Question about Garden
Mtd Yard Machine 16.5 h.p. LT Briggs & Stratton 16.5 OHV Model #313707 Type #0162 - E1 Code #010516 ZE Mower will start then shut-down... It does stay running if I squirt gas directly in the carburetor. I have taken the carburetor completely apart and cleaned it thoroughly. Changed the gasoline filter...replaced spark plug. Cleaned the holding tank where the gas enters the motor. Replaced the gasoline line. Checked all wiring...I have missed something but what is it?
  • kbbees Jul 22, 2010
    Yes we are going to try it...
  • 821 Answers
Hello,Typically this is caused by an obstruction or restriction in the gas system. The gas can seep to the engine's carburetor but not enough to keep it running. After being off a while the carb fills up with enough to run it for about a minute and then runs out again.
One thing to check before you get into the system too far is to make sure the vent in the gas cap is clear. If it can't get air into the tank it will do what you are describing. Try running it without the cap and see if it runs OK. If it does, take a paperclip or something small like that and clear out the little hole in the cap.
If the gas cap doesn't take care of the problem then try addng some "SEA FOAM" to the gas and run it. That is a fuel system cleaner. You can get this at most auto parts stores. Follow the directions on the can. Hopefully this will take care of the problem.
If it is a two stroke clean out the muffler.
wish you good luck,
take care.
Posted on Jul 22, 2010
Model # 313707 systematic
You can find the full schematic and parts list for model model 313707. This link has everything on your machine. A full set of schematics and a full parts list for every part.
Briggs and Stratton 313707 0162 E5 Engine Parts
Jun 05, 2014 | MTD Yard Machines Yad achine 42" 420cc MTD...
Torque pattern for Briggs & Stratton 313707 OHV head bolts
its a criss cross patern dont over tight they will break off when running make sure of your tork on them
Jan 03, 2013 | Briggs & Stratton Briggs Stratton...
Does a briggs 18 hp twin 2 have a oil filter its a late 90's model mtd riding mower
Most likely yes. It will look like a car oil filter. It looks like a round can that is screwed to the engine.
Mar 17, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Have a Yard Machine riding mower with 21hp Briggs Stratton engine OHV/IC V-Twin. when I turn on key nothing happens. How many switches control the start motor from the ignition and where are they located....
It depends on the model but most riders have the following;
1. Seat switch
2. Brake pedal switch
3. PTO switch
4. Neutral switch (if its a shift model)
All need to be closed in order to start engine.
Jun 03, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Changing oil in Biggs and Stratton engine
Use 10W30 weight oil. The capacity is 1.5 Quarts (48 ounces) with filter change. I highly recommend you use 100% synthetic oil in an air cooled engine. Change the oil and filter every 50 hours of use.
Apr 23, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have a Briggs & stratton 18hp ohv riding lawn mover. Model # 31D777 type: 0233 E1. Do you know where I can find an Owner's manual that can be downloaded on the computer? Went to briggs & Stratton...
I also have this same engine and am also looking for the owners/workshop manual . Also went to Briggs & Stratton with no satisfaction. If you find anything please drop me an email aswell. Thank you. harmsen2@bigpond.com
Mar 27, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Need a spark plug size for a yardpro self propelled lawn mower model number yp6y22cha briggs and stratton 6hp
If your mower does not have "OHV", overhead valves. You can use a Champion j19lm spark plug.
If you discover you do have overhead valves; A Champion RC12YC, will work.
Apr 28, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
261 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
