button bar and cause corrosion and shorting along ribbon cable. Use screen wipes for computer monitors only on TV's and any type of monitors. You can remove the back of the case. And remove the button board and clean with a cue tip and alcohol along ribbon cable.
Nov 04, 2007 | Acer AL1912 19" LCD Monitor
Dell 17" monitor
I had a simalar problem with my Dell 2001FP. The issue is that there is false triggering of the switch; you need to open the front panel, and electrically remove the swictch from the circuit by: 1) analyze the circuit; its usally pretty simple - a voltage drop circuit. 2) disable the switch by either removing it with a solder gun or, simply by using a sharp blade and cutting the PCB track leading it to it, as I did.(much easier - and reversible!) Fixed my problem.
Jun 03, 2006 | Dell E773C 17" CRT Monitor
Dell Dimension 4700 PC Desktop Logo
131 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
