Question about HP Photosmart C6180 All-In-One InkJet Printer
Have HP Photosmart C6180 all in one printer that continually turns on and off, the orange exclamation sign lights up & the screen says "To avoid damage, use the On button to shut down the printer. Do not use a power strip or wall switch to turn off" & Press OK. I cannot do anything else! Any solutions?
  • 100 Answers
Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This fix stopped my printer from power cycling and also fixed the ink system failures the printer was having. Have HP Photosmart C6180 all in one printer that - 3ace550.jpg
I ordered parts from mouser.com, but DigiKey.com may have better prices. I ordered 3 of these and 1 of these
Posted on Sep 28, 2010
  • minpdx Jan 28, 2011
    This info has been so helpful along with this group of pictures:http://picasaweb.google.com/109215435720... The pictures show how to get to the logic board. Thank you for helping me fix my printer instead of turning it into a boat anchor!
I lost the dics to my hp photo smart printer i need it to use my printer
here are your driver downloads
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=uk&lc=en&dlc=en&product=1153494
Jun 04, 2011 | HP Photosmart C6180 All-In-One InkJet...
While installing the HP Photosmart Full Feature Software and Drivers from the HP website, power went out for a few seconds. When power returned the printer was off and will not turn on when the power...
Theres nothing in the drivers that would cause this unless the software was doing an update to the printers internal software
you could try a hard reset
1. Remove all cables, including:
2. Unplug the printer power.
3. Hold down # and 6 on the keyboard.
4. Plug the power cord back in. .
Mar 18, 2011 | HP Photosmart C6180 All-In-One InkJet...
The screen no longer works on the hp photosmart d7260.
the touch screen on my hp is showing only black. it has a orange exclamation flashing and the manuel only says there is a error if you see this exclamation, Helpful!! I tryed to unplug everything and restart, didn't work still black and not working. any thoughts?
Nov 28, 2010 | HP Photosmart D7260 Printer
My HP Photosmart C6180 repeatly keeps turning on and off, but it never makes it to main screen. The HP loading continues to load and then auto shuts down (i do notice a flash of orange screen) I tried to...
Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This fixed the on and off problem and also fixed the ink system failures the printer was having. A similar fix may apply to other printers . acca299.jpg
Sep 01, 2010 | HP Photosmart C6180 All-In-One InkJet...
Hello. i have the hp Photosmart C6150 printer. for
Press the button on the printer, to turn the printer off.
Then, press the switch on the power-bar, to completely cut the power to the printer.
Turn the power-bar on.
Turn the printer on.
Jul 06, 2010 | HP Photosmart C6180 All-In-One InkJet...
Touch screen doesn't work
The photosmart c6180 does not have a touchscreen feature. You can check all of the features of this printer on our website HP.com.
Jiffy Epe
HP Technical Support Representative
Aug 27, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
112 people viewed this question
Ben Johnson
